Brakes, Suspension & Steering Conversion questions, Steering & Handling
  #16
Old Oct 29th, 09, 06:18 PM
keithl1967 keithl1967 is offline
Keith
Default Re: Problem with my new brake setup
Also, if it was lie pushing a brick wall to stop withthe manuals (which I also have), maybe it is because the brakes do need to be adjusted at all four corners...needed to push the pedal harder to the floor to stop that your "normally" should have to?
brakes on a 1967 4 wheel drim were not "self-adjusting" as later models were/are...
Keith
1967 Camaro
Bought 15 years ago:
230, PG w/ 314K miles!
Progression:
350 (325 horse), TH400, open 3.08
383 (450 horse), TH400, open 3.07
383 (450 horse), TH400, 8.5 4.56 posi
383 (450horse), TH400, 8.5 3.73
383 (450 horse), Muncie, 8.5 3.73
Old Oct 29th, 09, 06:23 PM
cmking26 cmking26 is offline
Ok, Maybe tomorrow I'll try using the upper hole and run the engine to check it.
1967 327 pwrgld.
Link http://www.cardomain.com/ride/2187713/1
Old Oct 30th, 09, 04:10 PM
DrSyntax DrSyntax is offline
Andy
In regards to the rod that links the booster to the master cylinder just check you have the right legnth as there can be a short and a long version. I am currently fitting a disc upgrade kit to my 69 and the kit came with a new power booster and master cylinder. The rod fitted to the booster was the short version but I had to pull that out and use a supplied longer version. If I hadn't noticed it would all have gone together fine but would probably have the just the symptoms described here ?
Old Oct 30th, 09, 04:43 PM
Yup mine came with a short and a long as well. I used the long one which seemed to fit right.
1967 327 pwrgld.
Old Oct 30th, 09, 04:45 PM
Steptoe Steptoe is offline
Steps
yes
Old Nov 4th, 09, 06:57 PM
Ok, I tried using the upper brake pedal hole but the booster pushrod would not angle that far up. When Ibled the brakes the fluid never shot out with pressure it just oozed out. So Im thinking this is because the master is not pushing enough pressure. Or could something be wrong with my proportioning block? My best bet I think is to take the remand master back and get a new one to try.
1967 327 pwrgld.
Old Nov 4th, 09, 07:33 PM
Steiner Steiner is offline
Steiner
Try a $30 hand vacuum pump before you take it all apart. Get one that comes with the little brake bleeder cup.
Start out at the right rear, then left rear, then right front, then left front. Use the correct little nipple that sticks in the bleeder screw and pump until no more bubbles come up in the clear line going to the bleeder cup. It helps to have someone watching the master cylinder and adding fluid because it's not hard to drain one like this. It'll pull the air out of the entire circuit.
Also, insert the nipple in the bleeder screw first, pump a few times to build a vacuum, then start to crack the bleeder screw open. Open it no further than what it takes for fluid to start moving. If you open the bleeder too far, it pulls air around the threads.
"Experience is something you don't get until right after you needed it."
'69 Camaro X44, 355/M20, Moser Trutrac 3.42 12 bolt
'97 S10, supercharged 4.3L, 5 speed, Torsen 3.42
'05 Durango, 5.7L Hemi
'02 Honda VTX Retro, 1795cc V-Twin
Old Nov 5th, 09, 01:31 AM
Alright, I ordered a vacuum bleeder kit from Harbor Freight it was $28 shipped. I'll try that and if it still doesnt work I'll go crazy.
1967 327 pwrgld.
Old Nov 5th, 09, 12:23 PM
Steps
Have you checked the pin length?
I have a vac bleeder....us it for checking and calibrating VA units on Dizzys
Meesed around with it bleeding brakes....havnt for yrs now, still use the old tried true pedel down method....
According to the local brake dhop guys...I have known them for over 30 yrs now and have top rep in street and race cars, custom setups etc...
" if cant bleed the tradtional way, there is something else wrong"
"if there is something else wrong, someone dies Im on manslaughter charges"
Thats the law in NZ.
Old Nov 5th, 09, 01:02 PM
larryh56 larryh56 is offline
Larry
I would recommend removing the master and bleeding that again. I installed a completely new system and after bleeding the master and then the 4 wheels I had very little pedal. I removed the master to bleed it again and got quite a few more bubbles out and now the pedal is firm. If you are not experienced bleeding masters (like me) there are some good posts on here about that. I got a brake line at the parts place to cut in half and bend when bleeding the master. Steps is correct, any method should bleed the brakes, some are just easier when you are working alone.
68 RS Coupe 327/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
Hey, where are we going...
and why am I in a hand basket?
Old Nov 7th, 09, 12:59 AM
Calpantera's Avatar
Calpantera Calpantera is offline
Bill
I think you should pull the rod and measure it, sounds like the wrong rod length to me.
'67 with a 40 over 350, 244/254, Lift .510/.533 Hydraulic Cam, Gear Drive, Dart Iron Eagle heads, Holley 650 carb, Performer EPS intake, M21 and 10bolt posi w/4.10s
"Gotta have wings if you want it to fly"
Old Nov 7th, 09, 03:40 AM
Well I used the longer one. Not sure on a size but I have the shorter one laying around.
1967 327 pwrgld.
Old Nov 7th, 09, 08:32 AM
Gar's67 Gar's67 is offline
Gary
In your first post you mentioned that you used fuel line hose to connect the booster to the manifold. DOT Approved Vacuum hose is stronger and won't collapse like fuel hose can. That's why it's 4 to 5 times more $ per foot too. Get that changed.
Gary
Old Nov 7th, 09, 11:45 AM
Steps
That still doesnt measn it is the right length
Check out older post as to how to measure for correct length and change
even 2mm makes a big diff..
Wrong..not can it will.
Old Nov 15th, 09, 02:38 PM
I used the vacuum bleeder today, and tried switching to the shorter rod for the master. Still no movement in the brake pads when the pedal is pushed. Only thing else I can think of is I got a bad master or a line is sucking air at the proportioning block. Or all four wheels need adjusted, but I doubt that all four are that bad that none move at all.
1967 327 pwrgld.
