Fuel Line Material - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
 3Likes
  • 1 Post By ctcz28
  • 1 Post By 69-Pace
  • 1 Post By Luwi67
post #1 of 13 (permalink) Old Apr 17th, 17, 04:41 AM Thread Starter
Jon
Fuel Line Material
Hi,
I need to determine if my fuel lines are stainless steel, or aluminium, as I can't register the car with aluminium fuel lines.
I've tried using a magnet, but some stainless isn't very magnetic at all, so it didn't really tell me anything.
Anyone have any suggestions as to how I may determine which material they are?
Many thanks in advance!
Heavychevy67 is offline
post #2 of 13 (permalink) Old Apr 17th, 17, 05:23 AM
Chris
Re: Fuel Line Material
If there is a hidden spot you could just touch the line with a grinder to see if it sparks, that would tell you. Obviously, the SS will spark and the Al won't. The Al is softer than the SS so if you can devise some sort of scratch test. I would also think that an Al line would be a lot easier to bend than a SS line so if you could detach the line and try bending it in your hands that might give you an idea too. The magnet test isn't very reliable for testing SS as you don't know the makeup of the SS alloy and the chromium may mask the magnetic properties of the nickel and iron depending upon its concentration in the alloy.
Heavychevy67 likes this.
'69 Z/28, Lemans Blue/White Stripes, DZ302, T56 Mag., 4.10
Dynatech, 17" VWW V45's 235/45, 275/40
ctcz28 is offline
post #3 of 13 (permalink) Old Apr 17th, 17, 05:26 AM
69-Pace's Avatar
Moved this thread from the issues with your website browser on the Camaros.net site problem forum to the tech section for best response.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 13 (permalink) Old Apr 17th, 17, 09:32 AM
Bobby
304 stainless which most pre-bent lines are made from is non magnetic however, as 304 is bent it will become slightly magnetic. Try the magnet test again with a strong magnet.
Stainless has a shiny appearance, aluminum more of a light grey dull look unless someone polished them but still not look like stainless.
I've never used aluminum tubing but all the stainless and cunifer tubing I've used has the information printed on the tubing of what it is, try looking for that. Keep in mind it could be worn off in spots so check the whole length.
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180 Headers
black/black
no radio
Luwi67 is offline
post #5 of 13 (permalink) Old Apr 18th, 17, 08:01 PM Thread Starter
Jon
Thanks for the tips!
I'll have a snoop around for any identifying stamp in the line.
post #6 of 13 (permalink) Old Apr 19th, 17, 05:05 AM Thread Starter
Jon
Hi ctcz28
The fuel lines are installed and full to fuel, so I can't grind anything at this stage. Thanks for the info on stainless steel composition re magnet test.
Is there a section I could "sacrifice" for a slight grind if I were to take the lines out for testing?
Thanks.
post #7 of 13 (permalink) Old Apr 19th, 17, 05:13 AM
Vega$69's Avatar
Simply scrape with a knife. If aluminum it will scrape metal off easy. If stainless it won't.
Vega$69 is offline
post #8 of 13 (permalink) Old Apr 19th, 17, 10:46 AM
Greg
pittpens24's Avatar
x2
'68 Camaro SS with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #9 of 13 (permalink) Old Apr 19th, 17, 06:35 PM
Chris
Also a good test, and easy. I'd try this first.
ctcz28 is offline
post #10 of 13 (permalink) Old Apr 19th, 17, 07:09 PM Thread Starter
Jon
Great ideas! Thanks fellas!
post #11 of 13 (permalink) Old Apr 19th, 17, 07:24 PM
Chris
Originally Posted by Heavychevy67 View Post
Hi ctcz28
Thanks.
I'd probably remove the shortest section I could find (like the short section under the driver's seat on a '69 from the prop valve to the rear line connector, not sure what the lines look like under a '67) and test it, then put it back in or just replace it. Cutting and flaring lines isn't too hard and you can probably rent the flaring tools for free at an auto parts store. If you don't want to mess with cutting and flaring, buy a slightly longer tube with the flares and flare nuts already installed and put a few "S" curves in it to make it shorter overall so it will fit in the place of the piece you removed (will look a bit funky, so better hidden under the car).
Here's another approach. You're testing this in order to register the car. Unless you personaly don't want lines made out of Al and want to replace all the lines, I wouldn't worry about it. I'm assuming that you have to have the car inspected to get it registered and thus the issue. I'd take the car to get it registered and if you get pushback, I'd put it on the registration agency to prove beyond all reasonable doubt that the lines are Al and not stainless. If it's this difficult to determine the difference then how can they say its Al and not SS? If they pull out a magnet and if it doesn't attract to the lines that proves nothing. You could even take in some form of reference documentation stating that not all SS will attract a magnet like ferrous metal will if they don't believe you. Even if you test the lines and determine that the lines are SS, it's still your word against their charge that the lines are made of Al. What are you supposed to do, break out a grinder on the spot and generate some sparks? I bet they will let it pass.
ctcz28 is offline
post #12 of 13 (permalink) Old Apr 19th, 17, 08:50 PM
Vega$69's Avatar
Actually the owner is responsible to prove the lines are not aluminum as part of the process.
Vega$69 is offline
post #13 of 13 (permalink) Old Apr 20th, 17, 05:38 AM
Chris
If this is the case, then I'd find out what the registration agency requires in the form of proof. Do they want brand new (anything but Al) lines installed on the car with the manufacturer's label stickers still attached and the dated purchase receipts? How about taking it to a shop acceptable to the registration agency and get the shop to certify the lines?
ctcz28 is offline
Tags
fuel lines
Human Verification
