71 Camaro wiper problem - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
LinkBack Thread Tools
Old Dec 29th, 12, 08:06 AM   #1 (permalink)
i have a 71 camaro with aftermarket cowl,wipers do not work.understand there is 2 different style motors and i have the non hidden style motor so probably have to switch this out but wanted to know if wiper linkage was different.the current motor hooks up to the linkage but wipers don't work. if i diconnect the linkage the motor runs but has no power i can stop it from turning with a pair of pliers.
alt66 is offline   Reply With Quote Quick reply to this message
Old Dec 29th, 12, 01:44 PM   #2 (permalink)
dzs
Re: 71 camaro wiper problem
make sure it is grounded it grounds to the firewall i had to scrape some paint off to get a good ground
dzs is offline   Reply With Quote Quick reply to this message
Old Dec 29th, 12, 05:57 PM   #3 (permalink)
thanks i'll double check that
Old Dec 30th, 12, 11:03 AM   #4 (permalink)
yellow69RS's Avatar
Re: 71 Camaro wiper problem
If I recall the difference in the motors is Depressed park. Not real sure how to explain it, but the standard wipers basically just stop at the bottom of the windshield. The depressed park stop at the bottom and the gear rotates further to retract the wipers under the cowl. I don't know if the linkage is different but I rather doubt it.
Jeff
yellow69RS is offline   Reply With Quote Quick reply to this message
Old Dec 30th, 12, 02:03 PM   #5 (permalink)
thanks
Old Dec 30th, 12, 02:16 PM   #6 (permalink)
1
twozs is offline   Reply With Quote Quick reply to this message
Old Dec 31st, 12, 02:31 PM   #7 (permalink)
Jeff
Yeah,the linkage,motor,and arms are different for standard and hideaway.
The motor is the barrel shaped one for hideaway(regular is square)
The linkage is also different(recognizable visually by three bolts bolting the wiper pegs on,for hideaway,as opposed to two,for standard.)
And the (one?)wiper arm has an additional added sub arm(for hideaway)to it.So,instead of a one piece wiper arm,its two piece.
And lastly,lol,for the early years(70-73),there is an addition mounting plate(hideaway)that goes in between the motor and firewall.
72LS3Z27 is offline   Reply With Quote Quick reply to this message
Old Jan 2nd, 13, 07:23 AM   #8 (permalink)
thanks for the info i do have the standard setup on it
Location
Location
First Name
Human Verification
» Recent Discussions
what brand paint will...
Yesterday 08:50 PM
Last post by bill3337
Today 04:52 PM
14 Replies, 273 Views
Canadian documented 68SS...
Yesterday 12:46 PM
by JJW68
Last post by JJW68
Today 04:48 PM
21 Replies, 475 Views
Ignition noise on the...
Feb 4th, 02 05:37 PM
Last post by SOA-Nova
Today 04:46 PM
21 Replies, 1,233 Views
14" hub caps
Today 04:35 PM
Last post by bertfam
Today 04:46 PM
1 Replies, 10 Views
low fuel light test
Feb 18th, 17 06:32 PM
by schnide
Today 04:39 PM
14 Replies, 373 Views
69 Quarters installation...
Today 04:11 PM
Last post by gmbuilder
Today 04:23 PM
1 Replies, 16 Views
Distributor
Today 01:38 PM
Last post by Mauimax3
Today 03:56 PM
6 Replies, 98 Views
Oil to the top side...
Yesterday 10:40 AM
Last post by zdld17
Today 03:47 PM
13 Replies, 273 Views
Cardone IROC steering...
Yesterday 07:15 PM
Last post by zdld17
Today 03:41 PM
6 Replies, 173 Views
JohnZ over at CRG :(
Dec 13th, 16 01:40 PM
by click
Last post by nashcar
Today 01:51 PM
34 Replies, 2,542 Views
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
