Found my broadcast sheet - Team Camaro Tech
Tag Team De-coding tags and numbers.
Old Jan 21st, 13, 10:05 PM
Frosty69 Frosty69 is offline
Jennifer
Default Found my broadcast sheet
It was on top of the gas tank in my '69 Van Nuys built Camaro. It is not in good condition but I could make out at least partial codes for most of it. Now, like so many before me, I'm wondering what all these codes mean. Can anyone help me with a few of them?
Engine RPO box 155 - R
Transmission bix 151- Looks like C (car has a TH350)
Low volume options box 169- B and 170 - 0 (Car does have power windows)
Air cleaner box 180 DD
Engine Harness box 252- ED
Not numbers matching but I think this was originally a L65 350 (production date is 1/15 which matches the 01C on the trim tag) but the boxes with the engine codes are not legible. Is there anything else that could help verify this?
Any way to figure out what the original carburetor was from boxes 178-183, or somewhere else?
Thanks in advance for any help!
Frosty 69- L65, TH350, original RS (and will be again some day), 59 59 frost green with D90 hockey stripe, power windows- back on the road after 20 long years!
nsaneblk- 2011 Camaro Black 2LT/RS M6 (daily driver)
Old Jan 22nd, 13, 12:32 AM
ZLP955 ZLP955 is offline
Tim
Default Re: Found my broadcast sheet
Can't help with decoding the broadcast sheet, but.......
Congratulations on finding it!!!!!!
'69 04A VN Z/28 69-69 715 with VE3. Ex-E/MP at Lions in LA.
Link to mark x22's excellent templates & diagrams:
http://s1218.photobucket.com/user/ZL...?sort=3&page=1
Old Jan 22nd, 13, 11:09 AM
Kurt S Kurt S is offline
L65 with TH350. No console guages.
Box 176 is the carb.
Kurt S.
CRG - www.camaros.org
Old Jan 22nd, 13, 11:35 AM
69camcon 69camcon is offline
Alex
Our cars are very close and similar. My sheet that is under the tank is still there (this one came out of the interior) & the car is all original (just one repaint 25 years ago). Check out to see if the options match up. L65, TH350, Rally Sport.
The Rides
1969 Camaro RS
1969 Nova SS
Old Jan 22nd, 13, 08:59 PM
Jennifer
Thank you Kurt!! Sadly Box 176 can't be read at all. I'm not sure if my car is in the database or if you even work on that. If you do and want more information I'm more than happy to share.
Thank you Tim. It is kinda exciting.
Old Jan 22nd, 13, 09:06 PM
Jennifer
[QUOTE=69camcon;1773092]Our cars are very close and similar. My sheet that is under the tank is still there (this one came out of the interior) & the car is all original (just one repaint 25 years ago). Check out to see if the options match up. L65, TH350, Rally Sport.
Alex, they are similar! Based on your sheet I think I can confirm some codes that were fuzzy. I used adobe to mark the differences, boxes I covered over and left blank are the ones I couldn't read. AC is one difference, I wonder what the other ones mean.
Old Jan 23rd, 13, 11:26 AM
bcm66's Avatar
bcm66 bcm66 is offline
Bryon
Jennifer, check this link. Posted by Ed from CRG. Very cool.
http://mysite.verizon.net/bertfam/misc2c.htm
If you can, post a copy of the one from your car.
68 Camaro SS 396 - 468 BBC now, Air Gap Intake, 781 heads, M21, 12 bolt. 67 Chevelle SS 396.
Looking for 68 Camaro with body number NOR 181016
Old Jan 23rd, 13, 12:08 PM
Alex
Well box 151 with the R is for Rally Sport which is the big reason my sheet is important to verify it's a real RS. The link provided above has a decoder but it's still missing some of the options.
The Rides
1969 Camaro RS
1969 Nova SS
Old Jan 23rd, 13, 12:21 PM
bertfam bertfam is offline
Ed
I'm assuming you mean box 161, not 151, and yes, the decoder is old. VERY old. Probably around 30 years old, so it's not up to date. A lot of new info has been discovered since then, but at least it's "something".
Ed
Old Jan 23rd, 13, 03:52 PM
HOT3O2 HOT3O2 is offline
Rick
What is the main differences between a "Body Broadcast Sheet and a "Chassis Broadcast Sheet? Were there any differences in the sheets from Norwood or L.A.
Rick
  #11
Old Jan 23rd, 13, 04:37 PM
They are for different parts of the assembly line.
http://www.camaros.org/assemblyprocess.shtml#chev
"the Body Broadcast Copy (BBC) was used on the Trim Line and Final Line, and the Chassis Broadcast Copy (CBC) was used on the Engine Dress, Chassis, and post-marriage overhead Chassis Line."
Kurt S.
  #12
Old Jan 23rd, 13, 08:23 PM
Jennifer
I wish I could post a picture! All you would see is a brown mess. I took lots and lots of close up pictures to preserve what info is there. I'm afraid there is not much hope for the document itself.
Thanks for the link!
  #13
Old Jan 23rd, 13, 08:54 PM
Jennifer
161 confirms the RS option but 151 confirmed the transmission so I'll take them both. My car is not a numbers matching and doesn't even have the RS parts anymore but it is still really cool to have the document.
From your sheet Alex and another similar one posted on the CRG forum I think I have most of the codes but still have a couple of unanswered questions.
Boxes 169 and 170 (F and R Geo setting) what does this mean? (All three sheets have B and O)
What are the boxes below that have no description?
Box 178 (All three sheets have AL)
Box 199 (Your sheet has B)
Box 228 (My sheet looks like it has # in that box)
Box 233 (All three sheets have C)
Can anyone help?
  #14
Old Jan 24th, 13, 11:06 AM
bcm66's Avatar
Bryon
Unfortunately we may never know what ALL of these things are on the Chassis and Body Broadcast Copy sheets. But, most of the important things have been figured out.
For those that have a "build sheet" for their car, realize that you are lucky.
  #15
Old Jan 24th, 13, 12:13 PM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Im not sure if this has been shown yet but check it out for yourself. RPO numbers.
I had to save it to my decktop before it would open.
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
"There will come a time when you believe everything is finished,
That will be the beginning." Louis L'Amour
Photos of my Camaro for viewing
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Tag Team      Current Topic: Found my broadcast sheet
Location
Location
First Name
Human Verification
