'99 SS T-top - roof repairs - Team Camaro Tech
Fourth Generation 1993-2002
Old Dec 8th, 12, 05:25 PM
tblazer tblazer is offline
Doug
Default '99 SS T-top - roof repairs
Greetings gents:
I've been away from the Camaro website for some time having recently retired from working.
I have a not-so-serious problem with my roof, (the "crown"), i.g. main portion of the roof between the t-tops and the rear hatch windshield. For some time now I've noticed what looks to be rivets protruding. They almost appear as rust bubbles, but clearly are not rust since visually they are evenly spaced.
My question is how to repair this. I thought that I saw an article in a car magazine which addressed this situation. The owner featured in the article replaced the OEM surfacing of the roof with a stainless steel surface, but I recall in the article that it was a painstaking process, probably not recommended for the novice (which I am).
Any help or suggestions would be greatly appreciated.
Merry Christmas to all!
Old Dec 8th, 12, 05:57 PM
Everett#2390's Avatar
<Jake-68's rule
Default Re: '99 SS T-top - roof repairs
Thank you, and a Merry Christmas back to you.
Don't take out the T-top, J/K
Picture?
Next time I have mind out, very rare, I'll take a look.
Give a man a rescued dog for the health of both their souls.
'With age comes wisdom, but then wisdom ages you even more.' Other Stuff
Old Dec 9th, 12, 06:26 PM
Doug
Everett, ..can you explain further your response? I cannot determine the intent of your response. Again the problem I refer to has to do with the narrow portion of roof aft of the T-tops. After speaking with a friend I believe now that the surfacing is sort of like a skin, which might be able to be replaced. The article I read previously in a magazine explained how the owner replaced his with I believe was a stainless or brushed aluminum skin.
Thanks for your reply though.
Old Dec 9th, 12, 11:02 PM
PowerWindows PowerWindows is offline
Jim
You probably have the same issue many 4th gens have, that being the adhesive used to glue the roof onto the metal supports (roof is fiberglass IIRC) causes bubbles in the roof aft of the T-tops where it's glued down. I've had several 98-02 4th gens and only 1 of them didn't exhibit this. I believe there is a TSB out on this.
Choose your poison from these listings regarding this: http://www.google.com/search?q=4th+g...hrome&ie=UTF-8
67 Camaro: 454/TH400/4.10 12 bolt. Lots of options: PS/PDB/PW, tilt, tach, gauges and more. K-K + 797-Z...
"Politics is the art of looking for trouble, finding it whether it exists or not, diagnosing it incorrectly and applying the wrong remedy" - Sir Ernest Benn
Old Dec 10th, 12, 04:23 AM
<Jake-68's rule
I was asking for a picture of the bubbles.
My '00 SS has T-tops, but I rarely take them out, but next time I have them out, I'll look.
From Jim's suggested search, I chose Page 90 of LS1Tech.com:
Below is the summary of the first post of this thread:
***Summary of Issue as of 8/9/2012***
4th gen F-body sail panels are adhered to the body of the car using glue (urethane). The bubbling sail panel paint issue is due to this glue seeping through the panel and causing bubbles along the surface of the panel. The reason for the seepage seems to be due to the lack of paint/epoxy primer on the underside of the panel, a process change which started at GM on very late '98 cars (05/98 and later are at risk) and affected all '99+ models. This allows the glue to directly contact the panel and seep into it over time. Heat/UV exposure seems to bring the glue through the panel once it's begun to seep.
Sanding/painting/bondo'ing/etc. will not fix this condition. Complete panel replacement is the only permanent fix. Once the glue has eaten into the panel, there is no way to correct this from the top side. The problem lies underneath, and nothing you do on top is going to change this. The only other option would be to never drive the car in sunlight.
This panel was discontinued by GM several years ago. At this point, your only options for panel replacement are:
New reproduction panel from site sponsor 6LE (fiberglass or carbon fiber)
Used panel from a donor 4th gen car built prior to 05/98 (and yes, an LT1 era car panel will fit and work just fine)
Have a custom panel made by a body shop that is good with fiberglass fabrication
There is a GM TSB out about this issue, but this is NOT a recall. Here is a link to the post containing the original TSB:
http://ls1tech.com/forums/2783967-post2.html
There was an updated TSB issued in April of 2003, but the only scanned file of this I can find is currently not working (on page 35 of this thread). If someone has a scanned copy of this 4-2-03 revision, feel free to post it in this thread, and I will link it to this summary. Having said that, the repair process is the same between the two TSBs.
Glues that have been approved via the GM TSB for new roof application:
- U400 HV Essex (Dow)
- 3M Urethane 08690
Rarely, some customers were able to get GM or their dealer to cover the cost of replacing the panel, but this is no longer an option as GM doesn't stock the part and won't pay to locate/obtain/install a reproduction or used panel. The last person I've heard about that was able to get GM to cover the repair did so in or around 2008.
A carbon fiber panel would be nice.
Old Dec 10th, 12, 08:41 AM
Doug
Everett, ..this is exactly what I was hoping to learn about my roof problem. I did not take a picture, but even if I did don't know if you will see the protrusions because they're not that pronounced.
I'll read over the link you provided and determine my next course of action.
thanks for the information.
Old Dec 11th, 12, 04:36 AM
<Jake-68's rule
You're welcome.
I looked at the roof on mine. I saw dimples, but no protusions, unless you would like to count the panel bowing up between the dimples.
Before I bought my SS six weeks ago, First Owner always had it in the garage, so, I may be seeing these later in life.
Carbon fiber roof panel would look nice.
Old Dec 11th, 12, 04:59 AM
blue89bird's Avatar
blue89bird blue89bird is offline
Jason
As others have said, this is a very common problem and is well documented. I've had many 4th gens and happened to get lucky with never running into this but I've seen dozens of them with the problem.
Jason
2009 CTS-V - 1968 Camaro 327/M20 Sequoia Green
Old Dec 11th, 12, 10:40 AM
Doug
Hey Everett; ..see my other post about "Wheel Criteria". Can you offer any advice concerning aftermarket wheel application for my 4th Gen?
Team Camaro Tech > Generation Specific Forums > Fourth Generation      Current Topic: '99 SS T-top - roof repairs
Location
Location
First Name
Human Verification
