How much would these be worth? - Team Camaro Tech
What's it worth? & ebay discussions
Old Feb 4th, 13, 03:53 PM
Black Z Black Z is offline
Default How much would these be worth?
I have a used set of iron cylinder heads, less then 1000 miles, here is a description from their website:
Pro Topline S-RT Iron Heads
76CC Combustion Chamber
167 CC Intake
Designed for Severe Duty with Hydraulic Cams, Kit includes 1.437 Manley Springs single Spring w/Damper (115 lbs Seat pressure at 1.800/250 open pressure 550 max lift, Manley Chrome Moly Retainers & Machined Locks, Manley Severe Duty Intake 2.02 & Manley 1.60 Inconel Valves). You still get the increased flow of multi-angle intake and radiused exhaust valve seats. In fact, Pro Topline says the 23° heads out flowed similar aluminum and cast iron heads on the market by 5% for a BIG improvement in low-end torque and top-end horsepower. Also feature an improved water jacket design, which increases flow around the plugs for improved combustion, angles plug locations, and a three angle valve job. Best of all, they accept conventional piston and valve train components for easy bolt-on power.
I was trying to figure out what value they would be if I decide to sell them? They cost $999 if purchased new and assembled. Thanks for the help
1969 Camaro SS
Old Feb 4th, 13, 04:58 PM
Eleanor's Nemesis Eleanor's Nemesis is offline
Michael Gekko
Default Re: How much would these be worth?
400-500 bucks imo.
1968 Camaro NHRA/IHRA SS/C 'Super Stocker' 396/Jerico
1968 Street/Strip Camaro 350 w/PG
1968 Caprice NHRA/IHRA Stock ELiminator O/SA 327-250 HP
Land of the Free Because of the Brave
It Takes a Long Time to Grow Old Friends
Old Feb 4th, 13, 05:16 PM
Vega$69 Vega$69 is offline
John
If they are such great heads why did you ditch them?
69 Pro Tour - LS7/T56 Building
C6ZO6 Vette Lemans Blue
69 Z28/RS Tribute
355/5 Speed(SOLD)
69 RS Clone
427/TH400(SOLD)
67 RS
ZZ502/5 Speed(SOLD)
69 Camaro
406 SBC/TH400(SOLD)
Old Feb 4th, 13, 05:19 PM
I am just going a different with my motor. I havent decided if I want to hold onto them for another build or sell them. So just trying to find out a value for them.
1969 Camaro SS
Old Feb 4th, 13, 06:58 PM
frankk frankk is offline
76cc heads in my books would be very undesireable.
wot
Old Feb 4th, 13, 07:00 PM
Ok, thanks, but they have their applications also. What I am looking for is what value someone thinks they are worth, not if they are desirable or not.
1969 Camaro SS
Old Feb 4th, 13, 07:07 PM
Screamincamaro Screamincamaro is offline
Agreed.... 76cc heads in my books would be very undesirable.
Also, 167 CC Intake those are pretty small ports. Probably a step above stock application depending on what the compression chamber looks like. Will probably make good low end torque but don't expect to make much HP with them. $400-600 used
Old Feb 4th, 13, 07:08 PM
Thank You, now that we have established they are undesirebale to some people maybe some others could chime in and let me know what they think they could be worth?
1969 Camaro SS
Old Feb 4th, 13, 07:20 PM
cool rocking daddy cool rocking daddy is offline
Chet
What do boat anchors sell for in your area. Undesirable means put them up on e-bay with no reserve and take what you can get for them.
69 SS Clone, soon to be Metal Man's version of Fathom Green with white pearl D90 stripes, 355, pocket ported 041 heads, mild hydraulic cam, Demon carb,GW subframe connectors and solid body bushings, 8.5 10 bolt, 2004R
Old Feb 4th, 13, 07:22 PM
Thanks for your input
Originally Posted by Eleanor's Nemesis View Post
400-500 bucks imo.
1969 Camaro SS
Old Feb 5th, 13, 06:21 AM
John
Heads are similar to RHS. I don't believe they are in business any more which may also hurt value
When I buy used whether they have 1000 miles or 10000 miles are worth no more then 1/2 the cost of new.
Would be a good head for a budget build boosted motor
69 Z28/RS Tribute
355/5 Speed(SOLD)
69 RS Clone
427/TH400(SOLD)
67 RS
ZZ502/5 Speed(SOLD)
69 Camaro
406 SBC/TH400(SOLD)
