Front Fender bolt - Team Camaro Tech
Body Shop Paint & Body Forum
Old Feb 23rd, 13, 01:13 PM
norcal_68 norcal_68 is offline
Default Front Fender bolt
Can someone tell me if this fender bolt screws into frame or if it it supposed to have a backing nut?
Mine is turning back and forth freely and seems like there IS a backing nut.
If so, how do you access nut?
Thanks,
Old Feb 23rd, 13, 01:27 PM
69 383 tko 5sp's Avatar
69 383 tko 5sp 69 383 tko 5sp is offline
topher
Default Re: Front Fender bolt
on my 69, the bolt just behind the wheel has a U nut that clips on to the flange mounting point. By design, it should not free spin.
69 plain jane 383,TKO 600, 10 bolt mono 3.08 w/caltracs, TT2's 17"x9.5 rear 17'x7 fr. Goodyear F1 275/40/zr17,215/45/zr17.QA1 coil over. Speed tech uca/lca. March ultra serp.
Old Feb 23rd, 13, 01:33 PM
captcanuck68 captcanuck68 is offline
Ted
The only was I got to one was to take and drill a small hole in fender to get at it...a pain, but saw no other way. There might be other ways...some may chime in, eh?
capt
Old Feb 23rd, 13, 03:25 PM
Default
thanks! it spins free 180 degrees and is loose so maybe I can try breaking the nut after spraying it w/ PB.
Old Feb 23rd, 13, 06:15 PM
rogerh rogerh is offline
It's a common problem. Most of the time you need to used a sawzall and cut the bolt head off.
Roger
1967 Camaro SS/RS 350/295HP Coupe. First and only owner.
Old Feb 23rd, 13, 09:14 PM
Denvervet Denvervet is offline
David
Or use a cutoff wheel to cut/grind head off. After that you'll be able to see what happened.
68 coupe ,572,tko
Old Feb 23rd, 13, 09:44 PM
Garfields Maro Garfields Maro is online now
Garth
The holes in the fender are slotted. If the bolt partially turns, it may be loose enough you can yank the bottom of the fender free and then have access to the nut.....or instead of "yanking", might fit a screwdriver or bar in behind the fender to pry it out.
  • '68 RS, AA, 749, L30, M(uncie)20 (originally a 3spd), 15yr backburner resto........
Old Feb 24th, 13, 07:35 AM
yellow69RS's Avatar
yellow69RS yellow69RS is offline
Jeff
This is how I did it.
Jeff
Old Feb 25th, 13, 02:42 PM
Great, thanks for all the advice. And of course, the other bolt on that fender is headless, with the stud in the frame. I tried drilling it out with a left handed bit and could only get about 1/4'' into it before my cordless battery died, it seems futile with a cordless drill. I'm going to try and get at it with a corded drill for more drill speed. I was going to try and heat up the stud but I wanted to remove the fender first.
Thanks for all the advice.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Body Shop      Current Topic: Front Fender bolt
Location
Location
First Name
Human Verification
