1969 RS Washer Hose Routing Diagram - Team Camaro Tech
Restoration Corner Where originality comes first
post #1 of 8 (permalink) Old Sep 27th, 11, 09:42 PM Thread Starter
Lloyd
I'm trying to locate a detailed windshield / headlight washer hose routing diagram for a 1969 RS. The AIM is vague on details for the RS in this area and a Team Camaro (and CRG) site & archives search didn't produce any detailed routing diagrams either. I also checked the major Camaro parts vendor web sites. Does anyone have the diagram?
Edgemontvillage is offline
post #2 of 8 (permalink) Old Sep 28th, 11, 03:46 AM
69-Pace's Avatar
Re: 1969 RS Washer Hose Routing Diagram
nozzles to radiator shroud with vacuum lines to fender skirt, where it routes up with the vacuum lines to firewall then across to washer pump.
Been a long time since I looked at the AIM but it has the correct diagram but no real text if I remember right.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 8 (permalink) Old Sep 28th, 11, 05:09 AM Thread Starter
Lloyd
There are 6 nozzle connections, where does each hose go? What about T connection(s)? The AIM doesn't show these specific hose connections at the main washer pump or connection details of the RS-only solenoid. Hose routing to the headlight nozzles from the inner fenders forward is reasonably straight forward. A diagram would help.
post #4 of 8 (permalink) Old Sep 28th, 11, 05:26 AM
69-Pace's Avatar
Start at the left side (pass) headlight, T or Y connector (depends on your kit - original is a T) both nozzles to main run line, that main run crosses across radiator shroud on front side to the right (drivers) headlight, then to a T connector with output going to another T to the right headlight two nozzles, the other side of the main run T connector continues up the fender skirt toward the firewall across the wiring bundle in back of the booster to the second pumps nozzle. There are only 4 nozzle connections in my 69, two at each headlight.
I'll try to take some pictures if I ever get home before dark this week.
69-Pace is offline
post #5 of 8 (permalink) Old Sep 28th, 11, 05:18 PM Thread Starter
Lloyd
Thanks for the explanation, pictures would be helpful. At one point in 2002 a TC Member posted detailed pump & solenoid drawings together with hose routing diagrams which are no longer hosted on this site and the off-site link is broken. I reached out to a couple of Members who participated in the discussions in '02 in hopes someone had saved a copy of the diagrams. I received an email last night with a copy! I am out of town until tomorrow PM however when I'm back and in front of my home PC I'll post the diagrams. Hopefully you can post a few pictures to accompany them. This should probably be a Sticky for future reference.
post #6 of 8 (permalink) Old Sep 28th, 11, 05:31 PM
Bob
This one:
Thank Mark X22. He did a great job on it.
BelAir Bob
69 Z28 X33 D80 Dusk Blue
69 Z28 X33 Rally Green
BelAirBob is offline
post #7 of 8 (permalink) Old Sep 28th, 11, 07:12 PM Thread Starter
Lloyd
Originally Posted by BelAirBob View Post
This one:
Yep, that's it. I agree, Mark did a terrific job on the diagram
post #8 of 8 (permalink) Old Sep 28th, 11, 10:44 PM
69-Pace's Avatar
cool. Thanks for posting.
69-Pace is offline
Human Verification
