| Team Camaro Tech Current Topic: Fel Pro one piece pan gasket question. | ||
| Engine General Engine Discussion. |
I have a 69 Camaro that I am freshening up the engine on and have question about the Fel Pro one piece pan gasket..
The block is a replacement 350 engine out of a 1975 or so passenger car with a thick front oil pan seal. The only gasket stocked at my local parts store with the thick front pan seal is the Fel pro part # OS34510T which has dipstick provisions on both sides, but my dipstick is on the drivers (left) side. It looks like it might leak on the side of the block/pan without the dipstick due to a thinner sealing area. The engine is out of the car right now, and is not coming out again.. therefore I do not want any oil pan leaks.. Does anyone have experience using the double dip stick pan gasket on a single (left) side dipstick block? Thanks in advance for any help.. By the way, I am a returning member having owned a 68 Coupe a few years back before trading for a 71 Corvette.. I sold the Vette and am now a Camaro owner once again.. |
I would just order the correct one. Like you said you don't want to pull the engine again. I use them and have no leaks.
67 R/S Blue 406 518HP and 504TQ Dart block,Callies crank,Mahle pistons,Ultradyne cam 230/238 duration @.050 530 lift at 113 lsa, Afr 195 heads,Holley 4150HP carb and RPM Air gap. TKO600 with 373 gears |
