every thing i look up for the many different heads i got dont tell me cc size of the stock heads, ive also been told that the 2.02 heads with id # 3917291 are "turbo" heads ,not sure what they ment by this?? can any one help??
They mean you should be impressed an pay them Big $$$ for them :thumbsup:
That, or they don't know $tuff about Chevy heads
There is no such thing as a '291 "Turbo Head" - these will not fit Corvairs, the only car manufactured by GM with a turbo that year...
The '291 is a 1968 (year model) casting only. Corvairs used "Turbo" mufflers, carbs, pistons and lots of other "turbo" parts l
It looks nearly identical to the '461-462 castings used the year before, but it has a flat boss on the side between the single left exhaust port and the center two ports. This boss is drilled and tapped for a Temp. Sender on the 1968 models (moved down from the intake manifold).
The chamber CC is usually in the 63~65cc range from the factory - but they can vary a bit more on some and it is also normal to find them smaller now as many heads you'll find have been 'milled' over the years reducing them.
These are commonly called "Camel Hump" heads :yes:
This refers to the two 'humps' on the front pad of the head...
These came in both 1.94" and 2.02" intake valve size.
The 'factory' heads have a "fly-cut" relief machined around the chamber intake valve area to unshroud the valve.
Fwiw, my virgin chambered big valve -461's cc'd at 66.0 and 66.+ cc's!!
And you forgot the -601's that can be as small as 52 cc's!
My -601's cc'd at 53 and 55.
And my old trough sparkplug chambered '56, 265, -306 heads chambers cc'd at 60 cc's and 118 to 120 cc intake port size!!
This is why the old 283 Power-Pack head was such a winner on a 283 b/c their intake ports are right at 137 cc's or so, way bigger than the earlier heads dinky ports!
I left a bunch of them off the pocket list Paul, because I'm seldom interested in them if I see them at swaps and etc...
You'll notice loads of the 'light-weights', like the '883, aren't on there either - they are just to junky/iffy to even consider buying
Feel free to edit the list with your favorites :yes:
Yes youngsters, there is a "Turbo" head for SBC. An over the counter only part. Part # 3965784, casting number 340292. Developed in 1975, the best SBC head of the era. "Turbo" is the nickname, like "Powerpack" or "Fuelie" is. They have 14mm angle plugs, 2.02, 1.60 valve seats, no heat riser, large ports, 66cc chambers, screw in studs, new design inlet port floor, large valve spring pockets, Tin alloy added. I have owned a couple pairs before.
Yes youngsters, there is a "Turbo" head for SBC. An over the counter only part. Part # 3965784, casting number 340292. Developed in 1975, the best SBC head of the era. "Turbo" is the nickname, like "Powerpack" or "Fuelie" is. They have 14mm angle plugs, 2.02, 1.94 valve seats, no heat riser, large ports, 66cc chambers, screw in studs, new design inlet port floor, large valve spring pockets, Tin alloy added. I have owned a couple pairs before.
Yes, that is what I said. These were Chevys top racing heads until the Bowtie line came out.
