Original hardware - See Post #2 & #5 - Page 2 - Team Camaro Tech
Restoration Corner Where originality comes first
post #16 of 23 (permalink) Old May 30th, 15, 04:55 PM
Steve Orr
steveo66ss's Avatar
Re: Original hardware - See Post #2 & #5
Can't go wrong with original parts! Processing Black Oxide or Zinc Phosphate is the easy part if you have the correct chemistry. Preparing the surface is KEY so be careful on how aggressive you are with original parts and surface finish. Take plenty of quality photo!Click image for larger version
steveo66ss is offline
post #17 of 23 (permalink) Old May 30th, 15, 07:00 PM
Chick
68camaroz28's Avatar
Originally Posted by steveo66ss View Post
Can't go wrong with original parts! Processing Black Oxide or Zinc Phosphate is the easy part if you have the correct chemistry. Preparing the surface is KEY so be careful on how aggressive you are with original parts and surface finish. Take plenty of quality photo!Attachment 112186
Think we talked at a Carlisle event! Yes, agree original parts are great but members should know also that many of the same supplier hardware is available and if your screw, bolt or whatever is pitted it will look terrible. Many including me phosphate our own parts unless its size prohibited. Palmetto products are easy to use, and inexpensive. For anyone reading this thread and are interested there are many excellent threads that can be found using the search key discussing using the Palmetto products and subsequent processes.
Chick
68, 69, & 2015 Z/28's
69 Nova's L34 Father/Son & L78 Surv purch-new
67, 68, & 2015 Z06 Corvettes
Our 68Z Restoration
68camaroz28 is offline
post #18 of 23 (permalink) Old Dec 28th, 15, 05:11 PM
Chick
9780422 Screw-GM is used heavily. I found the 9780422 screw to be made up by three suppliers which are identified in the picture with individual pics of the head markings. AMK uses Anchor screws for 9780422 and that might be correct but I decided to use 9780422 screws with the three suppliers found on my car and others for restoration. AMK catalog index has reference for 9780422 if anyone needs to order.
Chick
Our 68Z Restoration
post #19 of 23 (permalink) Old Jan 8th, 16, 06:42 AM
Bill
Is there anything for the 1967 Camaro regarding the original style nuts and bolts like the posting for 1968-69 Camaro? Coupe
coupe is offline
post #20 of 23 (permalink) Old Jan 8th, 16, 04:51 PM
Look up the part number in the 67 AIM. Then search Chick's thread for the
part number. Many of the same fasteners were used on 67's and 68's.
my 67' build thread:
allanjs is offline
post #21 of 23 (permalink) Old Jan 23rd, 16, 05:26 PM
Chick
As Al mentioned many of these fasteners/screws/bolts/clips were used on all Gen I Camaro's. What I have listed was for our 68 Z/28 car but have some 69 AIM items listed as well.
Chick
Our 68Z Restoration
post #22 of 23 (permalink) Old Aug 15th, 16, 04:44 AM
Chick
Recently updated Fastener Chart and wanted to share-Also placed in my build thread.
FIRST GENERATION CAMARO FASTENERS-68/69 AIM Fastener Part #'s Note: 68 assumed and 69 noted
Screws
0103321-P319, P320 3/8" lock washer AMK B-13052 (25) .38X.68 X.105thk
0159853-P98
0174916-1/4" Toothed Lock Washer w/9420415 screw (elect grounds), 69 AIM pages-28, 155, 156, 161, 182, 439, 440, 441, 460 AMK B-11314 (Cool
0187875-P155
0274430-P91
0447143- P39/91/162 (69 AIM UPC 1 A5) Hex screw 8-18X1/4 .34" O.D. AMK- B-11070 (20pcs) 0456766-P237 front spoiler #10-12X5/8 5/16 AF .4 O.D. Noted some originals had D in hex head.
0585842-P44 AMK N/A
1359887-P144, P366 5/16-18 1/2AF .67OD .28THK muffler clamp/hood leveler nut AMK B-12891 (6)
1363900-P119
3748038-P94 Motor Mt RH 3/8-16X7/8 9/16 AF .65 split B-12456 (2) B-12456 (2)
3749084-P319 Wire retainer (shift rods) AMK B-13390 (3) B-11574 (10)
3758783-P149 Battery hold down clamp bolt- AMK has no reference by GM part#
3768390-P94 3/8-16X1 1/8 9/16 AF .65 split AMK B-12458 (2)
3778526-P99 Fuel Pump 3/8-16X1 1/2 9/16 AF .65 split AMK B-10904 (2)
3784303-P68/118 5/16-18X7/8 1/2 AF .55 split similar B-10913 (2)
3786494-P94 Motor Mt LH 3/8-16X1.0 9/16 AF .55 split B-10907
3817006-P99 Timing cover & oil pan correct 1/4-20X7/16 7/16AF .44 external B-10881 (10)
3821961-P46 AMK N/A
3824124-P36 Zinc/Wiper Motor 10-24X1.0 .33 external AMK B-12298 (6)
3831892-P178 3/8-16X1 1/8 9/16AF 1.0 Conical "f' head AMK B-11718 (2)
3837950-P124
3839682-P144 hood leveler screw 5/16-18X1 3/8 .59 OD AMK B-10396 (2)
3839741-P135/142 3/8-16X1 3/8 1.31 Conical AMK B-11964 (4) Head Marking circled E?
3841230-P73/123 10-16X1/2 5/16 AF .4 O.D. AMK B-10511 (4)
3841497-P319 7/16-20 9/16 AF .22thk AMK B-10511 (4)
3846201-Pages 147 & 206 (69 AIM) 5/16-18X5/8 .75 Conical AMK B-12545 (5) Support bar to radiator support. Note: 2 orig. 69's had same bolt in both ends of support bar
3846202-Pages 61/63/73/144/145 5/16-18X7/8 .75 Conical AMK 'E', B-13317 (6) & B-10876 (12) & 'C' type B-11709 (6) & B-11710 (12) Note: Both head marks acceptable.
3847757-P127/141
3847758-P143 thread design not correct 5/16-18X1 1/16 1/2 AF .75 conical AMK B-11549 (2)
3848408-P91
3849634-P45/153 Stainless 8-18X5/8 .27 O.D. AMK B-11117 (12)
3853846-P155 Zinc/horns- 5/16-18X7/8 .75 toothed AMK Anchor head-marked screw B-10900 (2)
3856065-P141
3856691-P74 1/4-20X5/8 7/16 AF .62 conical Mfg marking not correct AMK B-10800 (6)
3857663-P135 3/8-16X1 3/8 1.0 Conical AMK B-11387 (4) B-11874 (12)
3858195-P186 8-18X3/8 1/4AF .34 O.D. AMK B-12049 (20)
3858700-P229
3863392-P53 10-16X3/4 5/16AF .4 O.D. AMK B-11090 (Cool
3863393-P52 1/4-14X1.0 7/16AF .69 External Zinc AMK B-11200 (2) or B-11201 (6)
3872454-P49 Similar 3/8-16X15/16 9/16AF .88 Conical AMK B-11717 (2)
3873950-P55, 56 Top Hat Screw 10-16X5/8 1/4AF .42 O.D. AMK B-11089 (Cool
3873951-P166 10-16X5/8 1/4AF .42 O.D. Top hat style AMK B-11088 (Cool
3873999-P188
3876129-P92 Voltage Regulator 10-24X1.0 5/16AF .5 O.D. AMK B-10011
3899538- P141 5/16-18X7/8 1.5 Conical AMK B-11600 (2) & B-11601 (6)
3899718-P56
3903536-P145 LH side only radiator 1/4-20X13/16 3/8AF .51OD AMK B-10384 (2)
3903539-P145 LH side only radiator sp/nut 1/4-20 .50X.63 L body ,.73 OD flange AMK B-10608 (2)
3904859-P42 Nut AMK N/A
3909140-P68/179 3/8-16X1 1/8 9/16AF 1.12 Conical AMK B-11719 (2)
3910700-P320 shifter/shock rubber grommet AMK B-10237 (4)
3918503-P68 3/8-16X1 1/8 9/16AF .8 Conical AMK B-10877 (4)
3919053-P160
3919089-P40, 48, 53 Dash Mat trim cover screws AMK N/A
3921445-P153
3922549-P360 5/16-18X7/8 1/2AF .55 split AMK B10913 (2) see 9409098 for alt.
3933052-P36 Zinc/Wiper Arm Pivots 10-24X1/2 .33 external AMK B-10884 (4)
3958062/9420825- 5/16-18X9/16 1/2AF .66 O.D. Brake & Fuel Line Clip screw AMK-Anchor B-10416 (4)
3963329- 3/8-16X1 1/2 1.12 Conical AMK B-11720 (2)
3986563- 3/8-16X1 1/4 1.31 Conical AMK B-11964 (4)
5544049-P320 .64 X 2.10 Shock/shifter stab. retainer AMK B-11235 (4) B-11236 (10)
9409098-Could be used for 3922549 if zinc removed and phosphated AMK B-12321 (2)
9409107-P171/361/366 1/4-20X5/8 7/16AF .44 split AMK B-12303 (4)
9411890-P119
9414252-10-16X5/8 .36 O.D. AMK B-12220 (10)
9414724-P172 10-16X3/4 .37 O.D. Zinc/AMK B-12197 (10) Note: Same screw available in Phosphate
9414752-P51 8-18X1/2 .27O.D. chrome screw AMK B-12116 (12)
9414754-P51 8-18X3/4 .27O.D. chrome screw AMK B-12123 (12)
9414763-10-16X5/8 .31 OD AMK B11135 (10)
9414764-10-16X3/4 .31 O.D. AMK B-11136 (Cool
9414766-10-16X1.0 .31 O.D. AMK B-12225 (6)
9414767-10-16-X1 1/4 .31 O.D. AMK B-12227 (6)
9415464-P161 8-18X1/2 1/4AF .34 O.D. AMK B-13419 (12) B-13750 (40)
9416208-P47 8-18X3/4 .31 O.D. AMK Stainless & Chrome B-12124 (10) B-11524 (50) Note: Sill Plate Screws
9416822-10-16X1 1/4 .36 O.D. AMK B-12228 (6)
9417318-10-12X1 1/2 .36 O.D. AMK B-12229 (4)
9417706-P186
9417986-same as 9416208
9418359-P262 8-18X1/2 .31 O.D. AMK B-12153 (15)
9418551-P42 10-24X3/8 .44 Conical Glove Box Hinge 67/68 Phillips Head AMK B-10925 (3)
9419028-P127
9419107-P361 1/4-20X5/8 7/16AF .44 split Zinc AMK B-12303 (4)
9419234-P319 washer .41 X .73 X .06thk B-11281 (12)
9419301-P48 Hood Hinge to Hood but not Hood Hinge to Fender- 3/8-16X13/16 1" Conical AMK B-10835 (4)
9419303-P52/72/187 10-16X1/2 5/16AF .4 O.D. AMK B-12081 (10)
9419305-P92 10-16X1/2 5/16AF .4 O.D. AMK B-12081 (10)
9419326-P163
9419327-P's 43, 44 8-18X1/2 .31 O.D. AMK B-12152 (15)
9419329-P167 10-16X5/8 .37 O.D. AMK B-11530 (10)
9419328-P163 10-16X1/2 .37 O.D. AMK B-12192 (10)
9419370-P70/89 5/16-18X5/8 1/2AF .55 split AMK B-12312 (4) Phosp B-12313 (4) Zinc
9419380-P103/128/153 1/4-14X3/4 3/8AF .5 O.D. AMK B-11104 (25)
9419400-P366 1/4-14X1/2 3/8AF .5 O.D. B-12093 (Cool B-11400 (25)
9419402-P123 5/16-18X3/4 1/2AF .66 O.D. AMK B-12589 (6)
9419663-P163 8-18X1/2 1/4AF .34 O.D. AMK B-13419 (12) B-13750 (40) Note: AMK also has Stainless & zinc dichromate Same screw as 9415464 & 9426269
9419672-same as 9419327
9419778-P229
9420151-P153 1/4-14X3/4 3/8AF .5 O.D. AMK B-12102 (Cool Phosp B-12103 (Cool Zinc 9420152 -14X1/2 3/8 AF AMK N/A Obtained Corvette Central #192117 correct zinc E screws. Additional info last page.
9420415-P38/150/155/156/178 1/4-14X3/8 3/8AF .5 O.D. AMK B-11097 (Cool B-11099 (25) Orig. head markings 'D' & RBW w/dimple (69 AIM pages-28, 155, 156, 161, 178, 182, 439, 440, 441, 460)
9420431-P156 10-24X1/2 5/16AF .4 O.D. Similar AMK B-10411 (8 pcs.)
9420494-P55
9420554-P153 8-18X1.0 .27 O.D. AMK B-11120 (10)
9420603-P62/113 5/16-18X3/4 1/2 AF .64 OD RBW (note-similar to 9780422 & used on Z-bar)
9420686-P229 8-18X5/8 1/4AF .34 O.D. AMK B-11076 (10)
9420721-P41 Same as 9423863 8-18X3/4 .31 O.D. Phillips Head Phosphate B-12170 (10) Zinc B-12171 (10)
9420723-P42 AMK N/A
9420825/3958062-Pages 72/73/123 5/16-18X9/16 1/2AF .66 O.D. Brake & Fuel Line Clip AMK-Anchor B-10416 (4)
9420941-Battery Tray- 5/16-18X5/8 1.12 Conical AMK B-13716 (2)
9421137-P229 8-18x1/2 .31 O.D. AMK B-11144 (10)
9421479 P37 Zinc-Cowl Panel Screw 8-18X9/16 1/4 AF .62 Flat AMK B-12172 (4) Our originals were phosphate, but not the norm.
9421495-P46 10-16X1/2 .37 O.D. Outside Mirror AMK B-11223 (6)
9421851-P41/167 10-16X5/8 .44 Flat Washer AMK B-12231 (6)
9421934-P231
9422245-P45 Listed under AMK but not on page shown???
9422297-P320 Cad anchor nut 3/8-16 GR8 9/16 AF .33 thk AMK B-10526 (6)
9422455-P230
9422606-P72
9422641-P128 1/4-14X1.0 3/8AF .75Flat Note: our 68 had 1.0 Flat vs. .75" AMK B-11431 (5)
9422654-P41 Clip Nut #8 .44 X .62L AMK B12245 (Cool
9423258-P161 10-16x3/4 .31 O.D. AMK B-11137 (10) Note: 9425622 same screw
9423351-10-16X7/8 .31 O.D. AMK B-11138 (Cool
9423863-Same as 9420721 8-18X3/4 .31 O.D. Phillips Head AMK Phosphate B-12170 (10), Zinc B-12171 (10) 9424858-P188
9423909-P122
9424858-P55 10-16X3/4 .37 O.D. Similar AMK B-11157 (10) phosp B-12197 (10) Zinc
9425111-P42 AMK N/A
9425486-P170
9425578-P169
9425622-10-16x3/4 .31 O.D. AMK B-11137 (10) Note: 9423258 same screw
9425812-10-16X1 .36 O.D. AMK B-12226 (4)
4926269- see 9419663- 8-18X1/2 1/4AF .34 O.D. AMK B-13419 (12) B-13750 (40) Note: AMK also has Stainless & zinc dichromate
9426539-10-16X3.0 .31 O.D. AMK B-11139 Note: Used for 67 Camaro vent window
9427208-P44 Steering Arm Cover 67/68 8-32X7/16 .38 Conical AMK B-10848 (4)
9427326-P53
9428499-P229
9431963-Zinc/Ign. Coil Bracket- 5/16-18X5/8 5/8 external AMK 'RBW' B-13232 (4)
9432395-Trunk Latch/striker 1/4-20X5/8 .75 toothed AMK B-10891 (5)
9780422-Pages 137/141-145, 149, 153 5/16-18X3/4 .67OD AMK 'anchor' B-13306 (12) B-13307 (50) Heavy use-fender, header, valance, batt. tray, hood catch, etc..
9824833-Std. Arm-rest Base Screws 1/4-14X1 1/2 .45 OD AMK B-11163 (6)
9919303-P138
Door-Deluxe/Custom Door Pull Straps 68/69 Camaro 1/4-14X1 7/16 .37 O.D. AMK B-11161 (4)
Door-Inside window hardware screws (correct) 1/4-20X7/16 7/16AF .55 O.D. AMK B-10427 (6)
License Plate Screws- AMK B-11179 (Cool
Seat Back Panel Screws 67-69 Camaro 8-18X3/4 .5 Flat washer AMK B-11222 (4)
Tail-lamp Housing Screw 67/68 Camaro 8-18X1/2 1/4AF .34 O.D. AMK B-11075 (12)
Wheel Opening Trim Screws- 8-18X7/16 AMK B-11532 (10) & B-10064 (32)
Bolts
0122017-P79
0122104-P152
0179868-P68
0180122-P79 3/8-16X1.0 9/16AF AMK B-10148 (4) Phosp B-10149 (4) Zinc
0180124-P79 3/8-16X1.25 9/16AF AMK B-10136 (4) Phosp B-10137 (4) Zinc
0186622-P126 3/8-16X1.25 9/16AF AMK B-11616 (4)
0191163-P79 3/8-16X4.0 9/16AF AMK B-10165 (1) Zinc
0385099-P127 5/16-18X5/8 1/2AF .75 Conical Similar AMK B-12548 (5)
0396712-P121 3/8-16X3.5 .8 O.D. AMK B-10074 (2) Note:thread end not correct
0839756-Flywheel 7/16-20x1.0 11/16AF AMK B-10191 (3) 3758783-P Battery hold down bolt with .87Dia captured washer
3790332-P62 5/16-18X6.5 9/16AF .34 Body Similar AMK B-10174 (2)
3817224-P94 'A' head marking AMK kit G4650 like originals except for bolt end chamfer
3892754-P66
3929905-P178 chrome 3/8-16X2.0 .75 O.D. AMK B-12755 (2)
6255899-P178/179 chrome 3/8-16X7/8 .75 O.D. AMK B-12751 (2) B-10887 (4)
9417950-P178
9418822-P81 See 180122 3/8-16X1.0 9/16AF
9418967-P79 3/8-16X3/4 9/16AF AMK B-10163 (2) Phosp B-10164 (2) Zinc
9419008-P103
9419073-P95 7/16-14X1.0 5/8AF AMK B-13682 (4)
9419101-P178 1/2-13X1.5 3/4AF AMK B-12590 (4)
9419713-P127 7/16-14X3.875 5/8AF Similar AMK B-10186 (1) B-10187 (2)
9421430-P59 1/2-13X3.75 3/4AF AMK B-13749 (2)
9424069-Caliper Brake Brackets 7/16-14X1.25 5/8AF AMK B-10184 (2)
9425299-P82
Clips
0125912-P73 Brake Line AMK B-10301 (4) cad. 3857706-P151 AMK N/A Heartbeat City has EGP-1124
3880723-P161
3881339-P73 Brake Line
3886521-P73 Brake Line
3886522-P73 Brake Line AMK B-10318 (1) Phosphate
9422836-P161 AMK B-10588 (Cool
Nuts
0102646-P126 Tie Rod 7/16-20 5/8AF .38thk AMK B-10585 (2) Zinc
0120368-P152 5/16-24 GR5 1/2AF .27thk AMK B-11505 (10) Phosphate B-12785 (10) Zinc
0121743-P156 Alt/relay junction 12-24 7/16AF .16thk AMK B-10502
0134530-P162
0134551-P168
0271172-P137/138 1/4-20 7/16AF .5 O.D. .24 OAH attached tooth washer B-12814 (Cool phosp B-13779 (Cool Zinc
0272876-P67/94 Castle Nut 7/16-20 11/16AF .37THK AMK B-10045 (4)
0359887-P118
0381700-P51/55/56 push type spring nut 5/32 stud .44 O.D. AMK B-10566 (15)
0445109-P163 spring nut #8-18 .41X.62 long AMK B-13370 (Cool
0445347-P51
1359889-P144
1378333-P127 flange nut 3/8-16 9/16AF .89 O.D. .4 thick AMK B-10475 (6)
3759924-P155 elect washer/nut 10-24 3/8AF .45 O.D..19 OAH AMK B-13507 (Cool
3846854-P138
3849974-P153 headlamp housing spring nut #14 AMK B-12259 (6)
3899847-P153 headlamp bezel plastic nut AMK B-12914 (6)
3907444-P178/179 Plastic Push in (license plate) AMK B-12920 (Cool
3921446-P153 headlamp adjustment plastic push in AMK B-12923 (4)
9417954-P178 5/16-18 GR5 1/2AF .27thk AMK B-12782 (10) phosphate B-12783 (10) Zinc
9418302-P144
9418828-P178 1/2-13 GR5 3/4AF .44thk AMK B-12797 (6)
9418931-P48/59/70/113 3/8-16 GR5 9/16AF .33 thick AMK B-12788 (Cool Phosphate B-12789 (Cool Zinc
9419751-P139
9419753-P137/139 stamped nut 1/8 5/16AF .53 O.D. AMK B-10629 (10)
9419755--P154 stamped nut #10 3/8AF .5 O.D. AMK B-13383 (10)
9419841-P138 stamped nut 10-24 3/8AF .5 O.D. AMK B-10352 (10) Phosphate
9419845-P52
9420171-P166
9420222-P153
9422654-P153 spring nut #8 AMK B-12245 (Cool
9425691-P178/179 conical nut 3/8-16 9/16AF 1.0 O.D. .46 OAH AMK B-12841 (4) B-11515 (12)
Lock Washers/P-Washers
0103319-P82/103
0103320-P178
0103321-P70/81 3/8 Regular lock washer
0103328-P95 7/16 Heavy .45X77 X.14THK AMK B-13058 (20)
0128144-P178
0135629-P42
0174916-P150 Toothed washer elect grounds 1/4 .26X.69 O.D. AMK B-11314 (Cool
0187119-P82 lock washer 5/16
1193463-P127 ,46X1.13X.19thk AMK B-11287 (3)
1362249-P178 53X1.24X.12thk AMK B-13073 (4)
3693853-P94 flat washer similar .47X.93X.09thk AMK B-11291 (12)
9419892-P103 flat washer .28X.62X.07thk AMK B-12989 (20) Phosphate B-12990 (20) Zinc
Rivets
67/68 Grille & RS Mldg.3/16X.27LX.44O.D. Black Anodized Alum. AMK B-13426 (Cool
9417761-P121 Drive Rivet to replace later service replacement gas cap screws. #6X5/16 .25 O.D. AMK B-10762 (10)
Wing Nuts/Clip Nuts/Special
0102634-P65 5/16-18 GR5 1/2AF .27THK AMK B-12782 (10) Phosphate B-12783 (10) Zinc
0124829-P113/150 3/8-16 9/16AF .22THK AMK B-12787 (Cool Phosphate B-10504(Cool Zinc
0273801-P89
0358501-P65 Lug Nut 7/16-20 3/4 AF .56 OAH AMK B-10010 (5) B-01545 (20)
0447143-P29 Detail #2 P Windshield Washer Nozzles AMK #B-11070 Zink Silver plating
1361640-P94
1365067-P68
3743360-P113 Bell-crank Felt AMK B-11303 (1)
3784845-P142/144 fender clip but nut not correct 5/16-18 .69WX1.0L AMK B-10616 (4)
3829086-P117
3841497-P319 Shifter linkage nut 7/16-20 9/16 AF .22Thk AMK B-10511 (4)
3868790-P40 Firewall Mat/Pad Rubber Plug AMK B-10672 (2) Can purchase as kit also
3886973-P39 washer nozzles
3892755-P66
3876130-P92 Volt. reg. 10-24 .37X.56L body .56 Flange O.D. AMK B12936 (3)
3899880-P145 fan shroud clip AMK B-10720 (2) Note: similar
3901399-P67 Springs & axle housing Nut 7/16-20 GR-8 11/16 AF .62 long AMK B-11508 (8)
3916608-P132 Spare Tire J-hook AMK B11379 (1) Note: see 9785616 wing nut
4874119-P37 Cowl Panel Plug
7279805 Radio Shaft Nuts 7/16-20 9/16 AF .12 THK B-10556 (2)
9417614-P66 1/2-20 GR8 3/4 AF .44 thk AMK B-10499 (4) Phosphate B-12801 (4) Zinc
9418699-P102
9419912-P103 Air Cleaner Nut 1/4-20 1.32 W AMIK B-10008 (1) Chrome
9422297-P79/81 nut 3/8-16 GR8 9/16 AF .33 THK AMK B-10526 (6) Cad
9422299-P59 nut 7/16-14 GR8 11/16 AF .38 THK AMK B-10533(4) Cad
9422301-P59 nut 1/2-13 GR8 3/4 AF .44 THK AMK B-10518 (4) Cad
9423518-P41
9785616-P132 Spare Tire Wing Nut AMK B-10612 (1) Note: see 3916608 J hook
CRG thread on hardware- Correct Fasteners and headmarkings
Thread I started on CRG & 68 fasteners- Documenting 68 Camaro Fasteners & Hardware
9420152-409 Radio Ground strap (68 AIM page 409) from body to sub-frame utilizes screw 9420152 and it was zinc. The screw is a self-tapping, 1/4-20 x 1/2", with indented head. Our originals were 'E' and can be purchased @corvette Central #192117 (2 for $2). Paragon offers the same screw with "RBW" #11189K, 7 screws for $5.00. 1967/8 Corvettes used this screw for radio ground straps and the front crossover brake line clip. AMK does not offer this screw!
Chick
Our 68Z Restoration
post #23 of 23 (permalink) Old Aug 15th, 16, 05:44 AM
Chick
Another area the AIM is incorrect on the hood hinge to fender screw. That screw assembly used a smaller diameter captured washer (conical diameter 3/4") as it gave more flexibility with adjustment compared to what is listed that had a 1" captured washer (conical diameter).
A picture showing the difference in washer diameter.
Chick
Our 68Z Restoration
Human Verification
