2000 Camaro Radio shuts off randomly as well as windows? - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Nov 5th, 07, 04:59 PM   #1 (permalink)
Hi,
My wife has a 2000 v6 camaro that has a problem with the radio and power windows cutting out. Regardless if the car is moving or not the radio will shut off randomly. Sometime frequently in a thirty minute drive sometimes not at all. I have looked at wiring and thought it was that at first but, it will do it when the car is just sitting. I was checking it out the other day and I just turned the key back to listen to the radio and it cut out. Its interesting because it also effect the power windows at the same time.
I was told it could be the body control module bcm. I found some replacement ones online but, was curious as if anyone know if the BCM can just be swapped out? Or does it need some kind of programing to go with the keyless entry? I asked the local dealer and he said he doesn't think so but, didn't sound like he knew what he was talking about.
Has anyone had this problem? If so how'd you fix it? Does anyone know the specifics on replacing the BCM?
Thanks in advance
Sevenpelicans is offline   Reply With Quote Quick reply to this message
Old Nov 6th, 07, 08:10 AM   #2 (permalink)
Smile Re: 2000 Camaro Radio shuts off randomly as well as windows?
Hello,
I worked on a car that had that same problem. The BCM was causing this. I replaced the BCM and the car has been fine. The BCM is located behind the passenger side kick panel up behind the dash. You do not need to program the BCM but you will have to reprogram your key fobs for your remote keyless entry to work. If you need the actual service manual procedures let me know and I can e-mail them to you.
gm4t40 is offline   Reply With Quote Quick reply to this message
Old Apr 1st, 11, 09:45 PM   #3 (permalink)
An update for reference. The BCM Retained Accessory Power relay is the problem. The manual tells you to replace the BCM but you can usually just solder the 5 mounting points. The solder usually cracks and causes the problem. Look on the net for BCM remove instructions (it is up above the passengers feet) and when you get it out from under the dash it opens right up. The relay is the tallest black box on the circuit board just above a row of shorter black cubes.
Bob Tiley is offline   Reply With Quote Quick reply to this message
Old Apr 8th, 11, 11:24 PM   #4 (permalink)
Send a message via Yahoo to newcareer
I have a 2001 & I have got the same problem, also can anyone reccomend a cleaner or something to restore my convertible top, I'm almest certain that its canvas.
newcareer is offline   Reply With Quote Quick reply to this message
Old Aug 26th, 11, 10:20 PM   #5 (permalink)
Red face Re: 2000 Camaro Radio shuts off randomly as well as windows?
I have a 2000 Camaro which is doing the very same thing and looking for a DIY fix. I have had the intermediate problem and it actually stopped for a while but I have noticed that once it gets cooled off it will work for a short time until it warms up. I think I will try the relay fix that was mentioned in previous thread. Sounds like there could be issues by changing out the BCM. Can someone tell me something that will make me more comfortable about changing it if the relay fix doesn't work. Does anyone have a procedure for that fix or changing the BCM?
lpcamaro is offline   Reply With Quote Quick reply to this message
Old Sep 3rd, 11, 12:29 AM   #6 (permalink)
I had the same problem on my 1999Z. Soldering the cracked connections on the BCM worked.
Step by step instructions:
http://www.ls1.com/forums/f50/bcm-lets-fix-144674/
'69 SS 350 Fathom Green
'99 Z-28
rys99z is offline   Reply With Quote Quick reply to this message
Old Jul 4th, 13, 11:59 AM   #7 (permalink)
Do you have the procedures to replace the bcm and reprogram the keyless entry?
my wife just bought a camaro and her power windows dont work at all and her radio works sometimes and sometimes it dont but i found out if i put pressure on the passenger side kick panel it cuts back on so i figure it must be the bcm yall are talking about
nickleo0430 is offline   Reply With Quote Quick reply to this message
Location
Location
First Name
Human Verification
» Recent Discussions
Lost Camaro forum??
Yesterday 04:02 PM
Last post by buenymayor
Today 05:02 AM
4 Replies, 147 Views
Trunk Lid corner to...
Feb 19th, 17 04:53 PM
Last post by jboettc208
Today 04:52 AM
9 Replies, 297 Views
My 67 Stinger
Aug 24th, 16 09:05 PM
Last post by Sheck44
Today 03:12 AM
69 Replies, 3,277 Views
'68 Correct vacuum line...
Yesterday 11:54 PM
Last post by VitaminC
Today 12:59 AM
1 Replies, 54 Views
Drag link hitting oil pan
Yesterday 02:08 PM
Last post by ZZ_430
Yesterday 11:06 PM
2 Replies, 143 Views
Gear Ratio?
Yesterday 10:16 AM
by smwdrum
Last post by weezbad
Yesterday 10:25 PM
18 Replies, 310 Views
Spark plug wire stands...
Yesterday 09:39 PM
Yesterday 10:24 PM
3 Replies, 103 Views
Hello everyone! How much...
Feb 18th, 17 10:21 PM
by RustyC
Last post by BonzoHansen
Yesterday 10:05 PM
26 Replies, 503 Views
Original but Rusty '69...
Feb 18th, 17 09:49 PM
by RPOL72
Last post by x77-69z28
Yesterday 09:03 PM
7 Replies, 379 Views
Trying to figure what...
Yesterday 08:55 PM
Last post by daven1256
Yesterday 08:55 PM
0 Replies, 64 Views
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
