1970 Z28 with 01C cowl tag, V0206CTB Stamp Original! - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Dec 21st, 07, 10:44 PM   #1 (permalink)
I know that all 69 Z28,s made in June had 06A cowl tags, but the other day I saw a 70 Z28 with bullit proof documentation that had a 01C cowl tag and the block was cast A-27-0, and the pad was V0206CTB and original with factory broach marks and the vin down by the filter.
What gives? Was there a problem with cowl tags in 70 production?
Any One know?
2002 Jerry Bickle Cavalier, 446" Small Block, Brodix Canted Valve, lenco 5 speed, 7.54 @ 180. mph,1.06 60', 2235 lbs for 2014. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973.
rszmjt is offline   Reply With Quote Quick reply to this message
Old Dec 22nd, 07, 03:42 PM   #2 (permalink)
Re: 1970 Z28 with 01C cowl tag, V0206CTB Stamp Original!
What's the VIN? My 70 L78 car is an 01C car as well and my motor is a late October 69 engine. It's hard to compare because my motor was shared with the Novas and Chevelles. The 70 LT1 motor was new and used on the Camaros and Corvettes only so they may have been behind on production due to the delay. I would want to see some good paperwork explaining why that happened. Was it a Canadian car? If so, the GM of Canada paperwork should show the date the car was delivered. If it was delivered before the motor was built then it's a restamp.
Jeff H
69 Z28 Hugger Orange original factory JL8 brakes, being restored
09 Z71 daily beater
Jeff H is offline   Reply With Quote Quick reply to this message
Old Dec 23rd, 07, 09:46 AM   #3 (permalink)
I have seen the documentation and like I said it is Bullit Proof, Original Protecto Plate with signed documentation from a commisioner of oaths, lots of original paperwork including original dealer invoice etc. The dealer invoice shows the car being sold in Mar/70. No it is not a Canadian car. The pad is original for sure as is the block vin stamp by the filter.
It puzzles me as to why a car would have a engine cast and stamped after the cowl tag production date. That is why I was wondering if GM had a abundance of 01C cowl tags in 1970 or if there was some cars held back for some reason?
Could GM have screwed up the cowl Tag? Maybe it should have been 02C?
Old Dec 24th, 07, 07:50 PM   #4 (permalink)
That's what I was thinking, maybe it's supposed to be an 02C car. My L78 VIN is 5022xx dated 01C and the shipping date was Jan 27, 1970. If the car you're talking about has a VIN close to mine then it probably is an 01C car. My 01C trim tag is a little odd with the date stamping line off to the left of where it should be. The L78 is also off center as well. Maybe they had problem with the early 1970 Camaros with the trim tag stampings.
Jeff H
09 Z71 daily beater
Old Dec 25th, 07, 04:58 PM   #5 (permalink)
Jeff, I will have to check the vin and see what it is compared to yours and get back to you.
Interestingly the L78 car I emailed you about has the L78 off centre as well. It is a 05E car. Another friend I do work for has a 70 Z28 also a 05E car ( 200 vin numbers off the 05E-L78 car ) and the Z28 is stamped off centre to the left as you describe with the L78 tag, Maybe there was a problem with the trim tag suppliers after all?
Old Dec 29th, 07, 10:12 AM   #6 (permalink)
I never really thought too much about when and where the tags were stamped. I guess with the NOR # being assigned at the time it was possibly done when the order was accepted. Or would the trim tag be stamped at the actual assembly plant as they prepared to build the cars.
Jeff H
09 Z71 daily beater
Old Dec 29th, 07, 11:19 AM   #7 (permalink)
If you want more expereinced opinions, this subject should be brought to the ORIGINAL Forum at www.nastyz28.com.
I have never heard or seen this myself. As someone who has experience and judges 2nd Gen Camaros at Carlisle, I would want to see EVERYTHING, before I draw a conclusion.
Was a "mistake" possible.....YES. Was it probable???? ........... NO!!!! Having said that curious minds would like to know.......
Chuck Sharin
Seattle area
69 COPO recreation (Day 2)
70 Z-28
70 L-78
70 SS R/S
73 RS LT
CamarosRus is offline   Reply With Quote Quick reply to this message
Old Dec 29th, 07, 01:54 PM   #8 (permalink)
My 70Z is a 03A 28.10 (March 1st Week 1970) Norwood Canadian car. Unfortunately when I bought it, in the mid 70’s, it had a L78 from what I guess came out of a 66 Vette as the rear cam journal was Grooved Rear and had a Canister Oil Filter; SO, I can’t comment about the time issues between the 360 Hp LT1 and production date on the cowl regarding my car, other then remind you that GM did have a ½ year production delay introducing the 70 Camaro. The engine of the 70Z was shared ONLY with the Vette, not a Chevelle or Nova or any other GM product. The answer may lie somewhere in the possibility of a similar discrepancy in the 70 Vette tagging. I do recall a similar discussion years ago (say 1980) when I considered finding a suitable LT1 for my car and a friend of mine who is very knowledgeable said to me that the Tag #’s of a 70Z could be out as much as 2 or 3 months either way. This is the first time I’ve heard a similar discussion. These cars are getting very rare and the records are not accurate especially for the 70Z. Because GM was scraping Hi Hp Big Blocks like the LS6, the 360 Hp Solid Lifter LT1 was grabbed for by both the Camaro and Vette production lines. GM actually over bored older 396 castings rusting in the warehouses to put in the Camaro, hence the 402.
The stampings on my Tag are very well centered with a constant Font.
One thing I have found different between 70 Camaros is the size of the Ball Joints. Mine are the larger ones as used in the 69 Chevelle, where as later models NOT Z’s of that year have smaller ball joints; then again, I’ve yet to get my hands on another 70Z to compare mine to. I believe the 70 Sub Frame is specific perhaps 2 specfic - LOL
This was my 70 1/2 Z28
Z15CAM is offline   Reply With Quote Quick reply to this message
Old Dec 31st, 07, 07:34 PM   #9 (permalink)
Jeff,
The car in question is 506XXX, so maybe the V0206CTB is correct. Wonder why it has a 01C cowl tag?
Any body know the monthly vin ranges for Jan and Feb of 1970?
Old Jan 20th, 13, 02:12 PM   #10 (permalink)
I know this post is 5 years old but I was just linked to this discussion from a post on NastyZ28 and thought I would add to it... and my 1st official post here!
It's a known fact on some 2nd gen Camaro's, especially Z28's, to have an engine installed in a car body that started production before or at the same time the engine was built. It's possible for the motor to be at the Norwood assembly plant the day after it was built as delivery time by train was only 1 day away.
For those interested, here's a link to a previous disscussion.
http://www.nastyz28.com/forum/showth...+vs+build+date
1970 SS L78, Classic Copper W/Saddle Interior, 4-speed & 4:10's. Frame-off restoration.
See photos of car & restoration here....
MN 70L78 is offline   Reply With Quote Quick reply to this message
Old Jan 21st, 13, 11:37 AM   #11 (permalink)
If there was a problem with the car, and it came off the line for one reason or another it is possible for the engine could be after the trim tag date. Does the protect-o-plate list the same stamp?
x77-69z28 is offline   Reply With Quote Quick reply to this message
Old Jan 21st, 13, 05:47 PM   #12 (permalink)
i know its an old thread but , i worked at a gmad plant starting in 1980 . the cowl tag went on the under body or the beginning of the line . if the body got severely damaged it would either be fixed at the end of the body line ( most likely scenario ) or sent to salvage to be dismantled . believe me Ive seen some cars get pretty damaged on the body shop line . they would have to come off the line to be fixed it usually didn't take a week to fix but this is an early production car after a complete model change , so who knows .
twozs is offline   Reply With Quote Quick reply to this message
Old Jan 24th, 13, 08:21 PM   #13 (permalink)
Maybe it has something to do with production delays at the body plant. Check the sheet metal date codes,especially the rear quarters if they are original. If the tag was made way earlier then the car and was awaiting a body to be put on,it may explain a lot. Compare the weeks that the rear quarters were stamped to the weeks that the rear speaker deck,inner A-pillars,outer rockers and floor braces were stamped. The quarter panel stampings were what delayed production and might be dated a bit later then the rest of the panels.
RichSchmidt is offline   Reply With Quote Quick reply to this message
Old Jan 25th, 13, 10:17 PM   #14 (permalink)
i actually read this post and its NOT a known fact . , my 73 is a week ( motor is a ...the motor was allways built before the body .... it had to be shipped to an assembly plant back then . it was a train from Flint MI or Tonawanda NY to Norwood OH or Van Nuys CA . mine took the short ride from Flint to Norwood . do you have picts of the date code on the block and the engine stamp on the head surface .
Old Jan 26th, 13, 09:05 PM   #15 (permalink)
I did not know that all June built cars where stamped 06A. What about July built cars?
6667ss138 is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
Human Verification
» Recent Discussions
low fuel light test
Feb 18th, 17 06:32 PM
by schnide
Last post by schnide
Today 04:02 PM
4 Replies, 162 Views
Gear Ratio?
Yesterday 10:16 AM
by smwdrum
Last post by Andrew69
Today 03:52 PM
27 Replies, 495 Views
68 Deluxe Seats...
Today 03:41 PM
Last post by VitaminC
Today 03:41 PM
0 Replies, 17 Views
'68 "Restore as I Drive"...
Apr 21st, 14 04:41 AM
Last post by 69TAPoser
Today 03:36 PM
1 Replies, 82,753 Views
My 15 minutes of fame...
Feb 14th, 17 05:12 PM
by zuma
Last post by jr68
Today 03:17 PM
12 Replies, 356 Views
Ride Of The Month - Home...
Apr 9th, 16 08:27 PM
by 69-Pace
Last post by 69-Pace
Today 03:04 PM
16 Replies, 1,572 Views
LS3 480 / Tremec Magnum...
Feb 17th, 17 02:47 PM
by ttwo
Last post by ttwo
Today 12:36 PM
8 Replies, 255 Views
Good Guys - Pleasanton
Today 09:14 AM
Last post by rogerh
Today 12:34 PM
1 Replies, 85 Views
Chevrolet Camaro ZL1...
Today 12:09 PM
Last post by AutoGuide.com
Today 12:09 PM
0 Replies, 74 Views
'68 Correct vacuum line...
Yesterday 11:54 PM
Last post by COPO
Today 12:09 PM
6 Replies, 163 Views
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
