Tag Team De-coding tags and numbers.
  #16
Old Nov 6th, 09, 07:33 PM
cjm465's Avatar
cjm465 cjm465 is offline
CJ
Default Re: anyone have a 06A hugger orange 1969 camaro??
Originally Posted by DjD View Post
My car's an 06A hugger orange convertible...
And it still has it's trim tag? I was thinking defective rivits on 06A's for a minute.
69 Z/28, X-77, NOM ( 396 Power), M-21, BU Rear, 71B/715.
BTW: Where the hell is my original motor?
Old Nov 6th, 09, 07:40 PM
Gary L's Avatar
Gary L Gary L is offline
Gold Member
"Tri-Tip"
Default Re: how was colors asigned to trim tags
Per the CRG report:
"Color System: The bodies were sequenced to "batch-paint" by color as much as the build schedule allowed, to minimize the waste of thinner required to clear paint guns between colors. The interior was masked off, the body exterior was tacked-off, and it then entered the main color booth, where it got three coats of acrylic lacquer, sprayed automatically with vertical and horizontal reciprocating spray guns, with a 3-minute "flash" between coats, followed by a 10-minute bake at 200F to "skin" the surface prior to sanding. In the next stage, any surface defects were power- and hand-wet-sanded with mineral spirits, then wiped off prior to entering the final "reflow" oven. This bake lasted 30 minutes at 275F, where the lacquer surface softened and "re-flowed" to a uniform gloss."
Gary, SIM TC Member with a Lemans Blue/Ivory 02D X33, DZ, M20, MS, flat hood. Only the BU code rear end is original.
http://www.camaros.net/showroom/data/500/DSC00005.JPG
http://www.camaros.net/forums/image....3&type=profile
http://www.camaros.net/showroom/show...0&ppuser=11189
Old Nov 7th, 09, 07:27 AM
1bad69z 1bad69z is offline
sheena farr
Originally Posted by NHBandit View Post
hmmm.. mind if we call the 2 of you the "tag team" ? one of you is a bad 69 SS and the other is a bad 69 Z huh ? Do you both need to replace "stolen" tags or what ? And you'd like us here at Team Camaro to educate you on how to get new trim tags ? And you're both brand new members to boot.. Or are you both the same person ? I'm a little confused since you BOTH are answering the questions that have been asked and ya said WE need new TAGS.. There's a guy on Ebay with a bucket of tags. Maybe he took yours... Maybe your cousin needs a new tag for his COPO too.. Ya ok..... good luck with that...
nhbandit. i was trying to help my girlfriend(1bad69z) with her tag. that is why my name is on my screen and her name is where she replied. it just shows on whose labtob we are on. sorry to rowl you up.
Old Nov 7th, 09, 07:34 AM
sheena farr
dennis any help would be greatful. the car is being worked on replacing the floor pans and supposedly the trim tag has come up missing off the front of the car. i dont know if better to just run without it or try to get repop? from memory the number started in 355 range but not sure what to do.
Old Nov 7th, 09, 07:36 AM
okiemark okiemark is offline
Gold Member
Mark
did I miss the part about how the tag was stolen??
My 69 Camaro
Old Nov 7th, 09, 07:50 AM
OK69 OK69 is offline
Joe
Sad somebody stole the tag......
Old Nov 7th, 09, 09:16 AM
sheena farr
it is in the restoration shop and guy says he dont know what happen that it just isnt on the firewall anymore
Old Nov 7th, 09, 09:21 AM
Gold Member
Mark
.... seriously? and you're buying that story?
My 69 Camaro
Old Nov 7th, 09, 09:53 AM
sheena farr
i dont want to accuse him of anything. but the trim tag was there and now it is gone. as early i dont think they made faulty rivets. i have never took one off so i dont know if it is easy or hard.
Old Nov 7th, 09, 10:07 AM
Gold Member
Mark
My 69 Camaro
Old Nov 7th, 09, 10:42 AM
sheena farr
http://www.collectormotors.com/L89/14.jpg
Old Nov 7th, 09, 11:12 AM
sheena farr
http://i325.photobucket.com/albums/k...N/IMG_0011.jpg
Old Nov 7th, 09, 11:16 AM
sheena farr
http://www.americanstreetmachines.co...tf=100&tfc=101
Old Nov 7th, 09, 11:34 AM
sheena farr
St6912437nor346700bdy
tr711 57 57pnt
06a x11
DjD's Avatar
DjD DjD is offline
Administrator
Dennis
I don't know how I can help, my number is lower than the range you mentioned... My understanding is all June '69 production from the Nor plant got 06A for some reason. That gives a much larger range of numbers.
The only really legit reason(s) to replace a trim tag is a lost or damaged one. Even changing interior or color has deception to it. and if it's a desirable car (SS, Z/28 etc) a replaced tag is going to draw suspicion on resale. If the car is nothing special (I know they are all special) it might be best to not replace it and if it is a desirable car it still might be best to not replace it unless you have solid proof the car is what it is...
...Dennis
White Wonder
The Nova
Photo Album
www.camaroslimited.com
"Don't take life so serious, you won't get out alive..."
