Tko 500 600 700 ? - Team Camaro Tech
Old Nov 27th, 12, 06:46 AM
wayne payne wayne payne is offline
Default Tko 500 600 700 ?
Getting ready to buy one of these trannys. I have spoken to Shafi at Keislers and he reccommends the 700. Gonna be about 3800 bucks. What are some of you guys experiences withe tremecs? Thanks, Wayne
Old Nov 27th, 12, 06:54 AM
Vega$69 Vega$69 is offline
John
Default Re: Tko 500 600 700 ?
What is the rest of you motor rearend combo?
I would do a search before I bought a 700 from Keislers. They seem to have a bad rep for actually delivering. Especially the 700s
Might want to talk to Scott at Hurst too.
69 Pro Tour - LS7/T56 Building
C6ZO6 Vette Lemans Blue
69 Z28/RS Tribute
355/5 Speed(SOLD)
69 RS Clone
427/TH400(SOLD)
67 RS
ZZ502/5 Speed(SOLD)
69 Camaro
406 SBC/TH400(SOLD)
Old Nov 27th, 12, 07:17 AM
SixtyAte's Avatar
SixtyAte SixtyAte is offline
Kevin
Try this guy also. AMP Performance. I got my complete kit, TKO 500 Trans, offset Mcloud shifter, Hurt shifter arm and ball, elec speedometer adepter, cross member, poly trans mount, new drive shaft assembled w/ front and rear yoke s and u-joints, Gm trans fluid, shifter plate, hat and stickers Was $3,000 shipped to my door and there was a $100.00 mail in rebate. Total, $2,900
TKO 600 /TCET5009(2.87 first and .64 OD) is listed below but I got the TKO 500 package ( 3.27 first and .64 OD) and its super.
9 pc kit for first gen http://www.ebay.com/itm/TREMEC-TKO-6...-/251130910389
Full Kit http://www.ebay.com/itm/1967-69-CAMA...-/370159874804
Call 1-800-454-8387 ex105.and ask for Tom.
Kev
Old Nov 27th, 12, 08:46 AM
kv67ssrs kv67ssrs is offline
I have a TKO600 from from Jim @ Hurst.... I love it..
Old Nov 27th, 12, 09:53 AM
67Carl 67Carl is offline
Carl
X2 on the Hurst TKO 600 (was only $100 more than 500) and on researching Kiesler in the archives. Know what your potentially getting yourself into.
I got the Hurst kit that included driveshaft, offset shifter and other necessary bits plus their LuK clutch package for somewhere around $3400-$3500. It has worked flawlessly and is by far the best addition to my car.
1967 350, Hurst TKO 600 5 speed, 12 bolt 3:55 posi, RS added
http://photobucket.com/1967_Camaro_Carl
Gone but Not Forgotten: 1970, born with a 6cyl, 350sbc transplanted in
http://photobucket.com/Carls1970Camaro
Old Nov 27th, 12, 10:22 AM
383 making about 500 hp and a 355 rear with 26 inch tall tires.
Old Nov 27th, 12, 12:00 PM
SixtyAte's Avatar
Kevin
The TKO 500 or 600 w/ .64 overdrive will be just fine with your setup !
Kev
Old Nov 27th, 12, 12:04 PM
Do any of you see much of a drop off in rpm's using the tko 500, 1st is 3.27 and 2nd is 1.98 compared to the 600 with 1st 2.87 and 2nd with 1.89. The 600 is adv. as a close ratio, just wondering. Thanks, Wayne
Old Nov 27th, 12, 12:06 PM
Carl
TKO 500 rated to 500lb/ft of torque, TKO 600 rated to 600lb/ft torque. For an extra $100 why not get the more stout one? I got the 0.64 fifth gear and can tell you after logging 400+ highway miles this Thanksgiving was absolutely the right choice. I had an M21 close ratio so the TKO feels a bit slower off the line, but I have a stock 350 from 1969. Probably makes about 230hp at this point. With 500hp (so jealous) I don't think you'll have a problem. Dyin' for a 383
Old Nov 27th, 12, 12:12 PM
Carl
There are calculators you can Google that compare rpm with different ratios and tire sizes. I've got a 3:55 rear, 17" rims with 245/50ZR17 (on the back) and was turning about 2200rpm at 78-80mph.
Try using this calculator to see the options;
http://www.proformancepowertrain.com...lyzer_5sp.html
Old Nov 27th, 12, 12:21 PM
SixtyAte's Avatar
Kevin
I have a 383 with 12 bolt 4:10 posi and was running a ST-10 with a 3:42 first gear. It pulled like heck through all gears but 3,200 RPM killed me when I wanted to go on the highway at about 60 mph. I went with the TKO 500 and the 3:27 first (I posted wrong first gear ratio before) and .064 overdrive. My car pulls like it did before and now I can cruise at 70 at about 2,200 RPM. You have 3:55 gears and you will love the 3:27 first if you enjoy the off line !
Kev
Old Nov 27th, 12, 06:22 PM
Steiner Steiner is offline
Steiner
Keep in mind the TKO ratings are at 5000 lb vehicle weight. They can be uprated considerably in a first gen. The fourth to fifth drop on the TKO's is much more noticeable than any one-two drop.
BTW, difference in first gear speed at 3000 RPM and 6000 RPM redline between 500 and 600 with a 3.55 gear and 235/60 tire is only 3 mph and 6 mph respectively.
'69 Camaro X11 Street Car
Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III
TKO-600 - Moser 3.42 - Detroit Truetrac
538 lb-ft - 500 hp
www.cmengines.com
'69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10
'02 Z/28 vert - stock
Old Nov 27th, 12, 06:39 PM
TMessick TMessick is offline
T
I'm running a TKO600 from CC5S (now Hurst Driveline) and am happy -- those guys give very good post-sale support and the kit went in smoothly aside from issues I caused myself (I had some mismatched 68/69 shifter and console parts)
I picked the TKO600 over the TKO500 mostly because I like the 1/2 gear split better on the 600 (less RPM drop) but the higher torque rating for small incremental price also helped sway me.
With a 3.55 rear, that 3.27 1st is going result in a pretty aggressive 1st gear that will run out of revs quick (25mph ~= 4000 RPM). It'll be fun, but I'd be surprised if you can hook up with all that gear. By comparison, the TKO600's 2.87 1st would be at ~30mph at 4k in 1st and should still be enough gear for you to smoke em with a 383...
Sooo -- I vote TKO600 from the vendor of your choice.
Old Nov 27th, 12, 06:44 PM
John
Car is sig is a 355 roller motor. 3.55 rear and the TKO 500 is perfect. Does not run out of 1st at all and at 1800 rpm freeway speed the car gets 18- 20 mpg.
I use 500s in my SB cars and 600s in BB.
Using a built T56 in my current LS7 build
69 Z28/RS Tribute
355/5 Speed(SOLD)
69 RS Clone
427/TH400(SOLD)
67 RS
ZZ502/5 Speed(SOLD)
69 Camaro
406 SBC/TH400(SOLD)
Old Nov 27th, 12, 06:50 PM
T
I agree that the 4/5 ratio split is noticeably "wide" but I still think the 1/2 is more noticeable. Probably because I wind out 1st gear to 6k, so I get 6000->3900 RPM change on the shift, whereas I rarely do the 4/5 shift above 80mph or so (4000-> 2600 RPM).
(just for reference, on a TKO500, the same 6000 RPM 1/2 would drop to 3600 RPM or so after the shift)
