| Team Camaro Tech Current Topic: engine for 68 project - have a 327 block, looking for advice | ||
| Engine General Engine Discussion. |
#16
i would go 350 r 383--383 if u can afford it --iron eagle heads-cheap and work excellent on 383s(i have a pair for sale 400.00)--a nice bullet cam roller r not-i got friends in s a that can help you r refer u to a good machine shop
#17
dollar for dollar, you can't beat a swap to a 5.3 these days. even after you buy the carb intake and ignition controller and put them on a junkyard motor, you will be right at about the same price point as a stock rebuild on a 327 or 350 and have a whole lot more motor under the hood.. i wish i had been smart and gone that route instead of sinking $1500 into a basic overhaul of the 305 i put in my 86 Camaro..
also, San Antonio was a neat city, too.. we saw a lot of history within walking distance of the hotel, and the river walk at night was one of the coolest places i've ever seen.
you don't plan sincerity. you have to make it up on the spot. wanna hear about 20 years ago when i was too smart to know any better? |
#18
Years ago I built a small journal 327, bored it 30 over - stock flat top cast pistons (9 to 9 1/2 - 1 comp) with cast rings and balanced it.
Cam was Chevys 350 H/P 327 hydraulic. Heads were camel back close chamber 194’s - had the exhausts cut out to 1.60 and a three angle valve job done. Intake was Chevrolet aluminum hi rise dual plane unit with a 650 holly double pumper and a set of headers. I put it in a 68 Chevelle with a four speed and 373 gears, what fun. I would drive it to the local drag strip and with full exhaust system and stock size tires it would do consistent 13.90s @ 105 mph. It would also get 16 mpg down the road. I built many motors over the years, gotta say this was one of my favorites, just put gas in and drive. |
#19
The only Mustang I'd ever own is a Fender. |
#20
Greetings from Arizona
When I put my wife's 67 Elcamino togather I rebuilt a 327, 202 heads, nice cam as I'm running factory ac and power brakes, with 700r4 and 12 bolt 3:31 gears it gets about 20mpg freeway My 69 Camaro had 327/210hp, I installed GM Crate motor, 350/330hp, 700r4 and 67 Transam 10 bolt with 3:31's also gets over 20 mpg freeway Both cars are drivers with Camaro on the road for about 5 years and Elcamino 3 years. Camaro motor cost about $2500.00 at local GM dealer and 327 cost about 1500.00 but I had heads already Good Luck, hope this gives you some ideas, My son has a 66 Chevyll with 383, 700r4, 4:10's turns 12's street driven, but power brakes required vacumn reserve tank due to low engine vac. FUN to drive haha j
http://photobucket.com/photobucketcomJayBj 66 SS Chevyll 67 Elcamino 68 Malibu 2dr 69 Camaro Convertible |
#21
Just wanted to add that I very recently sold the 327 engine from my '68 Camaro and building a 383 over the winter. I was told in no uncertain terms that you need a 4-bolt main block to build a solid 383. I asked if we can use my own 327 for that purpose and was told, no. Most (if not all) 327s were two-bolt mains.
Vic
Vic Brincat 1968 Camaro RS Convertible On Deck: 383 SB, AFR 195 Heads, 670 Holley, Doug Thorley Tri-Y Headers, Lunati "Voodo" roller cam, Weiand 8150 Intake, Scorpion Edurance Rockers, 700r4, Eaton Posi with 3.73 gears, Front Discs, Summit Legend 5 - 15" with BF Goodrich TAs |
#22
The 383 should be okay in a 2 bolt application, GM used the sbc 400 with 2 bolt mains lots of times.
1968 Camaro NHRA/IHRA SS/C 'Super Stocker' 396/Jerico 1968 Street/Strip Camaro 350 w/PG 1968 Caprice NHRA/IHRA Stock ELiminator O/SA 327-250 HP Land of the Free Because of the Brave It Takes a Long Time to Grow Old Friends |
#23
If rebuilding the 327 keep the duration around 210-215* @ 0.050"
Go with the Vortec heads, or the RHS Vortec type heads. Get the proper intake for it. Compression builds torque. 10:1 is pump gas friendly though it may need 91 octane. Keep your quench tight. 0.040" is great for the engine. A CHEAP stroker is a 350 crank and pistons. 350 cranks are a give away, your rods are the same in both engines, you'll need pistons anyway if you bore it 0.30. Go with the same heads with any size build you go with. Keep lift below 0.470" lift and the heads won't need any mods.
71 Camaro 355 NA 11.1650 @ 119.30 1.5028 60' |
| Tags |
| 327, engine horsepower, rebuild, stroker |
