Power steering install - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
post #1 of 2 (permalink) Old Sep 13th, 06, 05:11 PM Thread Starter
Steve A.
flat350's Avatar
Send a message via AIM to flat350
Angry Power steering install
Can anyone tell me what combination of parts will work to install the power steering pump on my 68 . Car was big block originally ( long gone ) it now has a 72 350 ,long water pump , headers . I have the pump and cradle can't seem to find the right combo to get it to where the pump will swing and tighten the belt at all ( could the pump and cradle be from the big block , were they different )
flat350 is offline
post #2 of 2 (permalink) Old Sep 13th, 06, 06:22 PM
Re: Power steering install
Yes, big blocks are different. Short and long water pumps use different also.
'69 used longpumps so use brackets to fit a '69. There are three pieces used on a '69.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
TJS69 is offline
Human Verification
Power Steering and Brake Conversion Issues biggytab Brakes, Suspension & Steering 6 Jul 11th, 06 06:08 PM
Adding a power steering pump on 396.... mjtav01 Engine 4 May 14th, 06 04:51 PM
trouble adding power steering to my 67 RS DPeter2101 Brakes, Suspension & Steering 6 Apr 6th, 04 09:06 PM
Running Compressor off Power Steering Pulley? Brian Lewis Heating & Cooling 4 Mar 11th, 04 12:22 PM
Supercharger power steering problem need A-Body Procharged69 Tech 2003 5 Oct 22nd, 03 11:44 AM
