Steering arm length - Team Camaro Tech
Brakes, Suspension & Steering Conversion questions, Steering & Handling
Old Apr 9th, 08, 01:27 PM
Joes_68 Joes_68 is offline
Joe
Default Steering arm length
Doing the drum to disc on front conversion. 1968 Convertible......Dropped the control arms, and installed new bushings and ball joints, also installed new BB springs and working on installing power steering. My part numbers on the steering arms are 3917193 for lh and 3917194 for rh. Can anyone tell me if these are considered the long short or medium steering arms??? Dave Pozzi's site did not have these part numbers. I have done a search on here and read most of what I can find on these swaps. I realize I need a new rag joint (no problem, Advance Auto) and a longer pittman arm. anything else I may be missing???? And will the swap work no matter which length steering arm I use??? Thank you for your help. Joe
Old Apr 9th, 08, 03:17 PM
Fred Ficarra Fred Ficarra is offline
Fred
Default Re: Steering arm length
First thing that comes to mind is the idler arm. It has to be the same lenght as the pitman arm or you'll have 'bump-steer' problems. Not sure of the rest of your stuff????
One owner 69 Camaro,(yep, bought it new)
RS SS Hugger Orange, L88, 4:10's tru-tack posi, ducted hood, Endura, spoilers.
TH400 (CX) with Coan 8" converter, GV-OD, 8 track still on console and best et 10.495, 128.79mph 1.428 60'
All with 1960's stuff. (except tires and converter)
+ MT Super Scavenger headers & 3" full exhaust with X pipe.
1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too.
http://epitomesrebuild.com/
http://ss427.net/
Old Apr 9th, 08, 07:07 PM
Joe
I have not seen in any of the write ups that the idler arm must be changed too..........Thanks for giving me the heads up. Still waiting if anyone knows the answer to the steering arm question. Joe
Old Apr 9th, 08, 10:35 PM
davidpozzi davidpozzi is offline
David Pozzi
Code:
MAXIMUM TOE CHANGE IN INCHES
TEST 1 - Long idler/short pitman:
Passenger -  Driver       Passenger -  Driver
 31/2" susp. travel         2" susp. travel
  0.075      0.150          0.050      0.085
TEST 2  -  Long idler/long pitman:
   0.160    0.235          0.100      0.135
TEST 3  -  Short idler/long pitman:
   0.165    0.225          0.100      0.140
TEST 4  -  Short idler/short pitman:
   0.125    0.140          0.090      0.090
The sidebar says the best combination is the long idler arm
and the short pitman, with the short pitman being the best
regardless of which idler arm is used.  It also states that
bumpsteer of more than 0.125" over 3" of suspension travel
is considered excessive, and that the early Camaro exceeds
this amount.
numbers on the left are for 3.5" travel, on the right is for 2" travel
Above shows how bumpsteer varies with different combos of Pitman and idler arms. Currently, only one idler arm is available and it's in-between the long and short.
David
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com
67 RS 327 original owner. 1965 Lola T-70
Old Apr 18th, 08, 04:20 PM
David Pozzi
Joe,
I do have those numbers on my page: LONG 6" manual, - LH-3902517 RH-3902518 (67, early long measured at 6") LH-3917193 RH-3917194 slow ratio manual steering.
They are the long arms. You can still use them, your resulting ratio will be a bit slower though.
David
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Brakes, Suspension & Steering      Current Topic: Steering arm length
Location
Location
First Name
Human Verification
