gas pedal bracket at firewall - Team Camaro Tech
Restoration Corner Where originality comes first
post #1 of 11 (permalink) Old Dec 11th, 13, 07:22 AM Thread Starter
Mikem67's Avatar
Does anyone have a pic of the mounting bracket that mounts to the firewall? It's the one that the gas pedal rod goes through and connects to the flat piece on the engine side that the threaded rod to the carb attaches to. Also does the gas pedal rod have a plastic grommet on both sides of the bracket? If so, who has the replacement grommets for the rod and the carb rod at both ends?
'67 Vert RS/SS
Mikem67 is offline
post #2 of 11 (permalink) Old Dec 11th, 13, 10:53 AM
Timmy
Re: gas pedal bracket at firewall
Hi Mikem67
Sorry a little Grainy,
Will take better ones if you need.
Timmy
Name:	1969 Camaro Gas Pedal Engine bay.jpg
ID:	55633   Click image for larger version
Name:	1969 Camaro Gas Pedal interior.jpg
french69ssrs is online now
post #3 of 11 (permalink) Old Dec 11th, 13, 02:23 PM Thread Starter
Mikem67's Avatar
Exactly what I needed, thank you. Do you know if there are two plastic grommets on the shaft that runs through the bracket and are there bolts and nuts or just sheet metal screws holding the bracket to the firewall?
Mikem67 is offline
post #4 of 11 (permalink) Old Dec 11th, 13, 03:21 PM
Timmy
Hi Mikem67
Went into the Garage when I got home and took some detail Pics.
The actual shaft moves back and forth like 1/2" and the Fat Arm that fits over the Shaft that has a "flat" in it to lock onto the Arm is also a little lose with like a 3/8 Washer.
I was at Ground Up last month and some guys came up from Long Island for parts for a High HP 69 that's on the Internet/ Youtube.
They broke the Gas Pedal off the shaft and bought a new one, looked just like mine but did not notice if there were more washers or a bushing to control the Side play.
Timmy
Name:	1969 Camaro Gas Pedal Engine Bay.jpg
ID:	55649   Click image for larger version
Name:	1969 Camaro Gas Pedal Pivot Interior.jpg
post #5 of 11 (permalink) Old Dec 11th, 13, 03:38 PM
Roger
Mike this is a pic of mine before the restoration. The fasteners were originally bolts and nuts with the nuts to the engine side.
Roger
rogerh is offline
post #6 of 11 (permalink) Old Dec 11th, 13, 03:46 PM Thread Starter
Mikem67's Avatar
Thanks for the pics they really help. Don't know if there was a difference from '67 to '69 on the fasteners but I have two ways to go now, thanks again for the help.
Mikem67 is offline
post #7 of 11 (permalink) Old Dec 11th, 13, 04:03 PM
Timmy
From Ground Up's Catalog,
Many other Parts Suppliers have this stuff.
http://www.ss396.com/mm5/merchant.mv...ort=&offset=10
2/3 way down on Page is
1967-1969 Camaro Accelerator Rod Grommet Kit
Code: APJ-1314
Price: $6.95
Or From Camaro Central -
1967 Accelerator Throttle Rod Support, Firewall Mount, Steel
Our Price: $25.95
Accelerator rod firewall support for 67 Camaro models. Made of steel construction with bushing inserts.
PART NUMBER: ACL-9
Timmy
post #8 of 11 (permalink) Old Dec 12th, 13, 02:58 PM Thread Starter
Mikem67's Avatar
Does anyone know where to get the nylon grommets that go on both sides of the firewall bracket that the gas pedal rod goes through?
Mikem67 is offline
post #9 of 11 (permalink) Old Dec 12th, 13, 05:29 PM
Timmy
Hi Mike
Found this -
Timmy
Name:	Camaro Central.jpg
post #10 of 11 (permalink) Old Dec 13th, 13, 05:23 PM Thread Starter
Mikem67's Avatar
Thanks Timmy, just ordered them.
Mikem67 is offline
post #11 of 11 (permalink) Old Dec 13th, 13, 06:59 PM
Jon
The support comes in two different flavors. Some are steel, but most later ones are solid plastic. I'm thinking the steel ones may have bushings but the plastic ones don't.
John N.
Today's Republicans are yesterday's Democrats, and today's Democrats are yesterday's Communists.
dyno jonn is online now
Human Verification
