Restoration Corner Where originality comes first
Old Nov 6th, 09, 02:28 PM
braz28 braz28 is offline
Erick
Default 1969 drum brake front hub
looking to purchase a set of drum brake front hubs for 1969 camaro.
Which year and model car would be same for a 1969.
i know Novas have the same hubs, just not certain on which years.
thanks
Old Nov 6th, 09, 02:57 PM
SPARKY69 SPARKY69 is online now
BILL
Default Re: 1969 drum brake front hub
68-72 are the same, from a nova
Old Nov 6th, 09, 03:52 PM
alanrw alanrw is offline
Alan
thanks
You gonna do the JL8 thing? Keep notes, it would make a great tutorial.
alan
Old Nov 6th, 09, 03:59 PM
Erick
alan
Exactly, i am researching all the necessary parts to make a JL8 kit and slowly i will be buying the parts. Once all parts purchased, i will asssemble on the car.
this site as been great for tips and advice.
It be nice if we could all put our knowledge on JL8 parts and have a JL8 do-it yourself file for all team camaro members to view.
Old Nov 6th, 09, 04:15 PM
Alan
Erick, what is your plan for the rear axle plate? I guess the center tube hole is what the O.D. of the axle is. I would think all you need after that is the spacing of the 4 backplate mounting/caliper bracket holes.
I also found this thread:
http://www.camaros.net/forums/showth...ASTER+CYLINDER
alan
Old Nov 6th, 09, 05:41 PM
Jeff H Jeff H is offline
Do you have Wayne Guinn's book, Camaro Untold Secrets? Lots of good JL8 information and some pictures/schematics with measurements and even shows some factory errors. The JL8 rotors were 11-3/4 vs 11" for the standard J52 4 piston brakes and they were 1-1/4 thick vs 1" so they required different mounting brackets and splash shields for the front.
Jeff H
69 Z28 Hugger Orange original factory JL8 brakes, cross-ram & GM fiberglass hood, TI setup, heater and radio delete, Stahl headers, Minilite wheels - being restored
00 Camaro SS daily beater
Old Nov 6th, 09, 09:22 PM
Alan
I thought the mounting brackets for the front splash shields were stock hubs. Jeff, you are saying that the front backing plates/splash shields are NOT Corvette pieces?
alan
Old Nov 6th, 09, 09:42 PM
BlackoutSteve BlackoutSteve is offline
Steve
Don't you mean 69-74?
Resto-modding my '69 Van Nuys Jane.
http://img154.imageshack.us/my.php?i...mbly1866cw.jpg
Old Nov 7th, 09, 11:04 AM
NHBandit NHBandit is online now
Mark
Hollander interchange #1045 GM Part number 3887867. Actually the interchange for Nova says 64-74. Also Apollo 73-74, Camaro 67-69, Chevelle 64-72, Chevy van series 10 64-70, Corvair 65-69, Firebird 68 only (not sure why), Olds Cutlass & F85 68-72, Omega 73 & 74, Tempest 64-66 & 68 (also not sure why), Ventura 71-74. This info is for the hub only, not the drum or the spindle. Should be pretty easy to find some good ones..
Old Nov 7th, 09, 05:00 PM
keithl1967 keithl1967 is offline
Keith
got one off of a junkyard 69 chevelle when I burnt one of my spindles about 12 years ago...
Keith
1967 Camaro
Bought 15 years ago:
230, PG w/ 314K miles!
Progression:
350 (325 horse), TH400, open 3.08
383 (450 horse), TH400, open 3.07
383 (450 horse), TH400, 8.5 4.56 posi
383 (450horse), TH400, 8.5 3.73
383 (450 horse), Muncie, 8.5 3.73
Old Nov 7th, 09, 05:23 PM
KevinW KevinW is offline
Kevin
There is a set in the TC Classifieds right now.
Old Nov 7th, 09, 08:02 PM
alan
The book says the front JL8 splash shields were made from some changes to the J52 standard shield, not Corvette pieces. It looks like most the JL8 brackets were modified pieces to fit the larger rotors. Most people don't realize how different the JL8 setup really is from the 67-68 4 piston disc brakes.
Jeff H
Old Nov 7th, 09, 08:17 PM
Alan
Hmm, Jeff, is it that a J52 shield was taken and machined in certain areas for clearance?
As to the fact that the rear axle was beveled, was it beveled on the inboard or outboard side? Wonder why as the flange fits into the disc itself, no?
alan
Old Nov 8th, 09, 08:35 AM
The flange is beveled on the inboard side.
alan
Jeff H
