| Team Camaro Tech Current Topic: Is it possible to paint just the lower rocker panels? | ||
| Body Shop Paint & Body Forum |
#16
Some of those new cars with zero miles on the lots have had their bumpers repaired and the whole cover was not cleared. Doubtful their owners will ever know. |
#17
Sorry for the delay in posting....
http://img.photobucket.com/albums/v2...-50-07_106.jpg http://img.photobucket.com/albums/v2...-49-45_408.jpg It doesn't look as bad as the picture makes it out. That was a bright flash in a dimly lit room. It normal lighting it doe NOT look so bad. So in the pictures you can see (as mentioned above) there IS in fact a lower body line that I was inquiring about.... Ron |
#18
Links to Pics posted and no replies since??
#19
What happened to all my knowledgeable responders? Anybody??
#20
I saw the pics, not sure what your question was though. Did you want advice on if they looked good enough not to paint ? If so, I'm 50/50 on it but it's really your call since it's your ride.
Russ (RJ) The Garlic Capital, Gilroy,CA 1968 RS convertible that is not quite stock Pics: my drop top driver |
#21
Ron |
#22
Yes you can but you will have an edge from tape.
Little M 434 SBC with Juice in the works |
#23
If you're not opposed to it, the lower molding kit is about $160 and would cover most of that up.
'69 Camaro X11 Street Car Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III TKO-600 - Moser 3.42 - Detroit Truetrac 538 lb-ft - 500 hp www.cmengines.com '69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10 '02 Z/28 vert - stock |
#24
Can you show me what you are talking about?
#25
http://www.ss396.com/mm5/merchant.mv...t_Code=KMX-452 And it will look something like this when done...
68 Camaro SS 396 - 468 BBC now, M21, BO coded 12 bolt - but currently has 3.31 gears and a posi. Old drag car back on the street. Looking for 68 Camaro with body number NOR 181016 CRG - www.camaros.org |
#26
I think it would look fine. If you wanted to get rid of the tape line then you would need to do is color wet sand and re-polish to hide the dividing line. That's how most body shops hide the lines when repairs are done.
#27
I'd say go for it for 2 reasons. 1---its not SEMA car and 2 there is seam between and gap between the rockers and the doors. Painting anything in the "middle" without at least seam is a no-go. Go for it, it will make the car look better.
#28
No you won't if you know how to backmask at a style line. I did this often in collision and recently did it on trike body. Refinish Netork provides tech info you don't get as much on hobby sites. Jimmo does not say it but the blending agent will make the clear take off if sprayed heavily.http://www.refinishnetwork.com/
#29
Mike 69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower http://s268.photobucket.com/home/pro...maro/allalbums |
#30
