Drill Press - Page 2 - Team Camaro Tech
Tools & Shops Shop Rat HQ
 9Likes
post #16 of 25 (permalink) Old Jan 4th, 17, 08:00 AM
Lyle
Originally Posted by ilikeike View Post
I love old tools like that.
I'm on garagejournal.com too,I dig the old garage stuff, vises,anvils,power tools....
I can completely relate to the emotional attachment to a tool that you remember being there when you were growing up. I've got my dad's vise and anvil (along with countless other tools) in my garage. The vise is from a Canadian Pacific Railway blacksmith shop where he worked and is huge (10" wide jaws that open even more than that, it must weigh more than 150 lbs).
thebat is offline
post #17 of 25 (permalink) Old Jan 4th, 17, 08:40 AM
Re: Drill Press
I have my Dad's all aluminum Craftsman hand drill and the armature is missing copper pieces where the brushes ride. The armature is no longer available online. I dought my B&D armature from my plastic cased drill would fit. There is a place in town that carries old old parts that could have one. I'd have to check.
Mark 1970 Z28 M22 3.73 Z21 Z87 - Lunati 20120121 Retrofit Roller Cam
Owned: 1968 Z/28 in '74. 1971 Z28 from '75-'77 4-spd
Ordered new Z28's in 1977, 1978 & 1980, all 4-spds.
1970 Z28 owned since 1981
COPO is online now
post #18 of 25 (permalink) Old Jan 5th, 17, 08:10 AM
David Pozzi
davidpozzi's Avatar
Re: Drill Press
That drill press motor is a dual winding type. There is a centrifugal switch with springs on the bottom that changes it from a low speed winding to the high speed winding. When you shut the motor off, you'll hear a click as the winding switches back to low. Some times they hang up & do not switch back to the low, "start" winding. Then it will try to start on the "high" winding which is low Torque. It's best to replace these with capacitor start motors if they go bad.
If you bog this motor down enough, it'll start clicking, trying to shift to the start winding.
davidpozzi is offline
post #19 of 25 (permalink) Old Jan 5th, 17, 08:16 AM
George
Gbauer's Avatar
Re: Drill Press
Originally Posted by HawkX66 View Post
The new machines definitely don't compare to some of the vintage iron. I was thinking about "restoring" this one, but I like it the way it is.
My tools are a like a lot of my firearms. They have scratches and get a little banged up because they get used, but they're reliable and shoot straight.
It's 1/4 horse.
Electrical Motors - Full Load Currents
Pretty darn beefy motor for a drill! Especially if you couple it with the pulley system you have on it.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #20 of 25 (permalink) Old Jan 5th, 17, 08:19 AM
George
Gbauer's Avatar
Re: Drill Press
I doubt it'll be all that easy to swap it over to a capacitor start motor (physical size, shaft size, etc). Also being 1/4 horse it might not be dual winding since it's small enough to not need it.
Besides I just prefer the old stuff. A capacitor motor would never have lasted as long as this one did.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #21 of 25 (permalink) Old Jan 5th, 17, 03:09 PM Thread Starter
Re: Drill Press
It does have the centrifugal switch. It works well, so I'll leave it. I like that it's the original motor, but if it didn't work well, I'd change it out.
https://www.flickr.com/gp/146684464@N06/p50BZU
Originally Posted by Gbauer View Post
It's 1/4 horse.
It's actually a 1/3 hp motor. Definitely does the trick.
https://www.flickr.com/gp/146684464@N06/864530
'69 SS396 X66 L34 08D M21 BS
Z23 711 U17 72 B
Semper Fi!
Build thread:
HawkX66 is offline
post #22 of 25 (permalink) Old Jan 10th, 17, 12:23 AM
David Pozzi
davidpozzi's Avatar
Re: Drill Press
I used a slightly newer model late 40's Delta drill press for many years and it's still going in our farm shop. I took it apart and cleaned/lubed it. Ours had a little gearbox add-on below the spindle that geared it down for more power but it slowed it down too. I have drilled 1 1/8" holes with it, but it was a struggle. I have a newer Taiwan drill press at home that uses a 1hp motor and I think you need that much in a modern rated motor. My home drill press has a larger reach, but is not as stiff and it does not drill large holes very smoothly, it wants to chatter and slip the belt with big 1" plus bits. I have an old huge Buffalo drill press that could handle anything but it needs wiring. That thing kinda scares me!
This is exactly like our old Delta 17" except it has a foot operated feed.
post #23 of 25 (permalink) Old Jan 10th, 17, 05:00 AM Thread Starter
Re: Drill Press
Both of those presses in your pic are pretty cool. Too bad you weren't closer. I enjoy re-wiring different things. I went to school for electronics, but I didn't stay in the field.
I have no idea what the limits of mine are. I haven't found them yet lol. I haven't gone too crazy with steel though. My bits are limited.
Z23 711 U17 72 B
Semper Fi!
Build thread:
HawkX66 is offline
post #24 of 25 (permalink) Old Jan 10th, 17, 04:30 PM
David Pozzi
davidpozzi's Avatar
Re: Drill Press
Here's my Buffalo 20" drill press. It's Navy surplus from the 40's. I think the motor is 3 hp 3 phase220.
I need to install the 3 phase contactor and hook up the foot pedal. This drill press has power down feed, which is the drive attachment on the RH side of the photo. It drives a quill down to the gearbox just above the morse taper. Handle on top left is the drive engagement in-out. The manual says you can even do some milling with it, but you'd need a cross feed table. I need a ladder to change belt positions...
Name:	buffalo drill press.jpg
ID:	171202   Click image for larger version
post #25 of 25 (permalink) Old Jan 11th, 17, 05:44 AM Thread Starter
Re: Drill Press
Wow! What a tank. You can do some serious drilling with that bad boy. I doubt there's much that would slow that down.
Z23 711 U17 72 B
Semper Fi!
Build thread:
HawkX66 is offline
Human Verification
