Turbo 350 - Team Camaro Tech
Troubleshooting Diagnosing problems done here.
Old Jun 3rd, 12, 04:33 PM
Smith84 Smith84 is offline
Ron
Default Turbo 350
I have a question i have a 84camaro with a 350 turbo tranny thats stuck in first even after manual shifting from under the car what would cause the tranny to lock up like that?
Old Jun 5th, 12, 11:32 AM
dnult dnult is offline
Default Re: Turbo 350
Bad govenor, or a stuck shift valve most likely. Good news is, the govenor is easy to get to with the tranny in the car. The valve body isn't too bad either, except you have to drain the fluid and remove the pan to get to it.
Dave
68 Coupe, 350 w/ Edelbrock Performer RPM heads, cam, intake, 700R4, Dave's small body HEI
Old Jun 5th, 12, 01:45 PM
yellow69RS's Avatar
yellow69RS yellow69RS is offline
Jeff
A vacuum modulator with no vacuum causes a late or never upshift. Hose off or line crimped shut? bad modulator?
Jeff
Old Jun 7th, 12, 01:43 PM
Good point Jeff...perhaps the easiest to check of all.
Dave
Old Jun 7th, 12, 03:29 PM
Ron
Default
I had to slam it in park from reverse, lost brake pressure and that was the only way to get it to stop rolling
Sent from my SCH-R680 using AutoGuide.Com Free App
