Muncie speedo - Team Camaro Tech
Old Nov 12th, 12, 06:22 PM
GAccomando GAccomando is offline
Default Muncie speedo
I believe I have a M-20 in my 67' Still decoding, but I need the new plastic gears inside that control the speedo cable. Both are so worn the speedo is jumping. Can someone recommed a good site for parts, and the proper name for the part?
Thanks as usual. G
Old Nov 13th, 12, 03:00 AM
Everett#2390's Avatar
<Jake 68's Rule
Default Re: Muncie speedo
Here's a start: I received a manual from Jody's Transmission
Circle gear for the shaft, pencil gear for the speedo.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Nov 13th, 12, 09:44 AM
norcal_68 norcal_68 is online now
There is the Speedo drive gear that is on the shaft and then there is the speedometer driven gear which you can pull out and sits in the bullet/housing which is attached to the cable.
Here is a good resource: http://chevelleengineer.home.comcast...eer/speedo.htm
The speedometer driven gear comes in different sizes depending on rear end etc. You can get that from local Chevy dealer, I got one in a day.
Thanks as usual. G
Old Nov 13th, 12, 10:03 AM
Here is the gear that sits on the shaft:
http://www.thegearbox.org/catalog/it...82/3547889.htm
Here is the driven gear that sits in the housing that connects to speedo cable.
http://www.thegearbox.org/catalog/it...82/3697857.htm
Old Nov 14th, 12, 05:25 PM
JodysTransmissions JodysTransmissions is offline
Make sure use the correct speedo driven gear with the correct OD corresponding speedo drive gear for longevity.
Jody Haag
JodysTransmissions@verizon.net
Most 4, 5, and 6 Speed Repairs, Parts, Service & Custom Installations
610-682-1602
Auto Gear Muncie Distributor & Builder
My '70 Chevelle: ZZ502/502 ROD 6 Speed
