Original hardware - See Post #2 & #5 - Team Camaro Tech
Restoration Corner Where originality comes first
post #1 of 23 (permalink) Old Jan 13th, 15, 08:23 PM Thread Starter
Dan
Hello fellow Camaro builders
I am restoring a 68 SS that sat in a garage for 42 years on the east coast and most all of the nuts & bolts are in very bad shape (un-restorable). Can anyone out there tell me where a good source of used or restored original hardware is. Or if anyone has a bucket full of original stuff they want to get rid of please let me know.
I have look at some items from AMK but the heads patterns are not correct in some cases.
The reason I am so concerned of the originality is that this car only has 9977 original miles on it.
Any help would be appreciated.
69 LeMans Blue X77 Z28 (full restoration complete)
68 Corvette Bronze RS Z28
68 LeMans Blue SS 396 L78 (under full restoration)
DDZ28 is offline
post #2 of 23 (permalink) Old Jan 13th, 15, 08:53 PM
69-Pace's Avatar
Re: Original hardware
IMHO AMK fasteners has the best reproduction hardware sets out there.
http://www.amkproducts.com/default.htm
Here is the 68 GM catalog broken down in PDF format.
File Type: pdf AMK GM Fastner Kit Contents 1968 part1 of 2.pdf (57.5 KB, 433 views)
File Type: pdf AMK GM Fastner Kit Contents1968 part2 of 2.pdf (71.2 KB, 261 views)
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 23 (permalink) Old Jan 14th, 15, 05:57 AM
Try soaking all your original hardware in Evaporust. You'll be surprised how well that stuff works.
'67 SS/RS 350, Muncie M20, Black with black interior.
b17brian is offline
post #4 of 23 (permalink) Old Jan 14th, 15, 06:16 AM
parkbrau's Avatar
A guy on E-Bay sells original hardware. His ebay name is originalcorvette. He also sells on the yenko.net site.
http://www.yenko.net/ubbthreads/ubbt...reb#Post595806
parkbrau is offline
post #5 of 23 (permalink) Old Jan 14th, 15, 06:36 AM
Chick
68camaroz28's Avatar
Dan do some searches as there is much to review. Check my build thread as I have a lot of info there as well on hardware but let me start with a few lessons learned. Good advice as without a doubt AMK is where restorers obtain most of their hardware (screws, bolts, etc.) needs, and Evapo-Rust IMHO needs to be in anyone's garage who is doing any type of restoration but in many cases original hardware is pitted and sometimes the mfg. markings are destroyed. I saved what I deemed needed saved and then re-phosphate which is a fairly simple process. If you were just addressing a 9977 mile car by taking out a bolt, putting in evapo-rust, and then coating with rust prevention magic to protect for its longevity that is one thing but you stated "restore". A large % of AMK's hardware has the correct configuration and in many cases even one of the many suppliers used back then as many were used so maybe your comment concerning head patterns means suppliers. The main goal is to have the correct configuration and what AMK does as well is gives you a guide as the back of their catalog (another thing every garage needs to have) has a listing of GM hardware by part number which assists with what did a certain screw or bolt configuration have. During our 68Z restoration (still going on) I spent hours going thru the AIM and AMK catalog along with reviewing our hardware off our car and other survivors. Not everything is correct from AMK or suited my fancy but I'd tell anyone to purchase the kits as it will save you a lot of time and again many of the pieces are exactly what I had in our 68. Here is a list that I think will help you so good luck on your project. Note the page number is the page from the AIM.
FIRST GENERATION CAMARO FASTENERS-68/69 AIM Fastener Part #'s Note: 68 assumed and 69 noted
Screws
0103321-P319, P320 3/8" lock washer AMK B-13052 (25) .38X.68 X.105thk
0159853-P98
0174916-1/4" Toothed Lock Washer w/9420415 screw (elect grounds), 69 AIM pages-28, 155, 156, 161, 182, 439, 440, 441, 460 AMK B-11314 (Cool
0187875-P155
0274430-P91
0447143- P39/91/162 (69 AIM UPC 1 A5) Hex screw 8-18X1/4 .34" O.D. AMK- B-11070 (20pcs)
0585842-P44 AMK N/A
1359887-P144, P366 5/16-18 1/2AF .67OD .28THK muffler clamp/hood leveler nut AMK B-12891 (6)
1363900-P119
3748038-P94 Mtr Mt RH 3/8-16X7/8 9/16 AF .65 split B-12456 (2) B-12456 (2)
3749084-P319 Wire retainer (shift rods) AMK B-13390 (3) B-11574 (10)
3758783-P149 Battery hold down clamp bolt- AMK has no reference by GM part#
3768390-P94 3/8-16X1 1/8 9/16 AF .65 split AMK B-12458 (2)
3778526-P99 Fuel Pump 3/8-16X1 1/2 9/16 AF .65 split AMK B-10904 (2)
3784303-P68/118 5/16-18X7/8 1/2 AF .55 split similar B-10913 (2)
3786494-P94 Mtr Mt LH 3/8-16X1.0 9/16 AF .55 split B-10907
3817006-P99 Timing cover & oil pan correct 1/4-20X7/16 7/16AF .44 external B-10881 (10)
3821961-P46 AMK N/A
3824124-P36 Zinc/Wiper Motor 10-24X1.0 .33 external AMK B-12298 (6)
3831892-P178 3/8-16X1 1/8 9/16AF 1.0 Conical "f' head AMK B-11718 (2)
3837950-P124
3839682-P144 hood leveler screw 5/16-18X1 3/8 .59 OD AMK B-10396 (2)
3839741-P135/142 3/8-16X1 3/8 1.31 Conical AMK B-11964 (4) Head Marking circled E?
3841230-P73/123 10-16X1/2 5/16 AF .4 O.D. AMK B-10511 (4)
3841497-P319 7/16-20 9/16 AF .22thk AMK B-10511 (4)
3846201-Pages 147 & 206 (69 AIM) 5/16-18X5/8 .75 Conical AMK B-12545 (5) Support bar to radiator support. Note: 2 orig. 69's had same bolt in both ends of support bar
3846202-Pages 61/63/73/144/145 5/16-18X7/8 .75 Conical AMK 'E', B-13317 (6) & B-10876 (12) & 'C' type B-11709 (6) & B-11710 (12) Note: Both head marks acceptable.
3847757-P127/141
3847758-P143 thread design not correct 5/16-18X1 1/16 1/2 AF .75 conical AMK B-11549 (2)
3848408-P91
3849634-P45/153 Stainless 8-18X5/8 .27 O.D. AMK B-11117 (12)
3853846-P155 Zinc/horns- 5/16-18X7/8 .75 toothed AMK Anchor head-marked screw B-10900 (2)
3856065-P141
3856691-P74 1/4-20X5/8 7/16 AF .62 conical Mfg marking not correct AMK B-10800 (6)
3857663-P135 3/8-16X1 3/8 1.0 Conical AMK B-11387 (4) B-11874 (12)
3858195-P186 8-18X3/8 1/4AF .34 O.D. AMK B-12049 (20)
3858700-P229
3863392-P53 10-16X3/4 5/16AF .4 O.D. AMK B-11090 (Cool
3863393-P52 1/4-14X1.0 7/16AF .69 External Zinc AMK B-11200 (2) or B-11201 (6)
3872454-P49 Similar 3/8-16X15/16 9/16AF .88 Conical AMK B-11717 (2)
3873950-P55, 56 Top Hat Screw 10-16X5/8 1/4AF .42 O.D. AMK B-11089 (Cool
3873951-P166 10-16X5/8 1/4AF .42 O.D. Top hat style AMK B-11088 (Cool
3873999-P188
3876129-P92 Voltage Regulator 10-24X1.0 5/16AF .5 O.D. AMK B-10011
3899538- P141 5/16-18X7/8 1.5 Conical AMK B-11600 (2) & B-11601 (6)
3899718-P56
3903536-P145 LH side only radiator 1/4-20X13/16 3/8AF .51OD AMK B-10384 (2)
3903539-P145 LH side only radiator sp/nut 1/4-20 .50X.63 L body ,.73 OD flange AMK B-10608 (2)
3904859-P42 Nut AMK N/A
3909140-P68/179 3/8-16X1 1/8 9/16AF 1.12 Conical AMK B-11719 (2)
3910700-P320 shifter/shock rubber grommet AMK B-10237 (4)
3918503-P68 3/8-16X1 1/8 9/16AF .8 Conical AMK B-10877 (4)
3919053-P160
3919089-P40, 48, 53 Dash Mat trim cover screws AMK N/A
3921445-P153
3922549-P360 5/16-18X7/8 1/2AF .55 split AMK B10913 (2) see 9409098 for alt.
3933052-P36 Zinc/Wiper Arm Pivots 10-24X1/2 .33 external AMK B-10884 (4)
3958062/9420825- 5/16-18X9/16 1/2AF .66 O.D. Brake & Fuel Line Clip AMK-Anchor B-10416 (4)
3963329- 3/8-16X1 1/2 1.12 Conical AMK B-11720 (2)
3986563- 3/8-16X1 1/4 1.31 Conical AMK B-11964 (4)
5544049-P320 .64 X 2.10 Shock/shifter stab. retainer AMK B-11235 (4) B-11236 (10)
9409098-Could be used for 3922549 if zinc removed and phosphated AMK B-12321 (2)
9409107-P171/361/366 1/4-20X5/8 7/16AF .44 split AMK B-12303 (4)
9411890-P119
9414252-10-16X5/8 .36 O.D. AMK B-12220 (10)
9414724-P172 10-16X3/4 .37 O.D. Zinc/AMK B-12197 (10) Note: Same screw available in Phosphate
9414752-P51 8-18X1/2 .27O.D. chrome screw AMK B-12116 (12)
9414754-P51 8-18X3/4 .27O.D. chrome screw AMK B-12123 (12)
9414763-10-16X5/8 .31 OD AMK B11135 (10)
9414764-10-16X3/4 .31 O.D. AMK B-11136 (Cool
9414766-10-16X1.0 .31 O.D. AMK B-12225 (6)
9414767-10-16-X1 1/4 .31 O.D. AMK B-12227 (6)
9415464-P161 8-18X1/2 1/4AF .34 O.D. AMK B-13419 (12) B-13750 (40)
9416208-P47 8-18X3/4 .31 O.D. AMK Stainless & Chrome B-12124 (10) B-11524 (50) Note: Sill Plate Screws
9416822-10-16X1 1/4 .36 O.D. AMK B-12228 (6)
9417318-10-12X1 1/2 .36 O.D. AMK B-12229 (4)
9417706-P186
9417986-same as 9416208
9418359-P262 8-18X1/2 .31 O.D. AMK B-12153 (15)
9418551-P42 10-24X3/8 .44 Conical Glove Box Hinge 67/68 Phillips Head AMK B-10925 (3)
9419028-P127
9419107-P361 1/4-20X5/8 7/16AF .44 split Zinc AMK B-12303 (4)
9419234-P319 washer .41 X .73 X .06thk B-11281 (12)
9419301-P48 Hood Hinge to Hood but not Hood Hinge to Fender- 3/8-16X13/16 1" Conical AMK B-10835 (4)
9419303-P52/72/187 10-16X1/2 5/16AF .4 O.D. AMK B-12081 (10)
9419305-P92 10-16X1/2 5/16AF .4 O.D. AMK B-12081 (10)
9419326-P163
9419327-P's 43, 44 8-18X1/2 .31 O.D. AMK B-12152 (15)
9419329-P167 10-16X5/8 .37 O.D. AMK B-11530 (10)
9419328-P163 10-16X1/2 .37 O.D. AMK B-12192 (10)
9419370-P70/89 5/16-18X5/8 1/2AF .55 split AMK B-12312 (4) Phosp B-12313 (4) Zinc
9419380-P103/128/153 1/4-14X3/4 3/8AF .5 O.D. AMK B-11104 (25)
9419400-P366 1/4-14X1/2 3/8AF .5 O.D. B-12093 (Cool B-11400 (25)
9419402-P123 5/16-18X3/4 1/2AF .66 O.D. AMK B-12589 (6)
9419663-P163 8-18X1/2 1/4AF .34 O.D. AMK B-13419 (12) B-13750 (40) Note: AMK also has Stainless & zinc dichromate Same screw as 9415464 & 9426269
9419672-same as 9419327
9419778-P229
9420151-P153 1/4-14X3/4 3/8AF .5 O.D. AMK B-12102 (Cool Phosp B-12103 (Cool Zinc
9420415-P38/150/155/156/178 1/4-14X3/8 3/8AF .5 O.D. AMK B-11097 (Cool B-11099 (25) Orig. head markings 'D' (69 AIM pages-28, 155, 156, 161, 178, 182, 439, 440, 441, 460)
9420431-P156 10-24X1/2 5/16AF .4 O.D. Similar AMK B-10411 (Cool
9420494-P55
9420554-P153 8-18X1.0 .27 O.D. AMK B-11120 (10)
9420603-P62/113 5/16-18X3/4 1/2 AF .64 OD RBW (note-similar to 9780422 & used on Z-bar)
9420686-P229 8-18X5/8 1/4AF .34 O.D. AMK B-11076 (10)
9420721-P41 Same as 9423863 8-18X3/4 .31 O.D. Phillips Head Phosphate B-12170 (10) Zinc B-12171 (10)
9420723-P42 AMK N/A
9420825/3958062-P72/73 5/16-18X9/16 1/2AF .66 O.D. Brake & Fuel Line Clip AMK-Anchor B-10416 (4)
9420941-Battery Tray- 5/16-18X5/8 1.12 Conical AMK B-13716 (2)
9421137-P229 8-18x1/2 .31 O.D. AMK B-11144 (10)
9421479 P37 Zinc-Cowl Panel Screw 8-18X9/16 1/4 AF .62 Flat AMK B-12172 (4) Our originals were phosphate, but not the norm.
9421495-P46 10-16X1/2 .37 O.D. Outside Mirror AMK B-11223 (6)
9421851-P41/167 10-16X5/8 .44 Flat Washer AMK B-12231 (6)
9421934-P231
9422245-P45 Listed under AMK but not on page shown???
9422297-P320 Cad anchor nut 3/8-16 GR8 9/16 AF .33 thk AMK B-10526 (6)
9422455-P230
9422606-P72
9422641-P128 1/4-14X1.0 3/8AF .75Flat Note: our 68 had 1.0 Flat vs. .75" AMK B-11431 (5)
9422654-P41 Clip Nut #8 .44 X .62L AMK B12245 (Cool
9423258-P161 10-16x3/4 .31 O.D. AMK B-11137 (10) Note: 9425622 same screw
9423351-10-16X7/8 .31 O.D. AMK B-11138 (Cool
9423863-Same as 9420721 8-18X3/4 .31 O.D. Phillips Head AMK Phosphate B-12170 (10), Zinc B-12171 (10) 9424858-P188
9423909-P122
9424858-P55 10-16X3/4 .37 O.D. Similar AMK B-11157 (10) phosp B-12197 (10) Zinc
9425111-P42 AMK N/A
9425486-P170
9425578-P169
9425622-10-16x3/4 .31 O.D. AMK B-11137 (10) Note: 9423258 same screw
9425812-10-16X1 .36 O.D. AMK B-12226 (4)
4926269- see 9419663- 8-18X1/2 1/4AF .34 O.D. AMK B-13419 (12) B-13750 (40) Note: AMK also has Stainless & zinc dichromate
9426539-10-16X3.0 .31 O.D. AMK B-11139 Note: Used for 67 Camaro vent window
9427208-P44 Steering Arm Cover 67/68 8-32X7/16 .38 Conical AMK B-10848 (4)
9427326-P53
9428499-P229
9431963-Zinc/Ign.Coil Bracket- 5/16-18X5/8 5/8 external AMK 'RBW' B-13232 (4)
9432395-Trunk Latch/striker 1/4-20X5/8 .75 toothed AMK B-10891 (5)
9780422-Pages 137/141-145, 149, 153 5/16-18X3/4 .67OD AMK 'anchor' B-13306 (12) B-13307 (50) Heavy use-fender, header, valance, batt. tray, hood catch, etc..
9824833-Std. Arm-rest Base Screws 1/4-14X1 1/2 .45 OD AMK B-11163 (6)
9919303-P138
Door-Deluxe/Cutom Door Pull Straps 68/69 Camaro 1/4-14X1 7/16 .37 O.D. AMK B-11161 (4)
Door-Inside window hardware screws (correct) 1/4-20X7/16 7/16AF .55 O.D. AMK B-10427 (6)
License Plate Screws- AMK B-11179 (Cool
Seat Back Panel Screws 67-69 Camaro 8-18X3/4 .5 Flat washer AMK B-11222 (4)
Tailamp Housing Screw 67/68 Camaro 8-18X1/2 1/4AF .34 O.D. AMK B-11075 (12)
Wheel Opening Trim Screws- 8-18X7/16 AMK B-11532 (10) & B-10064 (32)
Bolts
0122017-P79
0122104-P152
0179868-P68
0180122-P79 3/8-16X1.0 9/16AF AMK B-10148 (4) Phosp B-10149 (4) Zinc
0180124-P79 3/8-16X1.25 9/16AF AMK B-10136 (4) Phosp B-10137 (4) Zinc
0186622-P126 3/8-16X1.25 9/16AF AMK B-11616 (4)
0191163-P79 3/8-16X4.0 9/16AF AMK B-10165 (1) Zinc
0385099-P127 5/16-18X5/8 1/2AF .75 Conical Similar AMK B-12548 (5)
0396712-P121 3/8-16X3.5 .8 O.D. AMK B-10074 (2) Note:thread end not correct
0839756-Flywheel 7/16-20x1.0 11/16AF AMK B-10191 (3) 3758783-P Battery hold down bolt with .87Dia captured washer
3790332-P62 5/16-18X6.5 9/16AF .34 Body Similar AMK B-10174 (2)
3817224-P94 'A' head marking AMK kit G4650 like originals except for bolt end chamfer
3892754-P66
3929905-P178 chrome 3/8-16X2.0 .75 O.D. AMK B-12755 (2)
6255899-P178/179 chrome 3/8-16X7/8 .75 O.D. AMK B-12751 (2) B-10887 (4)
9417950-P178
9418822-P81 See 180122 3/8-16X1.0 9/16AF
9418967-P79 3/8-16X3/4 9/16AF AMK B-10163 (2) Phosp B-10164 (2) Zinc
9419008-P103
9419073-P95 7/16-14X1.0 5/8AF AMK B-13682 (4)
9419101-P178 1/2-13X1.5 3/4AF AMK B-12590 (4)
9419713-P127 7/16-14X3.875 5/8AF Similar AMK B-10186 (1) B-10187 (2)
9421430-P59 1/2-13X3.75 3/4AF AMK B-13749 (2)
9424069-Caliper Brake Brackets 7/16-14X1.25 5/8AF AMK B-10184 (2)
9425299-P82
Clips
0125912-P73 Brake Line AMK B-10301 (4) cad.
3880723-P161
3881339-P73 Brake Line
3886521-P73 Brake Line
3886522-P73 Brake Line AMK B-10318 (1) Phosp
9422836-P161 AMK B-10588 (Cool
Nuts
0102646-P126 Tie Rod 7/16-20 5/8AF .38thk AMK B-10585 (2) Zinc
0120368-P152 5/16-24 GR5 1/2AF .27thk AMK B-11505 (10) Phosp B-12785 (10) Zinc
0121743-P156 Alt/relay junction 12-24 7/16AF .16thk AMK B-10502
0134530-P162
0134551-P168
0271172-P137/138 1/4-20 7/16AF .5 O.D. .24 OAH attached tooth washer B-12814 (Cool phosp B-13779 (Cool Zinc
0272876-P67/94 Casle Nut 7/16-20 11/16AF .37THK AMK B-10045 (4)
0359887-P118
0381700-P51/55/56 push type spring nut 5/32 stud .44 O.D. AMK B-10566 (15)
0445109-P163 spring nut #8-18 .41X.62 long AMK B-13370 (Cool
0445347-P51
1359889-P144
1378333-P127 flange nut 3/8-16 9/16AF .89 O.D. .4 thk AMK B-10475 (6)
3759924-P155 elect washer/nut 10-24 3/8AF .45 O.D. .19 OAH AMK B-13507 (Cool
3846854-P138
3849974-P153 headlamp housing spring nut #14 AMK B-12259 (6)
3899847-P153 headlamp bezel plastic nut AMK B-12914 (6)
3907444-P178/179 Plastic Push in (license plate) AMK B-12920 (Cool
3921446-P153 headlamp adjustment plastic push in AMK B-12923 (4)
9417954-P178 5/16-18 GR5 1/2AF .27thk AMK B-12782 (10) phosp B-12783 (10) Zinc
9418302-P144
9418828-P178 1/2-13 GR5 3/4AF .44thk AMK B-12797 (6)
9418931-P48/59/70/113 3/8-16 GR5 9/16AF .33 thk AMK B-12788 (Cool Phosp B-12789 (Cool Zinc
9419751-P139
9419753-P137/139 stamped nut 1/8 5/16AF .53 O.D. AMK B-10629 (10)
9419755--P154 stamped nut #10 3/8AF .5 O.D. AMK B-13383 (10)
9419841-P138 stamped nut 10-24 3/8AF .5 O.D. AMK B-10352 (10) Phosp
9419845-P52
9420171-P166
9420222-P153
9422654-P153 spring nut #8 AMK B-12245 (Cool
9425691-P178/179 conical nut 3/8-16 9/16AF 1.0 O.D. .46 OAH AMK B-12841 (4) B-11515 (12)
Lock Washers/P-Washers
0103319-P82/103
0103320-P178
0103321-P70/81 3/8 Regular lock washer
0103328-P95 7/16 Heavy .45X77 X.14THK AMK B-13058 (20)
0128144-P178
0135629-P42
0174916-P150 Toothed washer elect grounds 1/4 .26X.69 O.D. AMK B-11314 (Cool
0187119-P82 lock washer 5/16
1193463-P127 ,46X1.13X.19thk AMK B-11287 (3)
1362249-P178 53X1.24X.12thk AMK B-13073 (4)
3693853-P94 flat washer similar .47X.93X.09thk AMK B-11291 (12)
9419892-P103 flat washer .28X.62X.07thk AMK B-12989 (20) Phosp B-12990 (20) Zinc
Rivets
67/68 Grille & RS Mldg.3/16X.27LX.44O.D. Blk Annodized Alum. AMK B-13426 (Cool
9417761-P121 Drive Rivet to replace later service replacement gas cap screws. #6X5/16 .25 O.D. AMK B-10762 (10)
Wing Nuts/Clip Nuts/Special
0102634-P65 5/16-18 GR5 1/2AF .27THK AMK B-12782 (10) Phosp B-12783 (10) Zinc
0124829-P113/150 3/8-16 9/16AF .22THK AMK B-12787 (Cool Phosp B-10504(Cool Zinc
0273801-P89
0358501-P65 Lug Nut 7/16-20 3/4 AF .56 OAH AMK B-10010 (5) B-01545 (20)
0447143-P29 Detail #2 P Windshield Washer Nozzles AMK #B-11070 Zink Silver plating
1361640-P94
1365067-P68
3743360-P113 Bellcrank Felt AMK B-11303 (1)
3784845-P142/144 fender clip but nut not correct 5/16-18 .69WX1.0L AMK B-10616 (4)
3829086-P117
3841497-P319 Shifter linkage nut 7/16-20 9/16 AF .22Thk AMK B-10511 (4)
3868790-P40 Firewall Mat/Pad Rubber Plug AMK B-10672 (2) Can purchase as kit also
3886973-P39 washer nozzles
3892755-P66
3876130-P92 Volt. reg. 10-24 .37X.56L body .56 Flange O.D. AMK B12936 (3)
3899880-P145 fan shroud clip AMK B-10720 (2) Note: similar
3901399-P67 Springs&axle housing Nut 7/16-20 GR-8 11/16 AF .62 long AMK B-11508 (Cool
3916608-P132 Spare Tire J-hook AMK B11379 (1) Note: see 9785616 wing nut
4874119-P37 Cowl Panel Plug
7279805 Radio Shaft Nuts 7/16-20 9/16 AF .12 THK B-10556 (2)
9417614-P66 1/2-20 GR8 3/4 AF .44 thk AMK B-10499 (4) Phosp B-12801 (4) Zinc
9418699-P102
9419912-P103 Air Cleaner Nut 1/4-20 1.32 W AMIK B-10008 (1) Chrome
9422297-P79/81 nut 3/8-16 GR8 9/16 AF .33 THK AMK B-10526 (6) Cad
9422299-P59 nut 7/16-14 GR8 11/16 AF .38 THK AMK B-10533(4) Cad
9422301-P59 nut 1/2-13 GR8 3/4 AF .44 THK AMK B-10518 (4) Cad
9423518-P41
9785616-P132 Spare Tire Wing Nut AMK B-10612 (1) Note: see 3916608 J hook
Chick
68, 69, & 2015 Z/28's
69 Nova's L34 Father/Son & L78 Surv purch-new
67, 68, & 2015 Z06 Corvettes
Our 68Z Restoration
68camaroz28 is offline
post #6 of 23 (permalink) Old Jan 14th, 15, 07:25 PM Thread Starter
Dan
Chick,
I have read your post (well, most of it) and will do so again. I have 5 gal of Evapo-rust in my shop, so I am good there.
Your detail of everything you have done including the listing you have shared in your reply is very much appreciated.
I will take your advice and start my homework on the AMK products.
This car had to be completely dis-assembled due to it being in a cinder block building in the woods of west Virginia sweating for those 42 years. The only saving grace with this car is when the prior (original) owner parked it he put 7 gal (yes, 7 gals) of oil in the motor, the only internal part that rusted was the top of the push rods.
Thank you for all your info.
Dan
DDZ28 is offline
post #7 of 23 (permalink) Old Jan 14th, 15, 07:30 PM
Jake-68's rule
Thank you for sharing, Chick, nice list.
We shall see if we can make it a sticky here for other members' future reference.
Invaluable list!
Give a man a rescued dog for the health of both their souls.
'I wish the Dollar Store would sell gas. '
CUBS - 2016 World Series Champions
post #8 of 23 (permalink) Old Jan 15th, 15, 05:22 AM
Chick
Chick,
Dan
Dan, our 68Z came out of WV and was purchased at Roger Dean Chevrolet in Charleston. When you start reviewing some new hardware parts will stick out that don't match up to what you had. Some quick examples are sub-frame bolts due mainly to the machining to the ends which you see two of them when you pop the hood, and gas tank strap bolts! A good rule of thumb also is if it was a ground or ground related its clear (silver) zinc. I'm sure you have been around the horn on this stuff so again good luck and neat car.
Invaluable list!
Thanks Everett, that would be great!
Chick
Our 68Z Restoration
post #9 of 23 (permalink) Old Jan 15th, 15, 09:54 PM
J.R.
I live about 3 miles from where your car was purchased. Roger Dean Chevrolet use to be downtown Charleston, WV on the corner of Washington Street and Broad street. ( Zone 40 - Dealer #135 ) They started out as a Mopar dealership. I don't know when they were started but I remember family members saying that they had done business with them in the 40's and forward. I know that they were still selling Chryslers in 1961 due to a story about a Dr. Golden and Roger Dean himself. Dr. Goldman liked for his cars to be gold in color, due to last name I suppose. Anyway, he wanted to purchase a new Chrysler 300G and Chrysler didn't offer gold paint that year. Mr. Dean ordered the 300G fully loaded, but only sprayed in primer. When the dealership took possession of the car, their body shop painted the color gold on it. ) The dealership was sold in 1971 and was then called Tag Galyan Chevrolet, Tag was a nickname given to Tinsley A. Galyean and several years later, I think in the mid 80's was renamed Team Chevrolet. About 10 years ago the property was leveled and the property donated by the family to the city for the purpose of building The Clay Center, a performance arts center. If you do a google search for Tag Galyean Chevrolet, you will see a few photos from the past.
adjudimo is offline
post #10 of 23 (permalink) Old Jan 16th, 15, 06:47 AM
Charley
We want pics !!!
clill is offline
post #11 of 23 (permalink) Old Jan 16th, 15, 08:01 PM
Chick
Originally Posted by clill View Post
We want pics !!!
OK Charlie but you gotta add some too!
Here are pictures of what is commonly seen in 1st gen Camaro's sub-frame bolts made by RBW. When the hood is open the top of two sub-frame bolts threaded ends are quite obvious and the originals sharp point is unique.
The top bolt is an original used to attach the radiator support. Bottom bolt used for sub-frame
Right side bolt used for radiator support & AMK bolt exactly the same.
Believe James had posted this picture which I saved a few years back if memory serves me but it shows a 67 or 68 sub-frame bolt/washer configuration. Note the small diameter washer is clear (silver) zinc.
Chick
Our 68Z Restoration
post #12 of 23 (permalink) Old Jan 18th, 15, 02:24 AM
Garth
Re: Original hardware - See Post #2 & #5
Chick, I think you mislabeled that 3rd pic ? Top bolt is sub-frame, bottom radiator support....?
Garfields Maro is offline
post #13 of 23 (permalink) Old Jan 18th, 15, 08:56 PM
Chick
Yes Garth, the bottom bolt is for the radiator support and again the same Elco Industries "E" bolt is available thru AMK, i.e., same mfg. markings.
The other bolts that have a angled end that are incorrect on many restorations are the gas tank strap bolts. The two anchor bolts on the left from AMK are not technically correct compared to the two original RBW bolts on the right. If you have a friend with a lathe, chamfer the end to resemble originals and re-phosphate.
Chick
Our 68Z Restoration
post #14 of 23 (permalink) Old Jan 22nd, 15, 05:12 PM
Chick
Another thing that can help with finding stuff is a table of contents for a 68 Camaro. I got tired of trying to find stuff and went page by page to create a table of contents. Have a copy of this in front of my Assembly Instruction Manual. Hope it can help others! Also have a copy in my build thread.
1968 CAMARO FACTORY ASSEMBLY INSTUCTION MANUAL “AIM”
TABLE OF CONTENTS
UPC 0 - General Information
UPC 1 - Body and interior/exterior trim and hardware
UPC 2 - Frame
UPC 3 - Front suspension
UPC 4 - Rear suspension & prop shaft
UPC 5 - Brakes
UPC 6 - Engine
UPC 7 - Transmission & clutch
UPC 8 - Fuel & exhaust
UPC 9 - Steering
UPC 10 - Wheels & tires
UPC 11/13 - Front sheet metal, radiator & grille
UPC 12 - Electrical
UPC 14 - Bumpers & miscellaneous
396 Engine Related- Pages 272-290 & 298-303
4-Speed Trans Back-up Switch- Page 323
4-Speed Trans Shifter Adjustment- Page 321
4-Speed Trans Shifter Assy. to Trans. & Cross-Member-Page 320
4-Speed Trans Shifter Rods & Hardware-Page 318
4-Speed Trans Shifter Rods & Hardware Big Block-Page 319
4-Speed Trans Shifter Stabilizer Shafts (3 of them)-Page 320
Accelerator Pedal & Parts-Page 103
Accelerator to Carb-Page 105
Accelerator to Carb Linkage & Hardware Z/28-Page 441
Air Cleaner to Carb & Valve Covers Z28-Page 443
Alternator Brackets Z/28-Page 441
Alternator Mounting-Page 79
Axle U-bolts-Page 243
Battery & Battery Cables-Page 151
Battery Tray-Page 149
Brake Line & Emergency Brake Brackets-Page 243
Brake Line-Front-Page 72
Brake Line-Rear-Page 73
Brake Pedal-Page 71
Brake Pedal Stop Lamp-Page 166
Brake-Master Cylinder, Brkt., & Pressure Indicator Switch-Page 70
Bumper Front/Rear Assy-Page 178/179
Bumper Guards Front & Rear-Page 419
Carpet-front-Page 47
Cigarette Lighter-Page 165
Clip closure-non hardened steel-Page 5
Clutch Linkage Adjustments-Page 114
Clutch Pedal & Linkage-Page 112
Clutch Release Bearing-Page 111
Clutch Shaft & Push Rod-Page 113
Console-Floor Assy-Page 229-231
Console Gauges-Page 385
Console Oil Gauge Line Routing-Page 386
Control Arms-Page 59
Cotter Pin Install Instructions-Page 5
Cowl Panel Piercing-Page 9/10
Cowl Seal-Page 136
Cowl Vent Grille-Page 37
Dash Trim Plate-Page 44
Dash Insulator Pad/Mat-Page 40
Defroster Ducts-Page 53
Disc Brakes-Front-Page 247
Dual Exhaust & Muffler-Page 360-367
Engine Mounts to Sub-Frame & Engine-Page 94
Exhaust Muffler & Hangers-Page 119
Exhaust Pipe (rear) & Hangers-Page 118
Fan Shroud & Radiator-Page 145
Fender Assy-Page 135
Fender Emblems-Page 139
Fender Extension to Fender & Valance-Page 143
Fuel Pump-Page 99
Fuse Panel-Page 160
Gas Cap Assy & fit up note-Page 121
Gas Gauge Metering & Rear Hose-Page 124
Gas Line & Clips-Page 123
Gas Tank Filler Neck (lower) & Cover-Page 122
Gas Tank Mtg. & Straps-Page 121
Glove Box Assy-Page 41/42
Grille-upper, lower, center & emblem-Page 138
Header Panel-Page 137
Headlamp-Page 153
Headlight Switch-Page 165
Headlight Dimmer Switch-Page 166
Heater Control Assy-Page 55
Heater Control Cables-Page 56
Heater/Defroster Assy-Page 52
Heater Fan, Blower Assy/Cowl-Page 52
Hood Catch, Support, & Latch Assy-Page 144
Hood Hinge-Page 136
Hood Insulation & Retainers-Page 448
Horn Relay-Page 155
Hub Assy-Page 60
Ignition Switch-Page 92
Inner Fender Mtg-Page 141
Inner Fender Seals-Page 140
Instrument Cluster/Instrument Cluster Lighting-Page 161/162
Instrument Panel Wiring Harness-Page 163/164
JL8 Brakes-Page 243
Leaf Spring to Front Bracket/Leaf Spring to Axle & Rear Shackle-Page 66/67
Master Cylinder Assy & Balance Valve-Page 248
Mirror-Rear View-Page 44
Mirror-LH Door-Page 40
Motor Mounts-Page 94
Nut install that are open end type stamped 'MB'-Page 5 Oil Pressure Console Gauge Engine Block Fitting-U17 A3 Page 386
Parking Brake Alarm-Page 168
Parking Brake Connector & Rear Cables-Page 75
Parking Brake Pedal-Page 74
Parking Lamp-Page 153
PCV & Hose Z28-Page 443
Pedal Trim Plates-Page 438
Power Brake Assy @ Cowl-Page 245
Power Steering-Page 373-379
Radiator support to fender & fender support rods-Page 142
Radiator & Clutch Fan-Page 256
Radiator & fan shroud-Page 145
Radio Antenna-Front-Page 410
Radio Capacitors-Page 406
Radio Ground Straps V8-Page 408 Radio Receiver & Front Speaker U63 A2 Page 404 Radio Speaker U80 A2 Page 416/7
Rag Joint Assembly & Caution-Page 129/130
Rear License Lamp-Page 172
Rocker Panel Sill Molding Spears-Page 45
RS Related-Page 423-437
Sheet metal gaps-Page 146-147
Shock Absorber-Front-Page 61
Shock Absorber-Rear-Page 68
Side Marker Lamps-Fender-Page 154
Smog Pump Z28-Page 442
Spare Tire & Jack Storage-Page 132
Speedometer Cable 4-speed-Page 241/322
SS Hood & Emblems-Page 294
SS Paint Stripes-Page 295
Starter Motor Mtg.-Page 89
Steering Box to Column Assy-Page 127
Steering Column Bolt-up-Page 44
Steering Column to Dash Seal-Page 128
Steering Column Mandatory Install Sequence-Page 130
Steering Wheel assy Sequence-Page 129
Sub-Frame Body Mounts-Page 50
Sway Bar & Links-Page 62
Tic-Toc-Tach-Page 384
Tie Rod Assy-Page 126
Transmission 4-speed Cross-member Mount-Page 95
Valance to fender & fender extension-Page 143
Ventilation System/Dash-Page 51
Voltage Regulator-Page 92
Windshield Motor Switch-Page 42
Chick
Our 68Z Restoration
post #15 of 23 (permalink) Old Feb 1st, 15, 08:05 PM
Nick
Rarerat's Avatar
Nice work Chick.
Rarerat is offline
Human Verification
