| Team Camaro Tech Current Topic: &%$#*@ header leak, I hate header leaks | ||
| Performance Our High Performance area |
#16
Some gaskets are different, I for one do use the rubber 1 piece pan gasket, and rubber valve cover gaskets, they are better engineered and obviously make more sense, rubber repels water and is non porous. I haven't used the copper or high dollar header gaskets, maybe I shouldn't judge, but passing hot gasses is pretty straight forward (insert fart jokes here), where as oil and water under pressure is an entirely different ball game. To each his own.
The only Mustang I'd ever own is a Fender. |
#17
wow, never thought a header leak would get this religious on gasket choices. If the Remflex graphite monsters I bought don't work, I'll try Fel-Pro manifold gaskets. I'm still going to get rid of the 3 bolt collectors at some point and go to ball/cone joints.
RJ The Garlic Capital, Gilroy,CA 1968 RS convertible 425hp 350ci full roller, Keisler TKO 5spd, 12 bolt posi, Wilwood discs, Hotchkiss suspension. Pics: my drop top driver |
