10 bolt rear end, 373 gears - Team Camaro Tech
What's it worth? & ebay discussions
post #1 of 14 (permalink) Old Jul 2nd, 08, 12:41 PM Thread Starter
anyone know what a 10 bolt rear end, 373 gears, in great shape. less than 500 miles after being re-built? thanks
okiemark is offline
post #2 of 14 (permalink) Old Jul 2nd, 08, 12:56 PM
Ray P.
camaro_fever68's Avatar
Re: 10 bolt rear end, 373 gears
Depends on what size 10 bolt -- what it fits -- and posi/non posi
The big 10 bolts (8.5") that fit the first gens are going easily $800 on up. The stock first gen 10 bolts (8.2") are not so desirable.
Ray
camaro_fever68 is offline
post #3 of 14 (permalink) Old Jul 2nd, 08, 02:31 PM Thread Starter
Ray: thanks a lot!
okiemark is offline
post #4 of 14 (permalink) Old Jul 2nd, 08, 10:48 PM
Agreed. A High HP engine will snap the 8.2. Which one is it and does it have POSI?
I might consider buying it.
Cyclopsracer is offline
post #5 of 14 (permalink) Old Jul 2nd, 08, 11:22 PM Thread Starter
It is posi. How high of h.p will hurt the rear-end if it's 8.2? My engine will be a re-built 327. I know the 10 bolt has the bigger, more sturdy bolts. I don't know if it's the 8.5 or 8.2.
okiemark is offline
post #6 of 14 (permalink) Old Jul 2nd, 08, 11:34 PM
Ray P.
Unless it's a really hot 327, I think you'll be fine with an 8.2. The drag strip (traction) is where you hurt these rears. I ran one into the low 11's before I finally broke it. It ran mid 12's for a few years with 3.73 gears and an Auburn posi unit.
It's real easy to tell the difference between an 8.2 and an 8.5 The 8.5 has lugs located on both sides at the bottom of the center section, see pic.
Ray
post #7 of 14 (permalink) Old Jul 2nd, 08, 11:39 PM
I am putting in a 503 HP 383 stroker and definitly need to go to the 8.5 or a 12 bolt
post #8 of 14 (permalink) Old Jul 3rd, 08, 08:42 AM Thread Starter
I'll see the rear-end today. I was told it had over $2,000 in the re-build and had the bigger bolts (?) or more bolts, as described above by Ray (THANKS RAY) I have to keep reminding Tom (Nelsonracingengines.com) I'm not trying to build a hotrod, just a nice drivetrain with the "right" stuff; for me personally and for re-sell value. I spend time here looking at old threads and posts,... but things are moving pretty fast now and appreciate all the help I can get.
okiemark is offline
post #9 of 14 (permalink) Old Jul 3rd, 08, 12:56 PM
Rich
the 8.5 had ring gear bolts with 3/4" heads, the 8.2 had 9/16" headed bolts, hope this helps
69 R/S Z/28 302 X33 D80 late 09C
69 T/A clonification LS6-6speed under construction
69 Nova SS retirement project
99 Firehawk
64 Chevelle wagon 6.0l planned sons toy
zman1969 is offline
post #10 of 14 (permalink) Old Jul 3rd, 08, 01:06 PM Thread Starter
thanks Zman. If I had it to do over, I probably would have gotten a good used 12 bolt. the buy building my engine jus so happens to have built 2 of the fastest Camaros on the planet (literally: go to YouTUbe: "F-bomb, 1200 h.p." I don't know if he even knows how to build a mellow engine, we'l see!. thanks.
okiemark is offline
post #11 of 14 (permalink) Old Jul 3rd, 08, 01:18 PM
Rich
i know the F-bomb a good built 8.5" is plenty good for 99% of the first gens on the road- ask me how i know- i have built 40-50 of them - i have no need for a 12 bolt anymore
99 Firehawk
zman1969 is offline
post #12 of 14 (permalink) Old Jul 3rd, 08, 03:28 PM Thread Starter
really!? that's good to hear. I'm learning as I go, myself. Some people say rebuilding an engine is like putting a pool in your back yard... you'll usually get your money back. The question is: if you build an $80,000 pool, will you get it all back.
okiemark is offline
post #13 of 14 (permalink) Old Jul 3rd, 08, 03:59 PM
8.2" here and still having fun (at least until the accident). Was $637 in parts for ring & pinion,Eaton posi,and install kit.
8.2" doesn't carry much value.
68 Camaro~LSx
Best to Date....and tuning
1.546 60'.....7.132 @ 94.43 660'.....11.327 @ 116.79.
<-Pics
post #14 of 14 (permalink) Old Jul 3rd, 08, 04:24 PM Thread Starter
how much of the "sturdiness" is in the gears, and how much is in the housing as far as taking stress? which is more likely to go out w/too much hp?
okiemark is offline
Human Verification
