Big Block in a '67 - Team Camaro Tech
Old Feb 2nd, 07, 07:26 AM
IDS_Bill IDS_Bill is offline
Team Member
Bill
Default Big Block in a '67
Hey Dudes,
Okay so - continuing the generation of tasks and parts for my '67 - I am trying to determine a couple of things... (and yes they are DUH questions...)
Will the 427 fit under the hood with the original style performer manifold and carb? I'll actually have the stinger hood so I will have another inch or so but I am concerned cause I see disclaimers on a lot of sites about not fitting a '67 hood.
There's a lot of talk of motor mounts and subframes. As this is the first Camaro I have done, when I yenko out (get it - yenko? I kill myself! ) the 350 that is currently in it, other than other bolt-in motor mounts - are there any other mods needed for the 427? I don't remember seeing anything about welding until the Aussie guy's right hand drive thread. Any info?
Thanks,
Bill
Old Feb 2nd, 07, 07:30 AM
Blade's Avatar
Blade Blade is offline
Matt
Default Re: Big Block in a '67
do u have a flat hood or a cowl? Cowl hoods the top of the breathe will sit right at the cowl underneath. as for the big block all u need is motor mounts.
Got to give the PEOPLE what they want!
Look....if you wanna be the best then you gotta take out the best!
1967 Prostreet Camaro
BB 431 650hp
400 Turbo Trans
Ford 9" 4:56 gears
http://www.cs3automotive.com/index.php
Old Feb 2nd, 07, 07:41 AM
Team Member
Bill
I'll have the stinger fiberglass hood that was an option on 67 Yenkos. Should give me another inch or so...
Old Feb 2nd, 07, 07:47 AM
Eric Kammerer Eric Kammerer is offline
Yes, you will need to change the bolt-on engine frame stands. The motor mounts are the part that bolt to the block itself.
Lots of info to search on here. try terms like "frame stand", "big block swap", etc.
You will also need a different transmission crossmember, depending on what's in the car now and what trans you want to use. Holes on the trans cross are offset to the passenger side to accomodate the shift of the engine in the same direction.
Eric
69 'vert project big block/TKO 600 RR
68 'vert driver RS clone -- gone!
Old Feb 2nd, 07, 07:58 AM
67funcar 67funcar is offline
My 68 was originally a 350 car and now has a 427 with Performer RPM manifold and Speed Demon carb. (not very correct, I know but at least I milled the Edelbrock markings off the manifold and heads) It will fit under your hood if you change the motor mounts but it is close! My Demon carb will not allow the use of the stock big block air cleaner base but with a Holley you should be OK. That stock air cleaner base sits lower around the carb than any aftermarket ones that I have seen. If anyone knows of a base that will sit low over a Demon, I would love to hear about it. I have had to go with a 2" high air filter rather than the stock filter.
The heater hoses on a small block car enter the firewall tightly beside the passenger side of the engine. On a big block car they are at the center of the heater box.
I used Hooker headers and they fit very nicely but my former headers (I think they were Hedman) had to be modified to fit around the steering box.
If you have power brakes, the valve covers will have to be short to fit under the edge of the brake booster. The stock style valve covers are fine. Most roller rockers will not fit under the stock valve covers but I used Magnum roller tip rockers and they fit OK)
You will probably have to go with a big block fan shroud because the big block motor mounts will position your engine off center slightly and the fan may hit the small block shroud.
That's all I can think of for now. Have fun.
Grant
Old Feb 3rd, 07, 02:02 PM
Trick1 Trick1 is offline
Also if you have a 4 speed you will need a BB Z bar for the clutch.
Its a little longer to make up the offset motor mounts.
The hood fitment depends on the Intake air cleaner combo.
Hi rise single plane vs a short duel plane intake
A Duel plane with a drop base air cleaner is the ticket I think.
And a larger radiator.
The shift to the pass side lets the rocker covers clear the brake booster and make room for exhaust around the steering box.
Trick1 68rs 454 4sp 12blt
Old Feb 5th, 07, 09:35 AM
kmotion kmotion is offline
Tech Team
Jim
Also think about the weight of a BBC vs the original 350.You will need to change the coil springs (front suspension) to BBC rated springs. Jim
Old Feb 5th, 07, 10:06 AM
TraxUnderground's Avatar
TraxUnderground TraxUnderground is offline
Gary
Your throttle linkage may or may not have to be changed or modded depending on manifold/and carb setup.
Gary
67 RS Resto-Mod 468 5 spd TKO600 3.73 12 bolt (work in progress but finally on the road!)
http://s96.photobucket.com/albums/l1...=camaroRS1.jpg
http://s96.photobucket.com/albums/l164/traxunderground/
73 Camaro project in a million pieces
Similar Threads
68 Big Block Camaro.. Real Big Block Car???? Bowtie Muscle Tag Team 27 Aug 28th, 06 07:13 AM
67 big block AC pics. Newbie Heating & Cooling 2 Jul 7th, 06 05:40 PM
Tall deck block in 67 Camaro fiveforty Engine 0 Apr 3rd, 06 05:56 PM
Small Block or Big Block PDW HOTRODS Performance 25 Dec 19th, 05 06:21 PM
i got me a factory big block Monte..sorta novaderrik Bench Racing 0 Aug 10th, 05 07:14 PM
