Input on clutch selection for 69 z/28 all stock - Team Camaro Tech
Old Dec 5th, 12, 12:59 PM
69zee 69zee is offline
Rich
Default Input on clutch selection for 69 z/28 all stock
I got my car a year ago. 69 z/28 80k miles and all original. I only drove it twice before the heater core went and the can of worms went all over the place. 6 months went by while I did a complete bumper to bumper mechanical rebuild. The trans was checked out and new seals installed. The engine was freshened with new bearings rings etc. Still a standard bore with original pistons etc.
I have been fighting a vibration at 3500 rpm since I got it on the road. Nothing made sense since everything was original and should have been balanced. The clutch was the only variable (after the new harmonic balancer was put in because the old one had a slight wobble). I finally pulled the trans and clutch last night and vibration went away. The new clutch I installed was the culprit. So now I need another and I was wondering what everyone else is using? I will not be going to the drag strip and I do not want to have a super hard pedal. Something smooth and high quality so I don't have to go through this again. Cost is not really an issue at this point. I just want a good reliable smooth clutch. Any ideas?
Old Dec 5th, 12, 02:46 PM
restore-z28's Avatar
restore-z28 restore-z28 is offline
Sonny
Default Re: Input on clutch selection for 69 z/28 all stock
Hey Rich, the last clutch I changed out I used an AC Delco set up. Never had an issue and was fine for a stock application. Here is a link to Heartbeat city with one of these units, mine was purchased through my friends shop locally but this will give you an idea.
http://www.heartbeatcitycamaro.com/s...n-HD-AC-Delco/
1969 Z28 Camaro
www.bccamaroclub.com
Old Dec 5th, 12, 02:54 PM
X-77 keith X-77 keith is offline
keith
I relaced mine with a Zoom Muscle Car Seies , and works great.
Old Dec 5th, 12, 05:06 PM
keithl1967 keithl1967 is offline
Keith
Zoom HP here...
Keith
1967 Camaro
Bought it in 1994:
230, PG w/ 314K miles!
Today:
Motor "in progress": 406, 10:1, comp xr282HR, Dart Iron Eagle 200cc, Holley Contender dual plane, Holley 750 DP
Muncie M-20
GM 8.5, 3.73 posi
Old Dec 5th, 12, 05:21 PM
Andrew69's Avatar
Andrew69 Andrew69 is online now
Andrew
Centerforce Dual Friction here.
Skunk Works
302DZ, M22W Muncie, 12-Bolt Rear 3.73
Some photos: http://www.camaros.net/showroom/show...0&ppuser=11587
Member # 159 (Formally known as X33D80)
Old Dec 5th, 12, 06:01 PM
Luwi67 Luwi67 is offline
Bobby
Originally Posted by andrew69 View Post
centerforce dual friction here.
x2
67 Camaro 350
M20 4spd console,
8.5 30 spline Eaton posi,
Moser shafts, Richmond 3.73
custom Spintech exhaust
black/black
Old Dec 5th, 12, 06:19 PM
1968RallySport's Avatar
1968RallySport 1968RallySport is offline
Daryl
x 3
Old Dec 5th, 12, 08:03 PM
ZLP955 ZLP955 is offline
Tim
McLeod RST; pricey but well worth the cost IMHO, and has nice light pedal feel.
'69 04A VN Z/28 69-69 715 with VE3. Ex-E/MP at Lions in LA; Now a work in progress.....
Old Dec 5th, 12, 08:28 PM
Rich
Please keep them coming. I will be looking at them and choosing in the next few days.
Old Dec 5th, 12, 10:10 PM
mjlynch71 mjlynch71 is offline
Jerod
Two years ago, put a new motor in my 1969 Camaro with 4 speed. Also went with the ZOOM Muscle car clutch, not a bad price either, I do not race the car, and it seems to be great. I have never done a clutch before. I pulled the motor and trans together and put it all back together outside of the car, then once in adjust the clutch rod, and that is it. I would get another one if I needed it. Thanks, Jerod
Old Dec 5th, 12, 10:34 PM
bhodges061 bhodges061 is offline
Bryan
+1, Zoom was an easy setup and works great
68 Camaro SS Silverstone Silver with Tuxedo Black Rally Stripes
468 VortecPro
M22 Rockcrusher
Old Dec 6th, 12, 05:07 PM
keith
Centerforce is a good clutch. With that said it is about two or three times the price of the Zoom and can be a pain to adjust. I have used Centerforce in a race car, but love the Zoom in my street car like I stated before.
Old Dec 7th, 12, 08:20 AM
firstgenaddict firstgenaddict is offline
James
I love the pedal pressure (light) and the clamping of the Center Force I don't think I would use another brand (especially if I were using it hard).
James
"Collectin' Camaro's since only Rednecks Drove them"
https://picasaweb.google.com/1123922...28_Restoration
Old Dec 7th, 12, 11:04 AM
zdld17 zdld17 is offline
Don
I am using the Centerforce CFII single disc with short t/o bearing , Its been the car over 10 years and still bites well . Put it in and forget it. I do used the adjustable pivot arm ball and factory "632" fork with my TKO.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Dec 26th, 12, 08:22 AM
Rich
So I took my Sachs clutch and pressure plate with my flywheel in to the machine shop. They spun it up and the clutch unit measured over 100g out of balance. I just hope I did not do damage to the bearings in the 100 miles I put on the car. The flywheel itself was only 4g out. After all your input and conversations with my new machine shop I ended up going with the closest OE replacement I could find. I went with an AC Delco unit. We balanced the flywheel and then spun it up again with the new clutch unit installed. Everything was balanced to 3.5g. I installed it in the car and the vibration is gone. The engine was very smooth with nothing attached. I do get just a tiny vibration with clutch and flywheel installed. Still 95% better than it was. Trans will be going back in soon and a road test will tell the whole story. Thank you all for your input and suggestions.
