How to remove backseat in 69 camaro - Team Camaro Tech
Interiors Upholstery & soft trim
Old Aug 5th, 09, 03:49 AM
1996jeep 1996jeep is offline
Adam
Default How to remove backseat in 69 camaro
Installing a new carpet. Is it hard and have any certain order to remove seats?how do u remove the backseat? Thanks
Old Aug 5th, 09, 04:17 AM
Dan E. Dan E. is offline
Dan Ensign
Default Re: How to remove backseat in 69 camaro
Carpets are tedious, they have to be trimmed to fit, take your time. The rear seat cushion lifts out, it has a catch on each side and the backrest is bolted in behind the seat cushion, then lift it straight up. The rear carpet need only be trimmed at the sides, most important thing with the front is to line up the toe pad correctly and cut the hole for the dimmer switch in the right place. You will also have to remove the sill plate trim. I had my 4 year old daughter sit on the hump to keep the carpet in place while I trimmed it. Also best if you take it out of the box and hang it for a while so it straightens out.
Dan E.
69 SS396 4spd. 4.11 posi. x66 coupe
Old Aug 5th, 09, 08:04 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
As Dan said, the bottom cushion has a metal catch underneath with a back facing notch. You have to sit on the cushion or push down on it very hard and then at the same time, push the cushion toward the back of the car, that should release the catch. Same procedure to re-install it. You can see the catch on each side in my pic here.
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
"There will come a time when you believe everything is finished,
That will be the beginning." Louis L'Amour
Photos of my Camaro for viewing
Old Aug 5th, 09, 11:51 AM
Adam
should i primer the floor before installing or spray undercoating on top ?
Old Aug 5th, 09, 12:45 PM
vincevs's Avatar
vincevs vincevs is offline
Vince
I vote no to undercoating... undercoating always makes the next owner think you are hiding something.
Vince
69 Base Coupe "The Wrecker" Project - Build Thread
67 rs/SS L48 4spd Convertible - Build Thread - SOLD
Old Aug 5th, 09, 03:55 PM
77thor's Avatar
77thor 77thor is offline
Fred
I would NOT undercoat anything inside the car.
1969 Camaro SS350, M21, 12 Bolt, 01B LOS Build
Old Aug 5th, 09, 03:57 PM
Mkelcy Mkelcy is offline
As for removing the rear seat, are you cursing enough?
Mike - '68 Camaro with lots of stuff done to it.
http://imageshack.com/a/img745/1637/0NP8Y4.jpg
Old Aug 6th, 09, 08:30 PM
Steiner Steiner is offline
Steiner
Whew, no kidding. The way I had to get lined up on mine, I had flashbacks of "GET LOW!" blocking drills in high school.
'69 Camaro
Dart 400-AFR 195-224/224 HR-Powerjection III TB with F.A.S.T. Sportsman XFI
TKO 600-Moser 3.42-Detroit Truetrac
500hp/538lbft
www.cmengines.com
'69 Camaro Beater-SFT 327-M20-Moser 4.10-sold
'02 Z/28 vert-stock-sold and totaled
Old Aug 7th, 09, 05:41 AM
L7869 L7869 is offline
an important thing to remember cutting the carpet, take your time and cut very little at a time. always cut off less then you think you need to and kept trying the fit. you have to be very careful not to cut the carpet too short on both side edges.
Old Aug 7th, 09, 07:04 AM
bikedude3 bikedude3 is offline
clayton hicker
hi guys i was going to post a topic and ask how do i get rear seat out of my 68 to replace my seat belts.is it the same on a 68 as a 69?thx
clayton hicker
  #11
Old Aug 7th, 09, 07:09 AM
Steiner
Yes it is. If you've got some Mechnix gloves or something it sure helps. Long sleeves will help with the hog ring run-ins as well.
'69 Camaro
500hp/538lbft
www.cmengines.com
  #12
Old Aug 7th, 09, 07:39 AM
clayton hicker
lol ok thx much
clayton hicker
  #13
Old Aug 18th, 10, 08:33 AM
generaldon generaldon is offline
Don H.
I took out the bottom cushion and the bolts holding the top one, along with the bent pieces on the sides, but i can't get the top cushion to come out. Anyone know how?
  #14
Old Aug 18th, 10, 08:36 AM
Melrose RS Melrose RS is offline
Tom
Back has to move upward toward the window to release the back from the hooks.
'67 rs - ordered new by my Grandfather
327 L30, K-K, Deluxe int, tach & gauges, 12 bolt posi, 4 speed.
the Melrose rs - L30 327/275hp
  #15
Old Aug 18th, 10, 08:38 AM
Don H.
ok thanks
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Interiors      Current Topic: How to remove backseat in 69 camaro
Location
Location
First Name
Human Verification
