| Team Camaro Tech Current Topic: Internal Regulator Conversion | ||
| Electrical & Wiring Troubleshooting electrical |
The following was submitted by Dave Nulton (dnult)
An accurate and informative article on converting to an internal regulated alternator. http://home.comcast.net/~Jimragtop/W...enCharging.htm
JimM's firstgens.com Camaro Board Jim's NEW Blog! http://www.Jimragtop.com former TC moderator, who thanks autoforums for giving me free lifetime gold membership Last edited by JimM; Apr 14th, 06 at 06:59 AM. |
Excellent! (I'm bowing with my hat off)
Give a man a rescue dog for the health of his soul. My 68 Camaro http://www.flickr.com/photos/everettwn68 www.firstgens.com |
What Everett said.
Thanks Jim for posting and thanks everyone for the compliments. I hope I haven't overdone the technical jargon and that noobs find it useful. Take care everyone.
Dave ======================== 68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI |
This I think is a little simpler but haven't tried it yet. Buddy did his Nova and all is fine. http://www.camaros.net/techref/ftecref14.html
Great write up Dave.
Now a question for you or anyone else. I did this conversion last year on my '69, but didn't use a REAR support as mentioned in Wes's write up. Are my bearings in trouble if I don't make one?
Dean '69 355-3.73 Moser-Truetrac-TKO-600-Hotchkis-DSE-QA1's-Baer's-17"Budnik's ST U/LCA's-GW Del-a-lum's |
thanks doug worked out fine and took 10 min
THERE IS NO REPLACEMENT FOR DISPLACEMENT 1970 CAMARO 396 350TURBO 373 REAR |
What were the first GM Delco alernators used in the 70's and 80's called? Wouldn't this conversion be similiar to the CS130 conversion electrically? I'm asking because I have a '69 Z/28 that I would like to convert over to an internal requlator system, but I don't have the heart to start cutting and welding on the original alteranator brackets? Can someone help me out with an internal regulator conversion that doesn't involve mechanical bracket modification or point me to a thread that has this information? Thanks.
Doug |
The original Delco alternator was the 10si, this is the external regulated model we are all familiar with.
In the 70's, it was replaced by the 12si, the first internally regulated GM alternator. And yes, in most cases, a 12si is a dropin, with some minor wiring changes. You can buy the correct pigtail connector for the alternator in most auto parts stores, then you just unplug the reg, and jumper the wire connectors, 1 to 4 and 2 to 3. Your gen light will even work.
JimM's firstgens.com Camaro Board Jim's NEW Blog! http://www.Jimragtop.com former TC moderator, who thanks autoforums for giving me free lifetime gold membership |
#11
Just a few corrections...
GM 10DN (externally regulated) to a 10si or 12si (internally regulated) Quote:
http://www.madelectrical.com/electri...elcoremy.shtml For wiring, if you don't want to cut the original wires you can buy conversion kits which make converting to a internally regulated alternator a "plug and play" deal. I recommend this if you are electrically challenged. http://www.americanautowire.com/imag...lternators.pdf |
#12
I did mine yrs ago
on the back opf the Alternator Big red one goes to the nut connection White wire to one of the baynets Blue wire is isolated Thne other baynet fitting on the alternator also commects to the main re wire /nut connection. Gauges, dash lights etc work fine.
My Spelling is not incorrect...it is creative http://www.kakariki.net/camaro/Meguiars.jpg http://www.kakariki.net/camaro/BeauRep.jpg http://www.kakariki.net/camaro/xmasparade.jpg http://www.kakariki.net/camaro/trailer.jpg |
#13
Thanks.
Doug |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| converting to 3wire internal regulator | 67ragtp | Electrical & Wiring | 3 | May 15th, 06 11:44 AM |
| Alum Valve Covers w/ Internal Damage | X33D80 | Engine | 5 | Aug 28th, 05 06:41 PM |
| Window internal replacement | Double J | Interiors | 1 | May 28th, 05 08:33 AM |
| Interesting cowl tag, Very low internal code | click | Tag Team | 6 | Jan 22nd, 05 01:20 PM |
| Dominator 1050 internal linkeage | Milan | Performance | 4 | Sep 6th, 02 03:32 AM |
