Drill Press - Team Camaro Tech
Tools & Shops Shop Rat HQ
 9Likes
post #1 of 25 (permalink) Old Jan 3rd, 17, 11:19 AM Thread Starter
Drill Press
I figured a couple of you might appreciate this. I have a 1937 vintage Craftsman Drill press that I've been using since I was a kid. It was my Dad's. I plugged it in a couple of years ago after moving and got nothing. I didn't have much time to screw with it so in the corner of the basement it went until I could buy a new motor.
Over the weekend I decided I'd give the old motor a chance and zipped it apart. It was filthy and filled with oil soaked wood shavings and probably metal shavings. The wiring had seen better days and the insulation was flaking off. I cleaned everything up, soldered on some new wires, lubed up the bearings and threw it back together. Works like new again.
pittpens24 likes this.
'69 SS396 X66 L34 08D M21 BS
Z23 711 U17 72 B
Semper Fi!
Build thread:
HawkX66 is offline
post #2 of 25 (permalink) Old Jan 3rd, 17, 11:31 AM
Matt
Re: Drill Press
They definitely don't make them like that any more!
HawkX66 likes this.
12 Bolt 3.55 Posi
461 BBC TKO600
Matt 69 is offline
post #3 of 25 (permalink) Old Jan 3rd, 17, 12:04 PM
Andrew
Andrew69's Avatar
Re: Drill Press
That is sweet! Good job.
HawkX66 likes this.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #4 of 25 (permalink) Old Jan 3rd, 17, 12:10 PM
Re: Drill Press
Nice. I love when vintage stuff gets put back into use. I'd rather have that one than a brand new one. And it has sentimental value as well.
HawkX66 and BlueRibbon like this.
1967 RS 327/275hp
trland is online now
post #5 of 25 (permalink) Old Jan 3rd, 17, 12:48 PM
Re: Drill Press
Way better than a new one and great that you didn't need to replace the motor. I would have done the same thing in that situation.
NH69Z28RS is offline
post #6 of 25 (permalink) Old Jan 3rd, 17, 12:51 PM Thread Starter
Re: Drill Press
Thanks guys. I would have hated to retire that ol' girl. She's ridiculously heavy which, of course, equates to pretty daggon accurate.
Z23 711 U17 72 B
Semper Fi!
Build thread:
HawkX66 is offline
post #7 of 25 (permalink) Old Jan 3rd, 17, 01:23 PM
69-Pace's Avatar
Re: Drill Press
Excellent job!
HawkX66 likes this.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #8 of 25 (permalink) Old Jan 3rd, 17, 01:32 PM
George
Gbauer's Avatar
Re: Drill Press
Those old motors were notorously overbuilt. I ran into a pump just last week that a customer wanted to replace that was nameplated at 2hp. It was from 1979. When I started digging into it I couldn't find anything that would do the job for less than 5hp. Scratched my head a bit and really dug in with the customer in his office pulling the old as-built drawings from 1979 and re-did all the calcs to figure out what flow and head the thing was operating at. I had the original pump curve and the old pump so I knew what it was flow at any given head pressure but I didn't know the head pressure.
Sat down and re-created a system curve using 30 year old, 3" ductile iron pipe for my calcs. Then, for ****s and giggles, I figured out what the actual horsepower draw was. It was over 2hp!
So then I really started looking closely. I noticed it was drawing 14 amps at 208V, 3 ph. That's a LOT of amps for a 2hp motor!
Turns out this 2hp is actually a 4 hp. My 5hp pump draws 17A so they're looking into what's there now (wire size, starter size, etc) but we believe we can do a straight swap and it'll be fine.
Moral of the story here is that the actual hp of that motor is likely double what it's name plated as so if you ever do replace it you'll want to look at the amp draw.
oh and he's buying two pumps from me and replacing them both.
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Also own: 2014 Mustang GT and a 2013 Dodge Citadel. One red, one white and one blue from the Big Three.
Politics is cyclical. You start off young voting Democrat. Grow older and wiser and vote Republican. Then you die and vote Democrat again.
Gbauer is online now
post #9 of 25 (permalink) Old Jan 3rd, 17, 01:40 PM
Re: Drill Press
Way to go
old stuff doesn't know when to quit.
HawkX66 likes this.
68 Camaro~LSx
Best to Date....and tuning
1.546 60'.....7.132 @ 94.43 660'.....11.327 @ 116.79.
<-Pics
post #10 of 25 (permalink) Old Jan 3rd, 17, 01:52 PM Thread Starter
Re: Drill Press
With the weight of the motor you'd think it was 10hp...
Z23 711 U17 72 B
Semper Fi!
Build thread:
HawkX66 is offline
post #11 of 25 (permalink) Old Jan 3rd, 17, 01:56 PM
George
Gbauer's Avatar
Re: Drill Press
Do you have a pic of the nameplate for the motor? I can look it up and tell you what it really is.
That 2hp pump is the same size as a modern 5hp. A lot of it has to do with service factors. The old motors were usually a 2.0 SF. New ones are 1.15 SF.
So a 1 hp motor back in the day would actually put out 2hp whereas a new 1hp motor will overload at 1.15hp.
....finally a topic where I'm the expert! This is fun!
Oh and if you really wanted to keep it original you can always have the windings baked and insulated at any electric motor shop. Shouldn't be too expensive and probably the same price as buying a new motor. The bonus here is that you won't have to monkey around with trying to get a new motor with the same shaft diameter and length. In the end it might actually be cheaper to have it baked and/or repaired than replaced and you'll likely get another 75 years out of it too.
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
post #12 of 25 (permalink) Old Jan 3rd, 17, 03:26 PM
Darin
Re: Drill Press
I love old tools like that.
I'm on garagejournal.com too,I dig the old garage stuff, vises,anvils,power tools....
1968 Butternut Coupe,
TKO 600
9" narrowed 3"
421" Dart SHP block.
ilikeike is offline
post #13 of 25 (permalink) Old Jan 3rd, 17, 05:23 PM
Chris
Re: Drill Press
Well Done!! Glad to see the old tools restored to working order. These things are great and show what America was all about "in the day". I hate crap from the ChiComs and now we have little or no choice.
'69 Z/28, Lemans Blue/White Stripes, DZ302, T56 Mag., 4.10
Dynatech, 17" VWW V45's 235/45, 275/40
ctcz28 is offline
post #14 of 25 (permalink) Old Jan 3rd, 17, 05:43 PM
Re: Drill Press
Got the same, Montgomery Ward, traded a 90cc dirt bike for it, 40 years ago. Still works.
TC # 349
zdld17 is online now
post #15 of 25 (permalink) Old Jan 4th, 17, 05:47 AM Thread Starter
Re: Drill Press
The new machines definitely don't compare to some of the vintage iron. I was thinking about "restoring" this one, but I like it the way it is.
My tools are a like a lot of my firearms. They have scratches and get a little banged up because they get used, but they're reliable and shoot straight.
[url=https://flic.kr/p/P6ED4N]
Z23 711 U17 72 B
Semper Fi!
Build thread:
HawkX66 is offline
Human Verification
