1969 Camaro Z28 Value? - Team Camaro Tech
What's it worth? & ebay discussions
post #1 of 7 (permalink) Old Mar 23rd, 13, 10:56 AM Thread Starter
Hello,
I was wondering if I could get some opinions on the value of a 1969 Z28 without the original engine? The car is rust free and otherwise in great shape.
Thanks!
MrGrinch is offline
post #2 of 7 (permalink) Old Mar 23rd, 13, 12:23 PM
Camarodude67
Re: 1969 Camaro Z28 Value?
OK, we need to see a lot of pics of your car in order to verify that it is real and then a guesstimate on what it is worth. We know your Trim Tag is real but your car needs to be verified in order to place a value.
Jeff G.
69 Z/28 RallySport
69 Z/28
67 Vert RallySport
69 Vert
camarodude67 is offline
post #3 of 7 (permalink) Old Mar 23rd, 13, 12:52 PM Thread Starter
Jeff G.
69 Z/28 RallySport
69 Z/28
67 Vert RallySport
69 Vert
What else should I look at to confirm it's authenticity?
Also, assuming it is real what would the approximate value be?
MrGrinch is offline
post #4 of 7 (permalink) Old Mar 23rd, 13, 01:50 PM
Camarodude67
First is to verify the Vin # sequence in the other post...
We need to see pics of Power Disk Brake setup and both prop valves.
12-bolt rear end and need the codes and build dates.
Single Fuel Line.
Disk Brake Pedals
4-speed hole in floor and firewall.
Re-enforcement plate on passenger side.
YH Rims 15X7
Rear Bumper Guards
This is just a few that I can think of at this time.
Then we can go from there...on a value.
post #5 of 7 (permalink) Old Mar 23rd, 13, 01:55 PM
Sonny
restore-z28's Avatar
Jeff is correct as we need more pics and information. You indicated a non original motor but does it still have all the other components on the engine IE: DZ carb, intake, exhaust manifolds, smog systems, date correct heads, water pump etc. Does the car have the original interior and YH rims? What is the condition of the interior? Any documentation? Prices vary significantly based on all these factors, hard to put a price on something with no pics and minimal information.
1969 Z28 (Sold)
1970 RS Z28 Camaro (Green)
1970 Z28 (Blue)
restore-z28 is offline
post #6 of 7 (permalink) Old Mar 29th, 13, 10:10 PM
Cliff
what are the differences in the drake pedals?
Your AZ Real Estate Guy
AZreGuy is offline
post #7 of 7 (permalink) Old Mar 29th, 13, 11:22 PM
Tim
Z28 included power (front) disc brakes, so the pedal should have the circular insert like this:
(depending on additional options, it may also have a bright trim surrounding the pedal pad, as well)
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Raced in E/MP at Lions in LA. Now restoring!
ZLP955 is offline
Human Verification
