Where to get terminal ends? '69 Camaro - Page 2 - Team Camaro Tech
Electrical & Wiring Troubleshooting electrical.
  #16
Old May 15th, 12, 03:09 PM
69-Pace's Avatar
69-Pace 69-Pace is offline
Default Re: Where to get terminal ends? '69 Camaro
Try calling lectric limited and American Auto Wire
1969 Z11 Pace Car - L48 350cid/300hp - 4 Speed Muncie 12 bolt rear
http://69pace.blogspot.com/
Old May 15th, 12, 03:15 PM
MW67RS MW67RS is offline
Matt
I called American Auto Wire and they said they didn't have anything. The guy I talked to recommended looking at pcsconnectors.com. I went to the website and found these. www.pcsconnectors.com/delphi_terminals.aspx
They look similar but don't know if they are the same.
Never heard of lectric limited. I will have to see if I can find them and give them a call.
Matt
67 RS, 406 small block, TKO600, Moser 12-bolt (3.73)
Old May 15th, 12, 03:35 PM
Matt
Just doing some more looking online and found this site. Shows a picture about 1/2 way down that looks like my connector. http://www.rowand.net/shop/Tech/Auto...Connectors.htm
I think I will give them and try and find out. It appears that the 67 is different than the 68 and 69.
Matt
Old May 15th, 12, 03:52 PM
flyingskibiker flyingskibiker is offline
cb
I have PCS bookmarked from other threads. Here is one of my links:
http://www.pcsconnectors.com/search.aspx?find=twin+lock
Though, I'm pretty sure I had it marked because those terminals are used in things like the turn signal switch, rear body harness, and center console... They look the same as what you've pictured. But...
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
Old May 15th, 12, 04:10 PM
Vintage 68's Avatar
Vintage 68 Vintage 68 is offline
John
Thumbs up Re: Where to get terminal ends? '69 Camaro
Those bulkhead connectors are the "TwinLock" design from Packard Industries ...
There was a thread eons ago that identified them and gave a source, but they've gone out-of-bus. or at least off-the-web according to a recent search - they sold them in bags of 10~12 for @$8
There are two common sizes in the connectors;
12/14 Ga = PCS #6288953
18/20 Ga = PCS #2973915
There's also a special Crimping Tool for them - it was expensive
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old May 15th, 12, 04:42 PM
Matt
Is the crimper necessary or can you use needlenose pliers and solder?
Matt
Old May 16th, 12, 10:42 AM
Vintage 68's Avatar
John
Wink Re: Where to get terminal ends? '69 Camaro
I guess you 'could' ...
Heck I've seen a guy closing a crimp with a vise
But using the correct tool will give the best mechanical bond and assure the strain-relief is correctly locked on the insulation.
I have seen these crimpers in stores for under $20 (I know, a lot to spend for something you don't think you'll use often) - I bought mine years ago at a "Bargain" price of just under $100 ... and I've seen them for twice that on some sites ...
Crimps look like this - Click image for larger version
Name:	Crimp Tool with Packard connectors.jpg
I use mine more often that I would even thought, specially because they will do most of the GM and others Packard style connectors.
Maybe you can just check around with a few shops in your area a find a mechanic that would be willing to do the crimps for you after you've got everything ready for a few $$ - worth a try anyway.
1968 Convertible
Some trucks
Old May 16th, 12, 11:16 AM
Matt
I can't spend $100 for crimpers but could swing $20. Any idea where I could find a set of crimpers for close to $20?
Matt
Old May 16th, 12, 11:23 AM
Vintage 68's Avatar
John
Well ... not the place I bought mine through, or this place - http://crimpsupply.com/packard-delph...FWIGRQod5msQlw -
But 'Amazon' seems to have several - like this
Amazon.com: Delphi Packard Five-cavity Wide-range Crimping Tool 22-12 AWG / 24-14 AWG: Automotive Amazon.com: Delphi Packard Five-cavity Wide-range Crimping Tool 22-12 AWG / 24-14 AWG: Automotive
- that may be just the ticket for the $$
1968 Convertible
Some trucks
