95 Camaro Problems, HELP !!! - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Jul 30th, 07, 06:50 PM   #1 (permalink)
Howdy, I have problems with my 95 Camaro,3.4 Auto, 54000mi. When I start the car it idles OK, Revs up smooth, But when I start driving, it hesitates when I start to accelerate, kinda like going over little speed bumps, It stops doing it when I really give it the gas & get up to speed, I guess what Im trying to say is that on light, normal acceleration is when it happens, Seems like it really needs a harder, more aggressive acceleration to get by the problem. Ive changed the plugs, fuel filter, air filter, PCV valve, TPS, EGR valve(error code), checked the fuel pressure (OK), removed cleaned & tested the IAC (OK), cleaned the throttle plate & scanned for error codes(system passed,no errors) & no change. I can get to where Im going basically by REALLY accelerating up to speed, almost gunning it, Problem occurs when I start again from a stop or low speed.
I am by no means a machanic, I do custom leather work, So im flying by the seat of my pants on this one, I can usually fix the problem, Once I Know what it is !
Thanks in advance for any help !
shoeboy57 is offline   Reply With Quote Quick reply to this message
Old Jul 30th, 07, 07:29 PM   #2 (permalink)
Re: 95 Camaro Problems, HELP !!!
it may be the lockup solenoid problem. after it shifts to second gear does it happen?
hereitis67 is offline   Reply With Quote Quick reply to this message
Old Jul 31st, 07, 07:37 PM   #3 (permalink)
Hi & Thanks, I kept a closer eye today, It seems to happen at 45 mph +, It also seems to do it worse early in the day when the car is cold after sitting all night, When I leave work after the car has been sitting in the sun 80+degrees for the day its not as frequent, just seems to give me an occasional but regular bump while im driving, almost like im hitting a small bump in the road ???
Thanks Again, Hope I can get this figured out before I need to see a mechanic, Shop Rates just sack me.
Old Aug 1st, 07, 03:38 AM   #4 (permalink)
Leave the trans in Drive rather than OD and record the results.
Give a man a rescued dog for the health of both their souls.
'I wish the Dollar Store would sell gas. '
CUBS - 2016 World Series Champions
Old Aug 1st, 07, 05:41 PM   #5 (permalink)
Thanks, Ill giver a try
Thanks Again
Old Aug 2nd, 07, 03:20 PM   #6 (permalink)
sounds like a failing coil pack to me, but the ses light would come on with a misfire code...also, the egr you mentioned, did you clean it, or replace it???carbon balls in the pintle valve will create a lean condition at low speeds and the car will buck...going in and out of lock-up is a possibility as bill mentioned...one more thing to check is a lazy o2 sensor...it could start reacting faster when it gets hot...you would have to watch it on a scanner though to see what the data stream says...
sometimes you`re the windshield and sometimes you`re the bug...
kustomwerker is offline   Reply With Quote Quick reply to this message
Old Aug 5th, 07, 06:58 PM   #7 (permalink)
Thumbs up Re: 95 Camaro Problems, HELP !!!
Hi & Thanks for all the help ! I drove the car in Drive rather than OD & lo and behold the bumping problem was hardly noticable, so my first thought was a tranny problem(remember, Im a shoemaker, not a mechanic) Went to see my tranny guy, As soon as he started the car he knew right away that it was Missing & Not the tranny. I found that 2 of the plugs that I replaced a couple mos back were loose, Unbelievable, One even had blow by. Put in original AC Delco plugs & a new wire set, PURRS like a kitten, So at least for now Im not even looking at coils.
Thanks Again
Old Aug 6th, 07, 03:36 AM   #8 (permalink)
Cool !! Glad to read you're back on the road.
You've learned, learned to listen, feel maybe, and collect symptoms as to why its running rough. Also, another point, does it run rough when cold or at operating temperature. The more the symptoms given, the better the location of fault and faster repair, even if you take it to a mechanic/repair shop.
Old Aug 6th, 07, 04:45 AM   #9 (permalink)
fortunately, there is about 10000 yrs of combined experience on this site...lmao...every repaired problem gives us a little more knowledge to help the next guy...there are alot of conflicting diagnoces, and for good reason...we all read and apply knowledge differently, therefore we see the problem differently in our head...when hearing and feeling the problem, it is far easier to figure it out...i`m glad you got it licked...
Old Jul 2nd, 08, 02:13 PM   #10 (permalink)
Big Thunder's Avatar
i have a 94 auto with a 3.4 and it does the same thing it will only hesitate when the engine is cold and when the engine is warm then it goes away
Big Thunder is offline   Reply With Quote Quick reply to this message
Old Jul 11th, 08, 10:43 AM   #11 (permalink)
didi you change the plug wires?
CamaroBrandon is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
Human Verification
» Recent Discussions
U-joint angles in two...
Yesterday 02:31 PM
by Cam_67
Last post by Everett#2390
Today 03:28 PM
5 Replies, 226 Views
Epoxy vs. Self Etch for...
Mar 24th, 17 11:51 AM
by rp0029
Last post by socal_tom
Today 03:20 PM
12 Replies, 341 Views
Spark plug wires and...
Today 03:19 PM
Last post by Camaro808
Today 03:19 PM
0 Replies, 35 Views
windshield trim clips...
Today 02:59 PM
Last post by bondora68
Today 02:59 PM
0 Replies, 32 Views
Heater blower not running
Today 02:12 PM
by sloank
Last post by BPOS
Today 02:45 PM
1 Replies, 50 Views
Rim space
Today 11:31 AM
by Alex69
Last post by DOUG G
Today 02:25 PM
1 Replies, 42 Views
Alternator belt size
Today 02:18 PM
by sloank
Last post by sloank
Today 02:18 PM
0 Replies, 40 Views
Classic Car Blasting's...
Today 06:46 AM
Last post by bwarren
Today 01:57 PM
1 Replies, 85 Views
Steering gear upgrade...
Apr 29th, 14 01:26 PM
Last post by will sinclair
Today 01:23 PM
28 Replies, 13,785 Views
New wheels
Mar 24th, 17 09:17 AM
by 69&76
Today 01:22 PM
12 Replies, 310 Views
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
