69 Z28/SS shifter - Team Camaro Tech
Restoration Corner Where originality comes first
post #1 of 12 (permalink) Old Nov 20th, 05, 09:53 PM Thread Starter
69 Z28/SS shifter
Is the hurst shifter on a 69 Z28 the same as a 69 SS car ?Is there a date code on shifter and are console shifters the same as nonconsole shifters?
Lukes 69 z28 is offline
post #2 of 12 (permalink) Old Nov 20th, 05, 10:09 PM
Doug
Re: 69 Z28/SS shifter
Luke,
Yes, yes and yes.
Doug
1969 Van Nuys RS Z/28. Protect-o-plate and chassis broadcast copy. Hugger Orange, original 711 interior, including carpet. Original drivetrain: DZ, M-20, 3:73 BO code peg leg. Flat hood, no spoilers.
z28doug is offline
post #3 of 12 (permalink) Old Nov 20th, 05, 10:43 PM Thread Starter
How and were are shifters dated ? Can you give me an example?
post #4 of 12 (permalink) Old Nov 21st, 05, 06:12 AM
Chuck
chuck69ss's Avatar
Not sure about the date codes and such but I have some pics for reference if it helps.
http://chuckbro.smugmug.com/gallery/612834/1/25938226
Chuck B
RI
- Frost Grn, x11, 350 4bbl, COMPCam XE256H, Crane XR-i HEI, M20, posi, Flowmaster 2.5";
You can live in your car, but you can't drive your house.
chuck69ss is offline
post #5 of 12 (permalink) Old Nov 22nd, 05, 09:42 PM Thread Starter
Thanks chuck for the pics...
post #6 of 12 (permalink) Old Nov 23rd, 05, 11:20 AM
William's Avatar
Careful here.
All 1969 Camaro 4-speed shifter mechanisms are the same. That is the assembly with chrome handle as shown in the photo.
On the assembly line there were 3 application possibilities for a shifter each with its own unique hardware consisting of mounting plate, linkage rods, levers, upper & lower column lock rods and swivel.
Saginaw: upper column lock rod and swivel same as 3-speed & all auto, all else Saginaw only
Muncie small-block: lower lock rod, mounting plate and linkage rods are sb only. Levers, swivel & upper lock rod Muncie only.
Muncie big-block: lower lock rod, mounting plate and linkage rods are bb
only. Levers, swivel & upper lock rod same as sb Muncie.
Many people believe there were different chrome handles with or without console. There is no reason to believe that. There is a vitually identical chrome handle that is about 1" taller, maybe for Firebird. Firebird may also share some of the other pieces.
Now you know why complete bb '69 shifters bring crushing prices.
William is offline
post #7 of 12 (permalink) Old Nov 24th, 05, 12:33 AM
Doug
I need to modify my first reply. Yes, yes and yes as long as the '69 SS car had a Muncie and a small block.
The numbers on my shifter unit in my 02C built Van Nuys Z are:
19D51C and 3138
Not sure how to de-code.
Doug
z28doug is offline
post #8 of 12 (permalink) Old Nov 24th, 05, 09:31 PM
joe
Send a message via AIM to zbo2
my 7A Z is:
39D21C and 3138
Joe
69 Z-28 Fathom Green />93 Z-28 Pace Car/>86 Corvette...Red
zbo2 is offline
post #9 of 12 (permalink) Old Nov 25th, 05, 04:19 PM
joe
On the 69 Camaro Hurst shifters I think the first number is the month and the second number is the year. 68 and 69 Firebird used the same shifter body and lever but Pontiac used less digits in their ID code. I posted a bunch of 69 Hurst shifter numbers on a thread in the tag team section awile back. You may still be able to find the thread in a search.
JOE58 is offline
post #10 of 12 (permalink) Old Nov 25th, 05, 09:20 PM
Gary
I've got a friend who is very knowledgeable regarding 69s. He claims that not only are non-console shifters a little taller, but they also angle toward the driver side a little more. He has shown me a couple he thinks are original. However, I have never seen anything in the AIM or anywhere else to back this up.
I have not proof, but I agree with William....they're the same.
Unreal is offline
post #11 of 12 (permalink) Old Nov 26th, 05, 07:16 AM
joe
The Hurst stick has a part number on the end that is pressed into the shifter body so the handle has to be removed to read it. There are many different Hurst round handle sticks but I have only seen one number used for the 69 Camaro all applications. I have seen some handles that appear to be a different shape because people bend them to fit an incorrect installation or because the incorrect shifter mount plate was used. It is best to check by the number.
JOE58 is offline
post #12 of 12 (permalink) Old Nov 26th, 05, 07:20 AM
Chuck
Send a message via AIM to ChuckD Send a message via MSN to ChuckD
Hey guys....my shifter also shows a code, 19D510. Not sure if it's a date code or supplier code. The AIM and the Parts and Service book show only one "Lever and Bracket Assy" for all 4 speed 69's. This tells me they are all the same, 69's anyway.
69 Z-28,all original(darn near!), Date correct DZ-spec motor, -186 heads, 30-30 Crane, 1178 crank, and 11:1 hyper-eutectic pistons, stainless valves, original manifolds and carb, with smog. #'s trans and rear. Bling-free.
ChuckD is offline
Human Verification
