| Team Camaro Tech Current Topic: Remove padding from roof | ||
| Camaro Tech General Tech Area For best results use specific forums |
I have removed the majority of the padding by scraping but have some left of course. My thought is to use wire brush on a grinder.
Will wire brush put too much heat in roof, or should a use scotch brite pads on the grinder? thanks, Jay
69 SS-350-470hp, TKO-600, DSE Coilover conversion suspension w/Koni shocks, Baer brakes w/hydroboost. 69 project for my wife - SS 396, Glacier blue http://www.camaros.net/forums/showthread.php?t=176706 |
By padding are you talking about the insulation that is between the roof skin and roof supports. A wire brush should not heat the metal enough to do any damage but it does make a lot of dust. Grinding or a emery wheel may.
I 69 they were not aware of the damage that asbestos could do to a person and I have not heard anyone say there is no asbestos in that insulation. If you do use a wire brush be sure to protect yourself and anyone around because we don't know what it is. Roger
1967 Camaro SS/RS 350/295HP Coupe. First and only owner. |
thanks Roger. By padding, I mean insulation. I am wearing a respirator and eyewear.
Update
: The wire cup on grinder works great and does not heat up roof panel. Just make sure to wear eyewear and respirator.
