| Team Camaro Tech Current Topic: Power steering box. Which port is for high pressure? | ||
| Brakes, Suspension & Steering Conversion questions, Steering & Handling |
Can anyone tell me which of these two ports is the high pressure port and which is the low pressure port? The part number on the casting is 5691676 if the helps.
Matt 67 RS, 406 small block, TKO600, Moser 12-bolt (3.73) |
Return is always closest to firewall on a Saginaw box.
'69 Camaro X11 Street Car Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III TKO-600 - Moser 3.42 - Detroit Truetrac 538 lb-ft - 500 hp www.cmengines.com '69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10 '02 Z/28 vert - stock |
Thanks Steiner. So #1 is the high pressure from the pump and #2 is the low pressure return back to the pump. Is that correct?
Also, my return hose is just hose clamped to the pump return. Is that alright?
You bet. Yep, #1 is high pressure and band clamp is fine on the return.
High pressure lines are always smaller than returns.
69 SS, 350/300 h.p., M-20, 12 bolt, matching numbers. "http://i376.photobucket.com/albums/o...s/IMG_2107.jpg" |
Thanks. That is what I needed.
