Low headers - wrong motor mounts? - Page 2 - Team Camaro Tech
Camaro Tech General Tech Area
For best results use specific forums
  #16
Old Oct 11th, 12, 09:33 PM
slnteyd slnteyd is offline
Steven
Default Re: Low headers - wrong motor mounts?
hey you guys couldnt tell me what frame stands and part # magisyc is using in his pic would you? im running a sbc setup with a 200r4 and the stands im using put the motor too far forward for the cross member and its off center. magisync's stands look like exactly what i need im using the narrow motor mounts from energy.
any help would be appreciated thanks
Old Oct 11th, 12, 09:35 PM
Steven
sorry forgot to add its the bto 2004r crossmember so it should bolt right up but the trans is too far forward.
Old Oct 12th, 12, 05:09 AM
zdld17 zdld17 is offline
Don
My D 368 header fit a tad higher that Stenier's car , I use the poly 31115 Energy mount, but I had to add some solid 1/4" solid spacers on each mount to get the Champ oil pan a comfortable distance away from the crossmember.
Prior to that I had the Thorley 376-1C with no issues. My car is at an 8.5" curb height from the rocker panel.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Oct 12th, 12, 09:39 AM
TJS69 TJS69 is online now
Tom
Smile Re: Low headers - wrong motor mounts?
The combined height of frame stands are almost equal. There is no "Magic" stand that is a cure all. The only stands that will move the engine significantly are the BBC stands. They offset the engine 1/2" to the passenger side and about 3/4" forward of the small blocks location. If you think that you have BBC stands, the driver's side stand is about 1/2" taller.
The only stands that the "Tall and Narrow" engine mounts will fit are the 1969 302/350 (SBC) or the 1969 BBC stands.
Is it the transmission crossmember mounting pad or the engine that is off center ?
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1
Old Oct 12th, 12, 10:06 AM
Tom
This is how my engine sits on 302/350 SBC stands. The engine is offset by about 3/16", but this depends on how your fenders were installed and if GM sheet metal etc.
The transmission mounting pad is centered for a small block.
Big Blocks transmission mounting pads are offset 1/2" to the passenger side and are 3/4" forward of the small blocks location.
Many aftermarket transmission crossmembers are made WRONG... They think all engines are on center OR all are offset. It depends on what engine was used for their pattern.
Old Oct 12th, 12, 10:25 AM
Steven
The transmission pad is off center towards the pass side so now it makes sense that these are probably big block engine stands thanks for all the info I really appreciate it you saved me a huge headache!!
Old Oct 12th, 12, 03:45 PM
rojo rojo is online now
Robert
Hmmmm. Topic for another thread. Big block car without knowing it?
Robert
'69 355ci 10:1, 64cc Edelbrocks, Comp Mag 280H, Performer RPM, 700r4 (2000 stall), 3.55 posi A/C PS PDB Hotchkis
'67 369ci 10.3:1, 64cc Edelbrocks, Voodoo 276/284, Performer RPM, Holley 650DP ...4spd 3.73 Moser 12 bolt
'77 Dodge Powerwagon 340ci X-head 727 NP203 Dana 44 / Mopar 9.25
TC member #18
Old Oct 13th, 12, 08:45 AM
Steven
Hey thanks for the info everything bolted up perfect after swapping the mounts out, the old frame stands were a couple I got from a buddy so his probably was a big block car.
Sorry didn't mean to jack anyone's thread.
thanks again!
