BB AC Box??? - Team Camaro Tech
Heating & Cooling Heating, cooling and air conditioning
Old Jan 28th, 13, 06:51 AM
The Camaro Guy The Camaro Guy is offline
Bruce
Default BB AC Box???
I am converting a 69 SB AC car to a BB with the correct engine mounts etc. Can I still use the original SB ac system, Except brackets.? I have been told I could with a slight modification to the inside of the suitcase.
Old Jan 28th, 13, 08:06 AM
Vintage 68's Avatar
Vintage 68 Vintage 68 is offline
John
Default Re: BB AC Box???
The inner suitcase sections are markedly different, with the BB unit also having a slanted section to clear the heads ...
There are also other differences in the plumbing, but most of those are cosmetic and the SB components can be left where they are and still function.
Summit carries the inner cases, here is the link - http://www.summitracing.com/search/p...e-outlet-cases
You could just change out the parts needed and go from there - or ... try to find a complete donor set-up from a BB.
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Last edited by Vintage 68; Jan 28th, 13 at 10:24 AM. Reason: bad-bad-bad spelling ...
Old Jan 28th, 13, 08:30 AM
Mark C Mark C is online now
Mark
The outer case is different as well, the angle from the firewall to the faces where the two halves mate up with each other is different than the small block one. Theres less of an angle (90 degrees being perpendicular to the fire wall) in the big block one, ie the whole evaporator tips more towards the fender than the small block one to allow for more clearance. The firebird A/C unit (thers only one for all engine options) from the same year is much closer to a BB Camaro unit, and it can probably be found alot easier than a BB Camaor unit.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
My Engine Compartment
Old Jan 28th, 13, 10:23 AM
Vintage 68's Avatar
John
Red face Re: BB AC Box???
Mark is right!
(and wow do I make a lot of spelling errors )
The Firebird units are sometimes easier to find as stated and are very close to the BBC set-up.
1968 Convertible
Some trucks
Old Jan 28th, 13, 10:39 AM
TJS69 TJS69 is offline
Tom
Smile Re: BB AC Box???
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
Old Jan 28th, 13, 03:04 PM
Bruce
So the question remains, if I were to indent the engine side of the outer case, cut and re-fiberglass will it work. Is there any clearance between the side of the engine and the outer case? I am working on a budget here and every dollar counts. I am trying to build this car under 20 grand including the purchase price of the SB X-44 car. Building it to a BB 4 SPD, silver over black, all body work, paint is done with an all new interior. Bought a 76 Suberban for a grand, with a re-built 454, T-400, I camed up the BB, new intake and holley DP 800 and sold the 400 to help pay for the upgrades . . . got the PS and radiator too!
Old Jan 28th, 13, 06:40 PM
Tom
Are you going to run headers ? You will have fun fitting them with a BB a/c box, let alone a SB one. People that have run a SB box and a BB, couldn't change the back two spark plugs. You should try the Pontiac route and maybe you'll get lucky.
I would go with a vintage air setup and that box would come out.
Old Jan 30th, 13, 04:31 AM
Bruce
Is it possible to change the suitcase to a BB and keep the SB inner part or is the whole thing different? Looking at the SB case, There is several inches of space on the engine side so it seems I could cut away as much as needed for clearance then fiberglass it in. I am planning on headers.
Old Jan 30th, 13, 07:08 AM
Mark
Both halves are different, and will not bolt up to each other.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
