Heating & Cooling Heating, cooling and air conditioning
Old Oct 28th, 09, 02:30 PM
Chuck Gibson Chuck Gibson is offline
Chuck
Default Vintage Air
How much trouble to install in 1967 non ac convertable with headers i would also like to move my alternator to the drivers side . Car has a 350 engine around 275HP Trans 3 speed auto with headers does not run hot should i go with a larger radiator.
Thanks in advance
Old Oct 28th, 09, 06:39 PM
BelAirBob BelAirBob is offline
Bob
Default Re: Vintage Air
Thanks in advance
Not a hard installation at all. The VA kits come with different brackets depending on which side you want to mount the compressor. Also, different length hoses. The Gen IV is the most advanced kit offered. Its all electronic like a modern car- no cables, and takes up alot less space under the hood. Its a nice way to go.
http://www.belairbobs.com/inc/sdetail/1015
BelAir Bob
67 RS 327, PG matching #s.-being resto'd.
69 Z28/RS X33 D80 Dusk Blue DZ,M21,Endura, Fiber optics- being resto'd.
67 327/275 L30, PG All matching w/broadcast sheet- Fact AC,PB,PS- Being enjoyed
Old Oct 29th, 09, 01:30 PM
brownnote brownnote is offline
Yep, the install isn't too bad, I say that now after it is done ha ha! Anyways, i went ahead and left the compressor on the driver's side, w/ alternator on the pass. side and ended up using the full length of the extra long hoses they provide that just have to have a final crimp to length connector on it. I was actually shorted one hard line, and didn't want to wait to get it, so I improvised. I do think that having the compressor on the pass. side makes it look cleaner, and will change my setup when I get the $ set asside to swap in some efi, but for now it is fine.
I would say that if I had to do the install over again, it would probably go 2x faster just due to the learning curve, but don't plan on doing it again anytime soon. I really like my gen IV vintage air system, and it made things soooo much nicer out here in Arizona! At any rate, I think one thing that makes life way easier with the install, is to take the right front fender off to get the old heater box inlet off and out. it just won't come out... in one piece that is! Anyways, I didn't have any help to take the fender off/hood etc, so it set me back hours trying to work around that I would say. Just do yourself a favor and take those pieces off!
I kept missplacing items, and 0-rings, so that def. makes for a longer install. That and working in a garage that is 115 degrees don't help either!
It is a great product, and will use it again for future rides.
Old Oct 29th, 09, 02:22 PM
larryh56 larryh56 is offline
Larry
X2 (especially removing the RF fender)
It is a very well designed kit. Read the instructions a couple of times before starting and it should got well. I have been very impressed with mine.
68 RS Coupe 327/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
Hey, where are we going...
and why am I in a hand basket?
Old Oct 30th, 09, 07:45 AM
69SS 350 5 Speed 69SS 350 5 Speed is offline
Jim
I installed VA Gen IV with Aeroquip stainless lines and the polished compressor in the wife's 69 last year. I ordered the kit for right side installation and moved the alternator to the left. Ordered Zoops billet brackets and pulleys. Easy install but time consuming. Used it on the Powere Tour in June and the rest of the summer. Nice cold air and we used the heater last weekend. No problems there either.
There is a fine line between hobby and obsession and I think I crossed it!
www.cardomain.com/ride/719562
69 Camaro SS 350 4 Speed (Now a 5 Speed)
69 Corvette L46 Convertable 4 Speed
71 Nova 350 4 Speed (Son's car in Dad's care for resto)
Old Oct 30th, 09, 02:32 PM
stope4 stope4 is offline
Does Vintage still use the cheap looking plastic cover on the firewall? The one the hoses protrude through?
EricE
68 Butternut Yellow
SS Coupe 396/325
Old Oct 30th, 09, 07:36 PM
Lucky68's Avatar
Lucky68 Lucky68 is offline
The Gen IV system uses a metal plate for the firewall (painted black). It doesn't look too bad and is much better than the plastic one.
68 Camaro: No motor/trans, 12 Bolt Posi 3.73, Hotchkis/Global West suspension, Vintage Air.
http://rides.webshots.com/album/250023748XWhfQW
Old Oct 30th, 09, 08:21 PM
ProdigyCustoms ProdigyCustoms is offline
Frank
I had a 20 year old kid (apprentice) working with us that I did a 20 hour challenge on a Gen IV. I asked him to read the instructions 3 times cover to cover so when he was doing the install and reading for the 3rd time, he would remember having read this and also remember things coming up. The kid beat the clock by a couple hours and it was perfect!
Nice kid, but if he can do it, anyone can.
Yes, you can get compressor brackets for driver side short alternator (67 / 68 style) and passenger side long water pump style (69 style), also compressor brackets for headers or Exhaust manifolds.
Frank Serafine
Prodigy Customs
Pro Touring Muscle Car Specialist
FREE PRO TOURING TECH and PROJECT PLANNING for Forum Members
Weekdays 8AM TO 10PM EASTERN TIME
FOUR ZERO SEVEN 832 1752
GP SuperStore
Group Purchase Discount Auto Parts
Old Nov 2nd, 09, 02:11 AM
Chuck
Smile Re: Vintage Air
Thanks for all of the information and tips.
Chuck Gibson
Old Nov 11th, 09, 02:08 AM
Hood_Lum Hood_Lum is offline
Oliver Lum
I'm in the process of installing my Gen IV.
Is the only reason to remove the fender to make removing the heater box easier?
Most of my heater box is already off (aka. broken) and the only portion still attached to the car is the section under the fender. Haven't taken a real close look at it but would I be able to take this section off fairly easy? Looks like just a round part with a rotating thing inside. I'm assuming it's just held on there by a few screws.
67 Camaro
96 Camaro Z28
94 Miata
