| Team Camaro Tech Current Topic: did I get ripped off? | ||
| Transmission & Driveline Transmissions and Differentials |
#16
Well at least you don't need a whole new engine like i had too. Getting ripped is part of life, i think. Lol ..
http://www.flickr.com/photos/10729028@N03/ 68 Camaro / 400 ci / 3.73 10 / Edelbrock 650 4bbl 94 GMC Suburban / 350 V8 / K1500 4x4 98 GMC Suburban / 454 V8 / K2500 4x4
#17
Probably the one on top, but I can't be sure. Put them down flat and take a picture of the side where the thrust washer goes. The thrust washer for the posi gear is smooth with no lip. The thrust washer for the standard gear has a lip around the inner edge and probably won't fit in the posi gear.
Moser Engineering Dealer '69 RS/SS396 pro street/427/4spd/9" http://www.camaros.net/showroom/show...00&ppuser=1922 |
#18
Oh oh, all my thrust washers have lips on them. I put it together using the ones in the top photo. Got .006 and .005 backlash by adding shims to the clutch packs. The spider gears were a little hard to put in, but not bad though. I took a photo anyway.
http://www.cardomain.com/id/balljoint |
#19
Sorry, I forgot that you were working on the 8.5. I thought it was a 12 bolt. Looks like you got it right.
#20
The smaller ones are for a posi.
69 SS 350 Camaro Muncie 4 Speed car. I specialize in rebuilding Muncie's ![]() Lee (In Louisville, Ky) |
#21
Since I dont have a service manual. What are the torque figures to see if the clutches are grabbing properly. I place the axles in each side right? and turn one wheel hub right? I appreciate the help
#22
Probably anything over 40 foot pounds is good. I set them up different when I put them together. I shim them tight. Did you use the limited slip oil additive on the clutches when you put it together? Lubrication will have an affect on the torque.
#23
yes, the clutches soaked in oil and additive for couple days. Thanks again
