New User Question-Hello! - Team Camaro Tech
Tag Team De-coding tags and numbers.
Old Nov 18th, 12, 07:30 PM
Guernsey Guernsey is offline
Ben
Default New User Question-Hello!
Hi. My name is Ben, and I am new to this site. I have a question regarding my 67 Convertible Camaro. My Cowl Tag has a 09C build date. I am trying to find out if the engine is original to the car. The block code reads: TO906MM. The dates seem to coincide.... Can someone tell me if this is an original tonawanda engine, or a replacement? If so, how can we tell? Thank you for your time.
Old Nov 18th, 12, 07:57 PM
trland trland is offline
Default
Welcome to the site Ben. I'm pretty new here too but learning a lot from the experts here. I also have a 67 with a TxxxxMM engine. MM is the L30 engine (327 with 275 hp) with automatic transmission and no smog pump. Since there is no partial VIN on the engine pad I've had to use other info to help convince me that I have a "born with" engine. Lots of reading here and on the Camaro Research Group site helped a lot.
Old Nov 18th, 12, 09:16 PM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Default Re: New User Question-Hello!
Guys Im moving this post to TAG section that deals with questions about number of engines, vin's etc. welcome aboard and try to post in the section that is most relevant to your needs
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
"There will come a time when you believe everything is finished,
That will be the beginning." Louis L'Amour
Photos for viewing
Learn How To Post Pics here
Old Nov 19th, 12, 12:29 AM
Garfields Maro Garfields Maro is offline
Garth
Welcome Ben, for 67, generally only SS and Z/28 had partial VINs stamped on the block, so all you can do is check date codes and casting numbers to see if they line up with the cars build date. Sounds like you have the original L30 . I'd suggest you check all the casting numbers for further confirmation. Here's a link to CRG for finding and interpreting those casting codes.....http://camaros.org/drivetrain.shtml
Also, if you feel like it, pop the valve covers off to check the heads. They're really the heart and soul of the L30.
  • '68 RS, AA, 749, L30, M(uncie)20 (originally a 3spd), 15yr backburner resto........
Old Nov 19th, 12, 04:03 AM
Everett#2390's Avatar
<Jake 68's Rule
Welcome, Ben.
Yes, research the camaros.org site to answer most of your questions.
Warning, you'll be asked for pictures. Members here like them.
Replacement engines from the dealer under warranty would have a 'CE' stamp.
And I prefer Guernsey milk over Holstein, more cream, makes better homemade ice cream.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Nov 19th, 12, 08:24 AM
buenymayor buenymayor is offline
Welcome, Ben. Check out the link Garth sent ya. That should keep you busy for a while.
Plus their manure smells better!
Experience...... It's what you get when you didn't get what you wanted.
http://camaro.bertke-one.com/teamcam...%20Camaro.html
Old Nov 19th, 12, 12:34 PM
Ben
Thanks for the help fellas!. (Maybe you are ladies, but I'm just assuming )
