Rear Axel/Grease Leak - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
Old May 27th, 08, 02:45 PM
berthicks96rs berthicks96rs is offline
Default Rear Axel/Grease Leak
I am just wondering if that kind of a leak would stop a mechanic from replacing the back brakes. I was told that it would be a month before the back breaks would give out and that the leak needed to be fixed before he could replace the back breaks which he said would cost $300+ and the leak would be around $250+ to fix. does this sound right or is he just trying to scam me. Thanks guys
Old May 27th, 08, 04:32 PM
yellow69RS's Avatar
yellow69RS yellow69RS is offline
Jeff
Default Re: Rear Axel/Grease Leak
Former ASE mech FWIW. If the grease leaks onto the new shoes they don't perform as designed. A little leak they tend to grab, alot of grease they don't grab at all. I have been out of the mechanic field for over ten years but it seems his prices are fair at todays rates.
Jeff
Old May 27th, 08, 04:56 PM
quickboat quickboat is offline
jim
The job is a pain. Gotta pull the axles. Maybe a smidge high though with just shoes. IMHO
67 RS Deluxe Int. A/C car
TKO-600
400 4 bolt block .03 over
Ported 215 Pro1 Platinums
Forged/balanced 400 crank, pistons, 6" rods
286HR cam w/1.6 rckrs LS1 beehives
Forgelines, 18"f 19"r, 4 link w/ minitub
IROC s/gear, 4 wheel discs
Old May 27th, 08, 06:01 PM
DjD's Avatar
DjD DjD is offline
Dennis
I have no doubt you can find someone to do your brakes even though your axle seals are leaking. As stated though the dif-fluid will destroy your brake linings and cause your brakes to fail. Your mechanic is being responsible if your axle seals are leaking. I doubt he is scamin' you, call another mechanic in your area and ask what he would charge to replace axle seals and to do a brake job. Someone will give you a ballpark figure over the phone.
...Dennis
www.camaroslimited.com
"Don't take life so serious, you won't get out alive..."
Old May 27th, 08, 06:24 PM
Oldrocker Oldrocker is offline
Tom
Sounds like your dealing with a true professional mechanic. Anyone that would replace the brake linings without repairing a leak that will destroy the new ones isn't someone I'd want working on my ride.
Old May 28th, 08, 06:34 PM
deerhunter deerhunter is offline
Since he told you the truth from the beginning, if I used a mechanic, I think I would give him your business. Shop rates what they are, I don't think he is trying to gouge you or he would have changed the rear brakes in the first place.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Camaro Tech      Current Topic: Rear Axel/Grease Leak
Location
Location
First Name
Human Verification
