73 RS LT Z28 4spd restoration - Page 2 - Team Camaro Tech
 Ground Up Restorations
Second Generation 1970-1981
  #16
Old Dec 25th, 12, 10:27 PM
firstgenaddict firstgenaddict is offline
James
Default Re: 73 RS LT Z28 4spd restoration
OK back to the Current Car
James
"Collectin' Camaro's since only Rednecks Drove them"
https://picasaweb.google.com/1123922...28_Restoration
  #17
Old Dec 25th, 12, 10:40 PM
James
12-25-2012 CURRENT STATE!!!
Body work done and in 2 COATS of Evercoat Epoxy Primer Filler.
James
  #18
Old Dec 26th, 12, 05:11 PM
Cortez69Z28 Cortez69Z28 is offline
Bryan
James. Bryan here. Is that at whits old place?
  #19
Old Dec 26th, 12, 09:04 PM
twozs twozs is offline
mike
don't paint stripes on that car . light copper metallic with neutral comfort weave vinyl interior
  #20
Old Dec 27th, 12, 01:02 PM
James
This is a correct car although I am painting 2 hoods for the car and it may end up with a bundle of snakes sidepipes with wide slots but there will be no stripes painted on it nor anything done which cannot be removed in a day or two to return it to stock.
It will be the correct color, it will have the correct over spray, sealers in the seams, floor joints etc, the trim holes in the rockers will be there even though it has no lower trim (because it is correct) it will be laser straight, with a mirror finish...
I always tell my customers that the way to ensure you get the most return is to restore the car correctly, modify it to your individual taste in a DAY II/period correct style retaining all the original parts for when the car is sold. You will get the most for and have the largest pool of buyers if the car is as close to original as possible, it is especially the case for a numbers matching 4 spd RS Z28.
James
  #21
Old Feb 6th, 13, 05:57 PM
James
For color matching clips, primers, inspection marks etc I use a set of PANTONE color chips as a standard. Pantone Matching books are available worldwide as the printing/graphic arts industry uses them as a standard. If you have ever picked out colors for a business card at a commercial printer... you've used it.
The RED-BROWN primer...
New sub frame bushings and cushions, Double checking everything for panel alignment....
After I get my alignments I mic the shim packs and write the figure down on a copy of the assembly manual page that has fender attachments.
I'm waiting on the NOS urethane nose to check everything then we are going to give her some color...
James
  #22
Old Feb 7th, 13, 04:45 PM
James
Going through an attic of parts and extra parts and duplicates and NOS....
James
  #23
Old Feb 16th, 13, 04:51 PM
James
Going through boxes of parts that have been collected over the years...
NOS Bowtie Center caps --2 Different styles-
I have 5 raised logo lighter blue centers & 4 of the Dark Blue Flat centers.
James
  #24
Old Feb 17th, 13, 10:12 AM
James
JACKPOT!
NOS RS NOSE
James
  #25
Old Aug 15th, 13, 07:05 AM
James
]More Progress...
The ruddybrown primer to mimic the bath which the car shells were dipped in prior to color coats.
Seam sealing the floors and other hidden places
Black Flowcoat primer for the remainder of the body panels.
James
  #26
Old Aug 15th, 13, 07:06 AM
James
CODE 60 oversprays...
James
  #27
Old Sep 13th, 13, 06:03 PM
James
The color match has been extremely time consuming on this one.
after playing with a gram scale and tints metallics etc I think I have it... lol
James
  #28
Old Sep 19th, 13, 04:11 PM
James
James
  #29
Old Oct 9th, 13, 08:32 PM
James
James
  #30
Old Oct 10th, 13, 01:07 PM
hugger1 hugger1 is offline
Nice work ....cant wait to see the car done ...good score on the NOS RS nose too...
Team Camaro Tech > Generation Specific Forums > Second Generation      Current Topic: 73 RS LT Z28 4spd restoration
Location
Location
First Name
Human Verification
