1969 Seatbacks and headrests - Team Camaro Tech
Restoration Corner Where originality comes first
post #1 of 13 (permalink) Old Feb 4th, 13, 03:50 PM Thread Starter
Matt
I know that headrests went from straight to bent early in the 1969 model year, but can anyone tell me if there were changes to the seatbacks at the same time or if they remained the same through the model year? Thanks
srq34231 is offline
post #2 of 13 (permalink) Old Feb 4th, 13, 04:00 PM
Anne
Re: 1969 Seatbacks and headrests
The seats didn't change. I'm pretty sure about that, but if you check with a parts supplier like Rick's you can confirm it.
Lawrence454 is offline
post #3 of 13 (permalink) Old Feb 4th, 13, 04:33 PM
Gary
If you mean the plastic backs of the seats, they were the same for 68 and 69.
Unreal is offline
post #4 of 13 (permalink) Old Feb 4th, 13, 05:22 PM Thread Starter
Matt
In particular, I was refering to the top of the seatbacks. The older straight headrests seem to push down to fit squarely against the top of the seat, but the bent ones I have seen don't seem to fit against the seat as well. I'm not sure if that is normal or if I'm looking at older seats with newer bent post headrests. Thanks
srq34231 is offline
post #5 of 13 (permalink) Old Feb 4th, 13, 07:45 PM
Garth
That's the way they are. Headrests and the associated hardware changed over the years (First Gen) but the basic seat frames remained the same......http://camaros.org/headrest.shtml
Garfields Maro is offline
post #6 of 13 (permalink) Old Feb 5th, 13, 10:30 AM
I just had my 69 std seats out , converting to TMI deluxe. I have the angled head rests so they go directly down into the seat but still has a slight tilt forward. Is this what you are asking?
I have an early 12A car from Nov 68.
Name:	TMI front.jpg
ID:	32129   Click image for larger version
Name:	tmi fronts.jpg
TC # 349
zdld17 is offline
post #7 of 13 (permalink) Old Feb 5th, 13, 10:53 AM
Kevin
KevinW's Avatar
I know what Matt is talking about, but I do not have an answer. I have both angled and straight headrest seats. If you try to put an angled headrest into a straight seat, it does not fit correctly and visa-versa. Its close, but they do not go down into the escutchion properly. I have taken off both the escutchion and lower plates from the seats, but could not really see the issue. But there is one!
I am talking about original factory seats. I have no knowledge on how the repro ones are with this.
Kevin
KevinW is offline
post #8 of 13 (permalink) Old Feb 5th, 13, 11:11 AM
Jennifer
I am not sure if this helps or not but here are a couple of shots of my seats. I have the curved bar headrest. The seats have been recovered, not sure if the material over the headrest was also recovered but I'm almost positive the seat frames and headrests are original.
Name:	2012-12-15 01.00.53.jpg
ID:	32131   Click image for larger version
Name:	2012-12-15 00.58.23.jpg
Frosty 69- L65, TH350, original RS (and will be again some day), 59 59 frost green with D90 hockey stripe, power windows- back on the road after 20 long years!
nsaneblk- 2011 Camaro Black 2LT/RS M6 (daily driver)
Frosty69 is offline
post #9 of 13 (permalink) Old Feb 5th, 13, 02:28 PM
Fred
Here's a couple of dusty one's. The pictures, not the seats. The seats are original. If I find some better shots in the next few minutes I'll stick them up here but if these don't help I'll go out to the garage and snap somemore. Say the word.
128.79mph 1.428 60'
Fred Ficarra is offline
post #10 of 13 (permalink) Old Feb 5th, 13, 03:06 PM
Garth
Would you agree it's only the curved bar headrest that doesn't fit the contour of the seat when in the down position ??
Straight bar was changed to curved bar for safety reasons during the 69 production run, around Nov/Dec 68. Nothing else in the seat was changed.
Actually imo, to be most effective against whiplash, the headrest should be be in the up position. The difference in contour isn't nearly as noticable, as shown in Fred's pics.
post #11 of 13 (permalink) Old Feb 5th, 13, 03:10 PM Thread Starter
Matt
The pics helped. My bent bar headrests fit in the seat back, but don't fit the shape of the top of the seat well when down. It looks like that is common, so I feel better now that mine are as they should be. Thanks for the help and pics.
srq34231 is offline
post #12 of 13 (permalink) Old Feb 5th, 13, 03:40 PM
Fred
OK, hot off the presses. They follow the seat closely.
ID:	32141   Click image for larger version
128.79mph 1.428 60'
post #13 of 13 (permalink) Old Feb 5th, 13, 06:23 PM
Ed
Coming into this late, but the only thing that changed was the head rest itself. And then only the angle of the bar. The seat and the mounting assembly didn't change. And yes, the "fit" isn't as good with the angle head rest as with the straight.
Ed
Ed B.
CRG -
bertfam is online now
Human Verification
