Horseshoe shifter location - Team Camaro Tech
Restoration Corner Where originality comes first
post #1 of 5 (permalink) Old Mar 19th, 17, 03:30 PM Thread Starter
Roger
CarAddict's Avatar
I did a lot of searching, but couldn't come up with the answer.
I am installing the Horseshoe shifter in my car. New floor--no dimples. I think I have it in the right location, but it is not centered in the car. Its 5/8 inch closer to the drivers side, measured with no interior to the metal on the door. It would make sense if it is supposed to be. Just want to make sure I am Correct before I start the console locating. Shifter would be easy to move if I need to.
If someone can check their shifter, or console and let me know if theirs is centered in the car, I would appreciate it.
CarAddict is offline
post #2 of 5 (permalink) Old Mar 19th, 17, 05:32 PM
Jake
697ibew's Avatar
I had the same problem as you. I used both of the drawings below to lay it out and test fitted it with the center console before drilling any holes.
https://www.dropbox.com/s/28st0lfnsg...81%29.jpg?dl=0
https://www.dropbox.com/s/kkmrm9gex3...on%29.jpg?dl=0
Last edited by 69-Pace; Mar 19th, 17 at 06:26 PM. Reason: Fixed photo links to embed
697ibew is offline
post #3 of 5 (permalink) Old Mar 19th, 17, 06:01 PM
69-Pace's Avatar
Re: Horseshoe shifter location
Your signature has no details on your ride - year, options etc so going to assume 1969.
Not sure I have an automatic template in the library yet but Dean Guccione has some decent pictures on his restoration build site from ten years ago 1969 L-78 Big Block Project Camaro
The AIM is not so helpful as it says mount on the tunnel using the existing dimples. I harvested a few photos from old threads here and at CRG below. Maybe one will get you the info you need but I suspect we need someone to give us measured drawings and a template in order to add it to the reference library since most of the photos in old threads are dead links to off shore photo shares.
ID:	178538   Click image for larger version
ID:	178545   Click image for larger version
Name:	1969 AIM M35 A8 page 338.jpg
ID:	178553   Click image for larger version
Name:	stirrup shifter image1.jpg
Name:	factory trans tunnel dimples.jpg
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 5 (permalink) Old Mar 19th, 17, 06:56 PM Thread Starter
Roger
CarAddict's Avatar
Thank you both.
This will help me very much
post #5 of 5 (permalink) Old Mar 20th, 17, 05:39 AM
Jake
697ibew's Avatar
Sorry Brian...my car is a 68 Convertible. I will upload my attachments from my dropbox account to this site so that the links won't be broken in the future. I'm sure i have more pics of my install as well but will have to look for them.
Jake
697ibew is offline
Human Verification
