Intakes And Hood Clearance - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Jul 2nd, 11, 11:18 AM   #1 (permalink)
Has anyone used the Edelbrock Performer RPM Air Gap or the slightly shorter Performer Air Gap intake on a 1970 Camaro? I was thinking of using one of these but was not sure of hood clearance even with a low profile air cleaner.
Any advise would be helpful....Thanks.
Tripper is offline   Reply With Quote Quick reply to this message
Old Jul 2nd, 11, 02:56 PM   #2 (permalink)
Re: Intakes And Hood Clearance
For one thing the Edelbrock Dual Plain Air Gap is the Same Height as a Performer-2 & RPM, You can check the Edelbrock Site to verify the Height.
Generally you require a Drop Base Carb Plate (Say a Morrosso Drop Plate) topped with a LT1 Scoop to run a 4" Air Breather in a 2nd Gen with a BBC/Holley/RPM - A 4" Breather will not clear the Hood with a BBC and Edelbrock Intake in a 2nd Gen even with a Drop Base unless you use a 3" Filter - Don't know about SBC's in a 2nd Gen - Never ran one - But a SBC over Air Gap should clear with a 3`Filter & Drop base Morrosso Plate.
There`s a Garbage Can Tin Lid in there for a Total Seal Cowl Induction:
See the Dodge Air Breather Puke Can on the PSGR Valve Cover to a Base Morrosso Carb Plate and the Dodge Heater Hose Bracket bolted to the Alternator. I`m Not Proud - Holley Annular Booster 80511-1-Edelbrock Dual Plain RPM Air Gap in Chevy Color - Almost looks Stock even with the Volvo S70 Electric Fan - LOL.
10.25:1, 7000rpm, 625Hp, Donovan Cam Gear Drive, Lunati SR 73 MKIV LS4-M21-3.31 12 Bolt Posi - 70Z
Just to show it`s a 7000rpm 460-M21 & 3.31 Gears.
Note: I just Bolt on the LT1. GM provided the Hood Sub-Frame Structure.
Believe me the Mill is not Cheap and you have to know what your doing - I`m the Mechanic & don`t trust anyone to Wrench my Ride.
She`s a 12 Sec 150+mph Road Warrior on pump gas and, over time, have owned it since 76 treating her with my personality.
Eat your heart out Baldwin & Nicky - I did it the way the General intended a 2nd Gen Z to be.
Hope my Post gives you some Idea about Cowl Induction - Be Creative - That`s GM`s Theme about 2nd Gens.
This was my 70 1/2 Z28
Z15CAM is offline   Reply With Quote Quick reply to this message
Old Jul 2nd, 11, 04:39 PM   #3 (permalink)
Z28 Mark's Avatar
Post Re: Intakes And Hood Clearance
I have a 73 Z28 w/ an Edelbrock Performer RPM Air Gap on a SBC 350- small Holley Carb and a Cowl Induction type are cleaner and I have to run a GoodMark Cowl Induction Hood also. The air cleaner cowl "ring" w/ gasket just fits w/o any damage to the hood. I still think the Air Gap is taller than a std. Performer intake-JMO.
Mark (AKA Z28 Mark)
1973 Z28 2001 Z28
Camaros Limited~Nor Cal
Z28 Mark is offline   Reply With Quote Quick reply to this message
Old Jul 2nd, 11, 04:58 PM   #4 (permalink)
Tripper: For a BBC it`s not any taller then a Performer-2 - Don't Know about SBC's - Check the Edelbrock Site Specs. I`ve taken the time to tell members how to build one with a BBC.
We don`t know if he`s running a SBC or BBC - Sish!
Old Jul 3rd, 11, 10:10 AM   #5 (permalink)
Sorry I was in a bit of a rush when I posted my question...Yes, this is a SB car..350.
I have been getting some say yes the RPM Air Gap will fit under the hood with room to spare and others sayin it won't with the carb I will be using which is a Holley 670 cfm Street Avenger with an electric choke.
Old Jul 10th, 11, 07:41 AM   #6 (permalink)
Beyond the factory low rise intake, none of the aftermarket intakes will clear the stock height hood on a 2nd gen Camaro with a BBC. The low rise and factory air cleaner cleared fine.
My '71 came stock with a BBC and the low rise cast iron intake. Once I decided to change to a aftermarket intake I found that no air cleaner/intake option would clear the stock hood, and finally gave up and went to the cowl hood.
The SBC 2nd Gens have a lot of clearance, and easily clear with the right dropped base air cleaner.
1971 SS427 Camaro. 2nd owner since 1973!
1971BB427 is offline   Reply With Quote Quick reply to this message
Old Nov 25th, 16, 06:54 PM   #7 (permalink)
Hi thanks for the info. I see you said you had to use a raised cowl hood. Did you opt for a 2" rise or the 4" rise. My 71 Cam has a 454 (short block not the tall block) Edelbrock 2.0 performer intake with a small thin adapter to allow the use of a QuickFuel square bore. When I bought the car the intake was removed their intention was to install a Weiand Team G high rise intake with a 1000 cfm Holly Dominator new parts which came with the car. SO, my question is: What size raise on the hood do I need to fit the Edelbrock QuickFuel combo, will the 2 inch rise be enough for the Team G high rise with the 750 cfm QuickFuel carb. The 71 Cam came with a fiberglass 4" rise cowl induction hood lift off. Cons I don't like the height of the hood. To me the huge hood rise takes away from the original beautiful flowing body lines. Also there are 6 hood locks to hold the hood down. What if there is a fire in the engine compartment. By the time I got the hood off, the car could be burned down to the ground. So do you think a 2 inch rise metal hood work with the Eldebrock combo and the Team G manifold combo. Thanks much for any help you can offer.
Burgundy is offline   Reply With Quote Quick reply to this message
Old Nov 26th, 16, 05:45 PM   #8 (permalink)
BonzoHansen's Avatar
In my 77 I have a sbc with an rpm non-air gap with a drop base air cleaner under a flat hood. Check the edelbrock site for measurements but i think the air gap is the same height.
TC Member #13
BonzoHansen is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
Human Verification
» Recent Discussions
I am looking for some...
Today 08:58 AM
Last post by dhutton
Today 09:55 AM
1 Replies, 49 Views
Project Meteor
Mar 22nd, 17 12:05 PM
by 68GK327
Last post by 67Rally
Today 09:55 AM
11 Replies, 281 Views
Spin on oil filter to...
Yesterday 07:21 PM
by Coach62
Last post by dave ray
Today 09:55 AM
9 Replies, 163 Views
Epoxy vs. Self Etch for...
Yesterday 11:51 AM
by rp0029
Last post by DT
Today 09:40 AM
7 Replies, 220 Views
Rear driver side drum...
Mar 22nd, 17 02:43 PM
Last post by allanjs
Today 09:01 AM
16 Replies, 407 Views
67 Rally Sport...needs...
Feb 11th, 10 08:46 AM
by 67Rally
Today 08:54 AM
1 Replies, 280,241 Views
Project "Its about...
Dec 7th, 16 08:42 AM
by ktrim
Last post by ktrim
Today 08:12 AM
54 Replies, 2,564 Views
Console question
Mar 10th, 17 01:09 PM
Last post by Grinder67
Today 07:38 AM
4 Replies, 262 Views
'68 Corvette Bronze...
Mar 18th, 17 05:35 AM
by RPOL72
Last post by Everett#2390
Today 07:05 AM
18 Replies, 746 Views
Overheating problem
Mar 19th, 17 05:31 PM
Last post by arocars
Today 06:49 AM
8 Replies, 238 Views
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
