1998 Camaro v6 will not start. - Team Camaro Tech
Fourth Generation 1993-2002
LinkBack Thread Tools
Old Mar 11th, 12, 03:51 PM   #1 (permalink)
hey yall, my 1998 camaro will not start. its not the battery because the battery is good (i tested it in another vehicle and it worked fine). when i try to start it up without the jumper cables it just clicks but when they are connected, it will try to start but rough and drains the battery in like 5 seconds. i recorded a video of what im talking about and the sounds it is making in this clip. what could be the problem?
wwejj0926 is offline   Reply With Quote Quick reply to this message
Old Mar 12th, 12, 12:47 AM   #2 (permalink)
davidpozzi's Avatar
Re: 1998 camaro v6 will not start.
It seems strange the battery will start another vehicle but not your Camaro. The clicking you hear is likely the starter solenoid snapping on and off due to lack of input voltage. Your battery seems weak, but on a good starting engine it is probably good enough, on the Camaro engine where you have to crank it more, it is not up to the job. It probably would crap out on your other vehicle if you had to crank it that long.
Check your battery cables very closely for corrosion, the fact that your added ground wire helped indicates something may be wrong with the factory ground cable. The ground connection must be to the block, and all connections clean and tight. It is very common to see battery cable corrosion on the positive battery cable, even on side terminal batteries. On the inner fender near the battery, there is a power junction block, it should have a power wire in the wiring harness that runs around in front of the battery towards the radiator. Inspect the wires there for shorts or breaks. I had a buddy find bad connections there (in front of battery) that killed his cooling fans & I think caused some starting issues. Once the battery is disconnected the computer loses all learned memory and will be a little bit hard starting & may not idle smoothly instantly, but it should start & run with elevated idle for a few minutes and recover within a few start ups as it re-learns what the engine likes.
Have you tried pouring a small amount of fuel in the throttle body and cranking it? If it tries to start with the added fuel, your fuel pump is probably not working.
davidpozzi is offline   Reply With Quote Quick reply to this message
Old Mar 12th, 12, 12:02 PM   #3 (permalink)
Hey David, thanks for the fast response. I cleaned the terminals on both battery terminals and I want to check if the wires have shorts or breaks but can I check if their working with my Multimeter? Also, I have not tried pouring fuel in the throttle body and cranking it. My brother started it the other day and it ran for a little while. Since it started without pouring fuel in the throttle body, should I still try pouring fuel in it?
Old Apr 6th, 12, 11:28 AM   #4 (permalink)
Hey I changed all the spark plugs and the wireing is alright. there is no cross-threads. somebody looked at it and said there is gas in the oil because the oil smells like gas. he suggested to maybe rebuild the engine or get a new one. he thinks there might be a head leak. waht do u think?
Location
Location
First Name
Human Verification
» Recent Discussions
69 rustbucket rebirth
Jul 22nd, 13 12:38 PM
Last post by 350sshugger
Today 06:02 AM
644 Replies, 106,354 Views
10 Garage Tools To Make...
Jun 15th, 16 08:58 AM
Last post by rgwiz
Today 05:49 AM
7 Replies, 1,192 Views
'68 Correct vacuum line...
Yesterday 11:54 PM
Last post by camarocards
Today 05:26 AM
3 Replies, 87 Views
Show Me Your Garages
Dec 22nd, 07 04:42 PM
by JimmyC
Last post by OdeJoyster
Today 05:16 AM
535 Replies, 200,300 Views
Look Ma!! , I'm on TV!
Feb 18th, 17 09:10 AM
Last post by buenymayor
Today 05:10 AM
8 Replies, 258 Views
Lost Camaro forum??
Yesterday 04:02 PM
Today 05:02 AM
4 Replies, 173 Views
Trunk Lid corner to...
Feb 19th, 17 04:53 PM
Last post by jboettc208
Today 04:52 AM
9 Replies, 310 Views
My 67 Stinger
Aug 24th, 16 09:05 PM
Last post by Sheck44
Today 03:12 AM
69 Replies, 3,284 Views
Drag link hitting oil pan
Yesterday 02:08 PM
Last post by ZZ_430
Yesterday 11:06 PM
2 Replies, 166 Views
Gear Ratio?
Yesterday 10:16 AM
by smwdrum
Last post by weezbad
Yesterday 10:25 PM
18 Replies, 333 Views
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
