Trying to figure out what 67 I have - Page 2 - Team Camaro Tech
Tag Team De-coding tags and numbers.
  #16
Old Jan 16th, 13, 03:36 PM
Paul68RS/Z28 Paul68RS/Z28 is offline
Paul
Default Re: Trying to figure out what 67 I have
So now what, should I rebuild this thing or chunk it? I really wanted to rebuild the 327. Urghh[/QUOTE]
It looks like you have a good starting point, HEI, A/C , probably a 4 bolt block (some versions even had the machined webs).
Drop a 307 crank in it and some new pistons and you'll have you 327. You won't get the torque the 350 has (might be nice with the A/C functioning) but you'll have the higher rev'ing 327. Yep, the 307 is a cast crank, but balance the assy and use quality parts and you'll be fine, below 500 hp.
In the end, you'll always get more torque and HP from the 350, but there's something about the scream of a high rev'ing 327
Old Jan 16th, 13, 06:00 PM
bcm66's Avatar
bcm66 bcm66 is offline
Bryon
Originally Posted by merlhagstrom View Post
So any sugggestions? Is this motor worth rebuilding, heads, pistons, cam, ect or just trash it? Also I must assume it is possible that they did marry the 350 truck motor with the 2 speed? I have the stock shifter and it feels like a two speed.
As stated earlier, it is probably a decent engine to rebuild.
Check the casting number on the heads to see what they are. It does appear that maybe they transferred over the intake and the carb from the original engine, along with possibly the alternator. Check the numbers on those and post what you find.
68 Camaro SS 396 - 468 BBC now, Air Gap Intake, 781 heads, M21, 12 bolt. 67 Chevelle SS 396.
Looking for 68 Camaro with body number NOR 181016
CRG - www.camaros.org
  #18
Old Jan 16th, 13, 08:35 PM
Luwi67 Luwi67 is offline
Bobby
In the end, you'll always get more torque and HP from the 350, but there's something about the scream of a high rev'ing 327 :yes
Also you can add the 151 cam and some S/R Torquers and you'll have yourself a nice little L79 copy
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180 Headers
https://www.youtube.com/watch?v=1-8uYCabSog
black/black
no radio
  #19
Old Jan 16th, 13, 08:57 PM
GoCamaro27 GoCamaro27 is offline
Merl: I would search for a nice 327 block to rebuild. There are still plenty of decent ones out there, and even if it's not the original 327, at least it is correct for the car. I also have a 327 coupe, originally Marina blue but with black deluxe interior (and it's an RS), so I found a good 327 block that only needed to be bored slightly to 331, and rather than a 3 speed manual or powerglide I'm going to put a 700R4 in it. A nice 327 would be a pleasant departure from all the 350s (no offense intended towards the 350) but they were great engines back then and still are now. With aluminium heads they are real performers.
Don't feel bad about the whole numbers matching thing, I fell for the same thing with my first '67 RS, it also had a 4-bolt main 350. You might want to save that block for something else.
Relax, all right? My dad's a TV repairman, got an ultimate set of tools. I can fix it.
1967 Camaro RS ZL1 427/4 speed
1967 Camaro RS 327 L30 4 speed
1955 Bel Air 4-door, 350/TH700R4
1969 Camaro convertible Z11 Indy 500 Pace Car, matching numbers 396/4 speed
1968 Camaro, Grotto Blue project car
1970 Camaro RS
My Mom's 1978 Lincoln Continental Mark V Diamond Jubilee Edition
2000 Rolls Royce Silver Seraph
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Tag Team      Current Topic: Trying to figure out what 67 I have
Location
Location
First Name
Human Verification
